Anything welding
Discussion in 'Garage / Workshop' started by EL TACOROJO, Sep 17, 2010.
  1. Dec 4, 2022 at 10:40 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Maybe narrow it down some. Self Shielded or hard wire or able to do both.
    real world budget?
    How much output do you need? Input Voltage?
    Power source and feeder in one unit or a separate power source and feeder
    Happy Shopping !
    soundman98 and koditten like this.
  2. Dec 4, 2022 at 2:16 PM
    CVYota
    CVYota Yarrr, me be Captn Andy
    Andy
    Crescenta Valley
    2011 DCLB V6 4WD
    Ok, ordered a 60 cylinder, the initial out ain't cheap, but I kinda knew that. How much is airgas going to charge for the 25/75 mix, with exchange?
    And for learning, I have a lot of scrap but even more rebar....lots of rebar. Is that good for welding? Or too thick for the 141
    Drainbung likes this.
  3. Dec 4, 2022 at 2:22 PM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    Aortas should be somewhere in the $60-80 range after all their fees and whatnot. It’s been a while since I had a 60 to swap but it was about there.
    Rebar is fine, just need to make sure your ground and actual weld area is clean. Kind of a pita but an angle grinder with a wire wheel should do.
    Kwikvette and Drainbung like this.
  4. Dec 4, 2022 at 2:56 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    You follow the CO trading post thread?
    Someone posted a 120v machine in there a few days ago.
  5. Dec 4, 2022 at 4:20 PM
    Bivouac
    Depends if you know the counter people by name.
    Being a familiar customer really helps being 100% serious in this region .
    Then some branches they really do not like small walk in business .
    soundman98 and Kwikvette like this.
  6. Dec 4, 2022 at 4:23 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Just look around or ask, might even find one so cheap it's free; friend literally just left half hour ago after dropping off his Miller he let me have.
    As for gas, I've found the larger suppliers like Praxair or Airgas to be the most expensive.
    A smaller, local supplier should be cheaper.
    I paid $350 per 150cf tank, and pay about $52 to get it exchanged for 75/25. Helps to get acquainted with said shops...should open an account if they have a means to do so with them and become a regular.
    perterra and Bivouac like this.
  7. Dec 4, 2022 at 7:15 PM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    @Kwikvette
    I have a nephew who just got out (Covid discharge) and his wife is in the reserves. So, Christmas gift in the making.
    I did start with one someone had posted but I have reworked everything except a few of the letters. That seems to be what happens every time I try to use someone else's posting.
    Still going to rework the arrows I added in the lower right, but pretty much done. Same size as the one you got.
    Not going to try to cut anything else until I get my air drying sorted out. Drained the table to make sure I keep that promise to myself. :D
    Making a DIY system to see how far I can get with that before I drop money on a refrigerated system.
    koditten, Drainbung, Delta09 and 2 others like this.
  8. Dec 4, 2022 at 7:16 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Shit that's awesome!
    Is that the Langmuir software they provide?
    And if so, have you found the software used to operate the machine to handle that much G code?
  9. Dec 4, 2022 at 7:21 PM
    Wsidr1
    Indiana
    That is created in Fusion 360(free version). It also will generate the G-Code. The Langmuir software (FireControl) just runs the stepper motors based on the G-Code generated by other programs like F360, SheetCAM, etc.
    This amount of code is not problem for FireControl. Even on an old laptop like the Dell I use in the garage, no problem.
    The CAD programs on the other hand, they definitely run better on a more capable computer. I still run F360 on my old Dell Latitude w/Core I5, but it is not ideal.
    koditten and Zebinator like this.
  10. Dec 4, 2022 at 7:24 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Ahhh ok.
    I do have a pretty good Ryzen 5 laptop I'll dedicate so no worries there. I thought I just read somewhere on the Langmuir forum about the free software included having a limit of how much G code it'll handle before having to upgrade to a purchased version? Maybe I'm misunderstanding the whole thing. I really should just dig the laptop out and start downloading said programs.
    Cool to see Langmuir have free cut files on their site though.
  11. Dec 4, 2022 at 7:26 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Some of the cad software is picky about graphics hardware too. Fusion 360 ran good on my old dell laptop with integrated graphics too. At least for the small parts I was making.
  12. Dec 4, 2022 at 7:43 PM
    Zebinator
    Zebinator Well-Known Member
    Norcal
    06 Tacoma TRD Offroad
    How important is dry air for a plasma cutter? Like, don’t bother without a drier on your compressor, or, it depends on the humidity where you are? asking as I am in this I’d-like-to-never-buy-another-compressor mode. Ugh.
    koditten likes this.
  13. Dec 4, 2022 at 7:47 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    You want the air as dry, I mean dry as possible running through multiple stages.
    This is anywhere, regardless of your environment.
    Cuts are cleaner, and consumables last longer.
  14. Dec 4, 2022 at 7:56 PM
    Zebinator
    Norcal
    The only thing I have found that caused fusion to really choke is huge patterns. I’ve used it on everything from smoking desktops to a 2015 MacBook Air.
    like @0xDEADBEEF said, fusion has a CAM module that comes on the basic version and there is great tutorial on the Langmuir site for using fusion from design to cutting:
    https://www.langmuirsystems.com/software/fusion
  15. Dec 4, 2022 at 8:02 PM
    Zebinator
    Norcal
    I was afraid of that…. Turns out knowledge is expensive. Lol.
  16. Dec 4, 2022 at 8:24 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I don't have a dryer.
    In the summer I go thru plasma torch consumables about every other week.
    In the winter I can go all winter on a set.
    I'm also in the planning stages for a dryer.
    Drainbung and Zebinator like this.
  17. Dec 4, 2022 at 8:34 PM
    wrtoyota
    wrtoyota Well-Known Member
    Yeah I saw it just a bit too late. Looking for something that can run on at most on 30 or 40 amp 240 volt circuit. 120v is useful but not necessary.
    Don't want to spend more than $800. I could probably get away with something a lot smaller. I mostly need to do some exhaust work in the short term.
  18. Dec 4, 2022 at 8:59 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Man, you could easily buy a Hobart Handler, Harbor Freight Titanium, or a Prime Weld MIG180 and be well under your budget for a new machine.
    You could easily find a welder all day long under that price; a nicer machine in the used market even.
    slander, koditten and Bivouac like this.
  19. Dec 5, 2022 at 4:11 AM
    Bivouac
    Moisture and *50,000 degrees of the plasma arc do not mix well .
    Consumable life is very short.
    Your best option is a Motor guard M-26 filter at the plasma machine . Check the filter often till you have an idea how often it needs changed,
    Plus any air driers you might have at the compressor.
    Per my* Hypertherm Rep Max
  20. Dec 5, 2022 at 7:02 AM
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    Thanks for the link to the tutorial. Hopefully, it will be the motivator to get me to design the spring plate/air bag mount/bumpstop idea I have bouncing around in my head.
    Zebinator[QUOTED] likes this.
