Anything welding
Discussion in 'Garage / Workshop' started by EL TACOROJO, Sep 17, 2010.
  1. Feb 12, 2023 at 2:44 PM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    Went on a cutting binge this afternoon. I had them already designed in Fusion 360. I love 16 gauge for signs:
    Got this one painted. My sister has a miniature pony named "Weeder". She says it's only job is to eat weeds.
    Hope @Kwikvette isn't triggered by the Army logo (for my nephew and wife). He's liable to wake up surrounded by empty crayon boxes! :stirthepot:
    @koditten I got that eagle's head squared away.
    The "Mitchell Trucki..." will be the bottom half and have a triaxle truck above it. Gotta get a little more time in on the truck.
    I'm happy with all of them. One mistake was Patriots sign outer circle cut was inside instead of outside. $hit happens!
    16 gauge, 30 amps, 40 amp tip, 3200mm(126in)/min, 65psi, .9 kerf width, 1.2mm(0.05") cut height, 1.4mm pierce, .5mm lead-in, 60degree angle
    KojiKP, Zebinator, Drainbung and 2 others like this.
  2. Feb 12, 2023 at 2:45 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Man, I really need to buy some 16 gauge steel now.
    The fortunate thing is, I pay for 16 and receive either 10 or 12.
    The unfortunate thing is, I need 16 now and wish I had passed on the 'upgrade' :rofl:
    Wsidr1, soundman98 and koditten like this.
  3. Feb 12, 2023 at 4:23 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    All art has imperfections. That mess up only gives it character!
  4. Feb 13, 2023 at 4:28 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    @Wsidr1
    @koditten
    Question though I'll try to summarize my experience today.
    Tried cutting 1/4". Keep in mind I've successfully cut 8 gauge, 10 gauge, 12 gauge, and 3/16" before already.
    Had an issue where it couldn't cut my holes out or the entire thing. Facebook group quickly found out my issue as I was using the same 0.6 second pierce delay I've used on all other thicknesses. Changed it to 1.5 second pierce delay, 45 amps, and successfully cut these out -
    Being done with 1/4", I loaded up 3/16" steel to proceed and cut some brackets I've already cut before. Meaning I had NC file already made because again, I've cut them in the past.
    First piece is a success, and cuts like normal -
    Yet the next 3-4 pieces didn't get cut all the way through. They failed in the same way the 1/4" pieces failed to cut.
    Ground is always placed on the work piece (so ground was never an issue on either metal) and I started the day with a new consumable.
    Is this the result of consumable life drastically being used up due to the pierce delay used for 1/4"? It's my only theory as I've cut these pieces out before in the past.
    shakerhood, soundman98 and mjbtaco like this.
  5. Feb 13, 2023 at 4:59 PM
    koditten
    Kirk
    Central Michigan
    Defiantly.
    The slagg/dross is blowing directly back at your tip. It's shortening the life dramatically.
    I've been wanting to program mine to do the wiggle pierce lead in when I get home.
    This vid shows what I mean. I hope I can program mine to do this.https://youtu.be/1twhyl43gas
    Drainbung and Kwikvette like this.
  6. Feb 13, 2023 at 5:04 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Nice!
    I may not ask a lot of questions, but I'm very observant about everything I cut and that video basically told me I was right about my assumption.
    Well I won't cut 1/4" much if at all really. This is just for a customer order on some mounts.
    soundman98 likes this.
  7. Feb 13, 2023 at 5:05 PM
    koditten
    Kirk
    Central Michigan
    Same. I don't cut thick iron much either.
  8. Feb 13, 2023 at 5:06 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Anything vehicle related is 3/16".
    Misc personal stuff varies depending what I've got on hand which speaking of...I need to find out what I'll use my 10 gauge for :rofl:
    Got two 4' x 4' sheets untouched as I've been using the 12 gauge.
  9. Feb 13, 2023 at 5:26 PM
    Shmellmopwho
    Shmellmopwho Well-Known Member Vendor
    Lomita CA
    2013 White DCLB TRD sport
    Bunch of stuff
    Welded these racks into a container today. Took 2.5 hours. $500 cash. Please God can I do 1 or 2 containers per day for 4 or 5 days a week for the same amount? Please??
