Anything welding
Discussion in 'Garage / Workshop' started by EL TACOROJO, Sep 17, 2010.
  1. Apr 19, 2022 at 8:35 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Yep. Normal. It will drop when you pull the trigger.
    la0d0g and Rakso like this.
  2. Apr 19, 2022 at 9:41 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Vulcan cart from Harbor Freight, same with the welding table next to it.
    Would make my own but we just moved in and I've got nothing to work on at home.
    Wsidr1[QUOTED] likes this.
  3. Apr 20, 2022 at 6:29 AM
    Dean62
    Dean62 Well-Known Member
    Jacob
    Florida Panhandle
    2020 TRD Sport 4x4 BR Access Cab Manual
    if you can find a local welding supply store you can probably get a better deal in the long run
    I bought my tank for $250 and get refills for $35 on a 80cf
    la0d0g[QUOTED] likes this.
  4. Apr 20, 2022 at 7:23 AM
    koditten
    Kirk
    Central Michigan
    I just swapped out a tank an hour ago.
    Cost me $77 for a 336 cf tank. Those are like handling a dead body!
    Hence I transfer the gas from this tank to the tanks that are on my 2 welders. Once its down to 1/4 full I can bear hug it and put on one of the other welder carts.
    RustyGreen and Rakso like this.
  5. Apr 20, 2022 at 7:41 AM
    la0d0g
    running for the hills
    For crawling not hauling
    I fill local. I was referring to initial purchase which is what they were asking about originally (if I recall correctly).
  6. Apr 20, 2022 at 7:56 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Yes, it was me asking and I was talking about initial bottle purchase.
  7. Apr 20, 2022 at 9:32 AM
    la0d0g
    It stirred up some great discussion and note I need to go check my flow :anonymous::D
    Kwikvette[QUOTED] likes this.
  8. Apr 25, 2022 at 11:10 AM
    dk_crew
    dk_crew Well-Known Member
    Dave
    Austin, TX
    2005 Tacoma 4x4
    My manual (hobart) says the typical rate is 20 so I've kept it there and haven't adjusted. But I think I will start fooling with it to see if I notice a difference going a tad lower and make my small tank last longer. I've been tempted to get a 2nd bottle -- running out sucks.
  9. Apr 26, 2022 at 4:51 PM
    soggyBottom
    soggyBottom Well-Known Member
    I have a small piece of 4140 I need to heat treat.
    What's a cheap way to measure temperatue for this sort of thing? I'll need around 850c for this.
  10. Apr 27, 2022 at 7:11 PM
    Zebinator
    Zebinator Well-Known Member
    Norcal
    06 Tacoma TRD Offroad
    Thermocouple + milivoltmeter.
  11. Apr 28, 2022 at 6:15 AM
    Bentrodder
    Bentrodder PeeRunner Fanboy
    Peter
    Cotati, CA.
    2015 DCLBFTMFW TRD Sport
    Kings and a TW DECAL!!!
    I use these all the time. Cheap and easy. They come in all different heat ranges.
    https://www.amazon.com/Markal-Thermomelt-Temperature-Indicator-Fahrenheit/dp/B004N84AAQ?crid=2TMKDBVQCNHC3&keywords=temp+stick&qid=1651151663&sprefix=temp+stick%2Caps%2C204&sr=8-12&th=1
    tyfoon11 and koditten like this.
  12. Apr 28, 2022 at 7:10 AM
    Tacman19
    Tacman19 Well-Known Member
    Dave
    Mid Missouri
    19 Tacoma SOLD
    As many as I can fabricate
    I pay $65 for a 80. You need to shop around.
    Zim
    koditten likes this.
  13. Apr 28, 2022 at 7:20 AM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    He bought the full tank for $200. Filling it alone should be around $65, but unless you’re scouring Craigslist all day, a full tank would be hard to find for $65.
  14. Apr 28, 2022 at 11:01 AM
    la0d0g
    This vv
    :thumbsup:
    GHOST SHIP[QUOTED] and Drainbung like this.
  15. Apr 28, 2022 at 5:58 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Anyone have a Karnage Welder? Looking for thoughts on it and to find out what kind of battery is in one to swap it out with LiFePo4
  16. Apr 28, 2022 at 6:02 PM
    koditten
    Kirk
    Central Michigan
    With a name like that, I'd run for the door. Never heard of it
    What welder needs a battery? Am I confused? Yes.
  17. Apr 28, 2022 at 6:04 PM
    Sandman614
    Tim
    '06 SR5 Off Road
    lol portable offroad welder to fix trail KARNAGGGGE *in my most wrestling announcer voice*
    Drainbung likes this.
  18. Apr 28, 2022 at 6:32 PM
    koditten
    Kirk
    Central Michigan
    I get you. That makes sense.
    I've never used any of these battery welders, but I can't see a big issue. Practice on the most common items that trail fail and hope you never need( or do hope) so you can win all the praise from the team.
    I've looked at a few, and non of them are built for everyday, all day use, but for emergencies, why not give it a go?
    No matter the welding rig, the operator ability is going to be the deal sealer .
  19. Apr 28, 2022 at 6:52 PM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    Anyone have an English wheel?
    I’ve read to buy the HF one and build a better frame for it as the dies are fine.
    In two weeks I’ll no longer have access to the shop I work at… will miss ALL of the things!
  20. Apr 28, 2022 at 6:56 PM
    koditten
    Kirk
    Central Michigan
    I don't. I'm running out of space for the tools I already have.
