Anything welding
Discussion in 'Garage / Workshop' started by EL TACOROJO, Sep 17, 2010.
  1. May 21, 2022 at 6:56 PM
    perterra
    perterra Well-Known Member
    Tejas
    Thats a hoot, never seen it before. 40 years in the biz and you learn something new every day.
  2. May 21, 2022 at 7:16 PM
    Slurmin Furrmen
    Slurmin Furrmen Welder / Fabricator
    Probably
    Northern Colorado
    21 OR DCLB
    Bearing wear
    yeah, the customized grips and accessories have taken off over the last 10 years ... I have been in or around the welding field for not quite 20 and a lot has changed even in that time.
    They are, without a doubt, a complete and utter waste of money, but still fun and I am a sucker for colors. Black and grey is boring as hell. :bananadance:
    There are some out there that serve a purpose beside just looking good. I used to have a large diameter torch grip on my field rig, it actually made long days on pipe much easier on my grip / hands / forearm as the larger diameter helped with feel, and I found myself not gripping the torch as tight on cap passes. It was turned out of wood and epoxy and about 1-1/4" OD. I really liked it unless it got wet / sweat gloves, then it was slicker than greased owl shit.
    But the ones at home in the picture above are strictly for the hell of it.
    RustyGreen and shakerhood like this.
  3. May 22, 2022 at 12:15 AM
    mjbtaco
    mjbtaco low and slow
    Michael
    Montclair , so cal
    Turbo'd 95.5 extra cab and 2013 Silver DCSB TRD Sport
    PERFORMANCE Custom Turbo Setup FRONT SUSPENSION Drop Spindles by Aaron Carswell 01-04 Swaybar Endlinks Energy Suspension Endlink Bushings Cando Upper Control arms QA1 coilovers with 8" spring Custom 4 pot Brembo BBK Modified lower control arms with mjbfab qa1 mounting plates and Poly bushing sleeves REAR SUSPENSION Chasis Tech drop leafs QA1 adjustable shocks weld in drop notch Gas tank cross member bridge 3" angled blocks 2013 Double Cab Short Bed TRD Sport Eibach Pro Truck Shocks front and rear Lifted to the 3rd setting on the front shocks
    Finally mounted my vice to my welding table after about 3 years of using clamps to hold it down any time I used it lol.
  4. May 22, 2022 at 12:19 AM
    mjbtaco
    Michael
    Montclair , so cal
    Follow em on instagram, I always say I'm gonn buy some but I never pull the trigger lol. Same goes for hour glass ingenuity and his crazy expensive but awesome torch holders lol
  5. May 22, 2022 at 8:19 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    I thought you went with Pink to keep other people from using your torch
  6. May 22, 2022 at 8:24 AM
    Bivouac
    You have Blue eyes correct ?
    I only ever suffered from Arc flash one time long ago. Several eye Doctors agreed Blue eyes are more prone to Arc Flash.
  7. May 22, 2022 at 8:26 AM
    Bivouac
    That was pretty Fast I have a new vice I bought 12 years ago for such a good price I could not pass it up.
    Then I have a few already
    mjbtaco[QUOTED] likes this.
  8. May 22, 2022 at 8:30 AM
    Bivouac
    When your dealing with several hundred thousand dollar machines It is a life saver.
  9. May 22, 2022 at 10:49 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Yep. Blue.
    Bivouac likes this.
  10. May 22, 2022 at 1:41 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Anybody using Harbor Freight MIG wire? .030 steel 2lb is about $9.00. Amazon, HD want $14-$20 for a name brand roll. Any other suggestions?
  11. May 22, 2022 at 1:46 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I really like Weldcote wire for MIG.
    Bluedemon for electrodes (if you do SMAW as well).
  12. May 22, 2022 at 2:11 PM
    koditten
    Kirk
    Central Michigan
    I've never paid attention to brands of MIG wire. It seems they all perform a bit different. I can always adjust my settings or style where I have no issue with the solid wire MIG I'm using.
    Just keep an open mind and play with your settings.
    Kwikvette likes this.
  13. May 22, 2022 at 5:03 PM
    Slurmin Furrmen
    Probably
    Northern Colorado
    21 OR DCLB
    Bearing wear
    Why would pink keep anyone from using my rig?
  14. May 22, 2022 at 5:05 PM
    Slurmin Furrmen
    Probably
    Northern Colorado
    21 OR DCLB
    Bearing wear
    Yeah, I have a few things from hourglass. Nice stuff.
    My current obsession is Kinetic Customs (smackers) if you arent following them.
  15. May 22, 2022 at 5:12 PM
    Slurmin Furrmen
    Probably
    Northern Colorado
    21 OR DCLB
    Bearing wear
    Yup. T650D buckets were around 75000 new. Re-line with ar500, new GET from sandvik, and a line bore ran, at the time, from 10 to 30k depending on the condition of the bucket. Most of them averaged out to around 18,000 in the early 2000s.
    When the customers agrees to my rebuild schedule, we stayed around 12000 ever 8-9 months ... or they could run their crap into the ground to get a little extra production and hit 30k after about 12 months. Some people are just too dumb to understand the benefit of maintenance over repair.
    RustyGreen likes this.
  16. May 22, 2022 at 5:46 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    As some of you know, I've been stupid happy with the Prime Weld 225X TIG welder at school for steel, stainless, and aluminum.
    Liked it so much I bought one for home-use.
    Been on the fence on a MIG welder and finally pulled the trigger (pun intended) on a Prime Weld MIG180.
    I'll post about it if anyone's been taking a look at a $500 MIG welder.
    RustyGreen, Vmax88, dk_crew and 3 others like this.
  17. May 22, 2022 at 6:11 PM
    Bivouac
    Things must be different where you are.
    The jobs I worked no one would touch anything Pink have points deducted from there man card
    Then this was the mid seventies to the early nineties
    koditten likes this.
  18. May 22, 2022 at 6:35 PM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    I will be interested. My old Hobart 150 is bound to give out eventually, and since I have the PW 225 and Cut 60 plasma, I might as well go for the trifecta!
  19. May 22, 2022 at 6:37 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Nice!
    A plasma cutter is definitely next on my list, but once I figure our an air situation at my place.
    How you liking yours?
  20. May 22, 2022 at 6:41 PM
    Bivouac
    How do they handle any Warranty ?
    Near by Warranty service ?
