Anything welding
Discussion in 'Garage / Workshop' started by EL TACOROJO, Sep 17, 2010.
  1. Jan 17, 2014 at 6:49 PM
    #2301
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    Try airgas also, in my experience they tend to be more helpful.
  2. Jan 17, 2014 at 7:01 PM
    #2302
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    You should build a cart instead of buying one. Be a lot cheaper and would be a good first project
  3. Jan 17, 2014 at 7:05 PM
    #2303
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    They won't swap oxygen tanks for argon carbon dioxide. You will have to get a new bottle of nerts.
  4. Jan 17, 2014 at 7:27 PM
    #2304
    SCRunner12
    SCRunner12 Tundra Troll
    Robert
    Santa Cruz, CA
    2006 Tundra DC, TRD, 4wd
    I've heard that and will have to look into it. Might go the easy route just to get it all set up, but it would be sweet to say I built it myself.
  5. Jan 17, 2014 at 9:09 PM
    #2305
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    He's saying he takes one tank in and exchanges it for another with a different gas/mixture.
  6. Jan 17, 2014 at 10:14 PM
    #2306
    nagorb
    Alabama
    2001 dbl cab 4x4
    Yep, though some places won't. I would call first.
    If you don't take your neighbors set up and he wants to get rid of it let me know:D
  7. Jan 17, 2014 at 10:25 PM
    #2307
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    A lot depends on condition, hydro date and so forth. But you're right.
  8. Jan 18, 2014 at 12:22 PM
    #2308
    SCRunner12
    Robert
    Santa Cruz, CA
  9. Jan 18, 2014 at 12:54 PM
    #2309
    nagorb
    Alabama
    2001 dbl cab 4x4
    I wouldn't do it, looks beat up, doesn't even have the nozzle, and the trigger might not be the only thing busted.
  10. Jan 18, 2014 at 3:04 PM
    #2310
    SCRunner12
    Robert
    Santa Cruz, CA
    Ok, I talked to him and he said it was working fine yesterday then started acting up. He just decided to replace it with one of his friends welders.
  11. Jan 18, 2014 at 5:40 PM
    #2311
    koditten
    Kirk
    Central Michigan
    Offer 125. all parts are available for those.
  12. Jan 18, 2014 at 5:51 PM
    #2312
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
  13. Jan 19, 2014 at 1:09 PM
    #2313
    shawnphoto
    shawnphoto Well-Known Member
    MT
    First Gen Tundra
    First Gen Tundra Linked and Long Travel
    what do you guys think about this one http://sandiego.craigslist.org/csd/tls/4294045598.html
    lincoln weldpak 175 "heavy duty version" with regulator, large bottle (not pictured), original spool. has barely been used supposedly. also a 50ft military grade 220 extension cord, all for 850. what do you guys think? i cant seem to find a price on this welder
  14. Jan 19, 2014 at 1:22 PM
    #2314
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    A-hole and douchebag as it may come across, I'd stick to new. There are some good deals out there, but I tend to stay away from them. Spend the couple hundred extra and get something new with a warranty.It just doesn't seem worth it to save a couple hundred and deal with potential problems.
  15. Jan 20, 2014 at 11:27 AM
    #2315
    4banger4x4
    4banger4x4 Probably should'nt have done that.
    Eric
    Whorelando, Fl
    Sucks being the only steel welder in the shop. 20 feet up doing overhead dual sheild. uploadfromtaptalk1390246035398.jpg
  16. Jan 20, 2014 at 12:36 PM
    #2316
    Phil Dammit
    Phil Dammit Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
    Been there done that, cept it was 7018 rod instead of dual shield.
  17. Jan 20, 2014 at 2:07 PM
    #2317
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    I found this guy for $40 with discounts, seems to get decent reviews. I ordered one up for my Miller 180, we will see what kind of quality it is. If the bolting that holds it together looks janky, I was thinking about stripping the paint and tacking it for my first project with the welder. [​IMG]
  18. Jan 20, 2014 at 2:10 PM
    #2318
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Speaking of welding carts, here's my little tyke. I now have a piece of perf protecting the speaker box.
  19. Jan 20, 2014 at 2:15 PM
    #2319
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    ^^^ Very slick.
  20. Jan 20, 2014 at 2:18 PM
    #2320
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Thanks, worked out really well, plus the welders down low so its not top heavy like most carts I have seen.