    KRAMERICA, shakerhood, jubei and 10 others like this.
  10. Feb 13, 2023 at 8:27 PM
    Clark27
    Clark27 Well-Known Member
    Springfield, MA
    2015 Lexus GX460
    Just ended up ordering the WEN 4214T from Home Depot so in a few days we should have a drill press in hand! Have a particular project now that it would be nice to use so I’m excited to get started. Where did you buy the adjustable chuck?
    Kwikvette[QUOTED] likes this.
  11. Feb 14, 2023 at 5:49 AM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    I meant 3/16 plate pieces to the bed frame to bolt to the truck frame. :rofl:
    Bivouac[QUOTED] likes this.
  12. Feb 14, 2023 at 5:50 AM
    Slashaar
    Josh
    Kansas City, MO
    I've never even thought about a surface being too smooth for paint. TIL. Might be why my paint on my bumper is coming off since I grinded it all smooth on the outside. Left the weld on the inside for strength.
  13. Feb 14, 2023 at 5:52 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    uxcell Keyless Drill Chuck MT2 Morse Taper Mount Adjustable 1/32"-1/2" (1mm-13mm) 3-Jaw for Lathes Milling Drilling Machine https://www.amazon.com/dp/B0776QMXMK
    jubei likes this.
  14. Feb 15, 2023 at 5:17 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Delivered the clock today and made money on that.
    Also delivered these today; had cut the tabs yesterday -
    The shop liked them so much that he wants one more set (these are for motor swaps) as well as Dana 80 rear arm mounts.
    Already drew the parts up so I'll cut those tomorrow after school.
  15. Feb 15, 2023 at 5:35 PM
    Wsidr1
    Indiana
    I cut two more of those US Army signs and these NRA Silhouette targets for a friend who shoots in competitions.
    He brought me an old rusty piece of plat that was about 3/8". I cut it at 50 amps, 40ipm, 70psi. Main thing was pierce delay time. I programmed at 0.9 secs but had to increase on the fly after I saw the first piece didn't pierce clean. I bumped it to 1.2 secs and the rest did fine. Needed almost no cleanup. I rarely cut anything this thick, so I was happy to see the good outcome.
    FYI, the arc started fine through the rust.
  16. Feb 15, 2023 at 5:42 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Those are some nice cuts
  17. Feb 15, 2023 at 6:04 PM
    Pyrotech
    Pyrotech Well-Known Member
    The gouging tips showed up today. hopefully I can get the weld removed and get everything aligned properly an rewelded. Least that is the plan for when I get back home this weekend.
  18. Feb 15, 2023 at 7:29 PM
    Shmellmopwho
    Lomita CA
    Bunch of stuff
    Another couple sets of sliders this week
    Pchop, Ozzylara805, la0d0g and 6 others like this.
  19. Feb 15, 2023 at 7:58 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Ordered more electrodes and tips.
    Do you guys replace your tips at the same time as your electrodes for your plasma cutters?
    Going to be cutting some more 1/4" tomorrow.
  20. Feb 15, 2023 at 8:13 PM
    mjbtaco
    mjbtaco low and slow
    Michael
    Montclair , so cal
    Turbo'd 95.5 extra cab and 2013 Silver DCSB TRD Sport
    PERFORMANCE Custom Turbo Setup FRONT SUSPENSION Drop Spindles by Aaron Carswell 01-04 Swaybar Endlinks Energy Suspension Endlink Bushings Cando Upper Control arms QA1 coilovers with 8" spring Custom 4 pot Brembo BBK Modified lower control arms with mjbfab qa1 mounting plates and Poly bushing sleeves REAR SUSPENSION Chasis Tech drop leafs QA1 adjustable shocks weld in drop notch Gas tank cross member bridge 3" angled blocks 2013 Double Cab Short Bed TRD Sport Eibach Pro Truck Shocks front and rear Lifted to the 3rd setting on the front shocks
    Went to weld today and...... womp womp.
