Anything welding
Discussion in 'Garage / Workshop' started by EL TACOROJO, Sep 17, 2010.
  1. Mar 11, 2023 at 9:25 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Is this the before or after picture??
    Hard to tell being they are upside down just how they mount.
    They should attach to the frame.
  2. Mar 11, 2023 at 10:32 AM
    ejwan
    ejwan Well-Known Member
    Finally got my air dryer completed time to disassemble and finish welding off the joints/paint. Then it's time to use it for plasma cutting. Way over kill
  3. Mar 11, 2023 at 10:41 AM
    Bivouac
    Better over kill then not enough!
  4. Mar 11, 2023 at 12:29 PM
    Ozzylara805
    Ozzylara805 Well-Known Member
    Oziel
    Grand Island Nebraska
    2012 trd off-road
    do y’all think the plate is strong enough to support the truck and not bend?
    Zebinator likes this.
  5. Mar 11, 2023 at 1:52 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Tell me you have dry air without telling me you have dry air :drool:
    koditten, Zebinator and ejwan[QUOTED] like this.
  6. Mar 11, 2023 at 3:04 PM
    Bivouac
    Just what are your plans . You can bend anything if you work hard enough.
    Lots of high speed rock bashing where the slider takes the impact of the all the truck weight on a few square inches from a few feet in the air several times in 100'.
    By all means add lots more to strengthen the sliders and the rest of the truck.
  7. Mar 11, 2023 at 6:29 PM
    Zebinator
    Zebinator Well-Known Member
    Norcal
    06 Tacoma TRD Offroad
    Finally, some welds. Lol.
    Making a bracket to mount a digital readout and speed control to my old mill.
    These came out better than I would have expected with no practice/warmup but I’m curious why I get the little pointies in my stack (of not-dimes). Any pointers?
    koditten likes this.
  8. Mar 11, 2023 at 6:57 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Looks like you're whipping your torch too fast; wirespeed can't keep up.
  9. Mar 11, 2023 at 8:04 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    those welds look like all of mine! too fast. take a breath, slow down ;)
    koditten and Zebinator[QUOTED] like this.
  10. Mar 11, 2023 at 8:09 PM
    soundman98
    NW Indiana
    i guess the better question is 'how far are you willing to go?'
    you could gusset all of the short plates extending out from the mounting plate to the rails, but then the question is if the mounting plate is thick-enough/bolted-through-enough/reinforced-enough to deal with the potential extra stress. if things are bending, that force has to go somewhere, and it's very unlikely reinforcing only a singular part of the design will be the result you're looking for.
  11. Mar 12, 2023 at 1:53 AM
    Bivouac
    Just lack of Arc time !
    You need to find your rhythm right toe pause left toe pause front pause repeat .
    The welder output determines the length of your pauses
    In the olden days before the new remote output control changing settings could mean a long walk to the welder to adjust things so one learned to adjust your speed rather then output of the machine.
    Zebinator[QUOTED] and soundman98 like this.
  12. Mar 12, 2023 at 9:30 AM
    Slurmin Furrmen
    Slurmin Furrmen Welder / Fabricator
    Probably
    Northern Colorado
    21 OR DCLB
    Bearing wear
    Long walk?! Its only a 15 feet lead. :rofl:
  13. Mar 12, 2023 at 10:03 AM
    Bivouac
    ha ha ha if only The truck might only have been only 30' away but most of that was straight down.
    Then of course the stairs were 100 yards away .
    It must have been good to get your dues paid !! Cold in the Summer nice and warm in the winter. Fume extractors for every booth .
  14. Mar 14, 2023 at 3:10 AM
    Bivouac
    My thoughts and prayers to all in California Between the Snow and the melt water and the rain.
    I know very many of you are out there.:fingerscrossed::fingerscrossed::amen::welder:
    Shmellmopwho, dk_crew and Kwikvette like this.
  15. Mar 15, 2023 at 10:16 AM
    Shmellmopwho
    Shmellmopwho Well-Known Member Vendor
    Lomita CA
    2013 White DCLB TRD sport
    Bunch of stuff
    Building some rigging bins for someone at work. I will also be building them some chain motor bins. 2 of each.
    la0d0g, soundman98, dk_crew and 5 others like this.
  16. Mar 16, 2023 at 1:13 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Replacing the MIG180; nothing wrong with it, I'm just used to big boy welders
    Power cable, ground cable, everything is beefy as hell
    Big boy torch
    And best of all, I get to go back to 33lb spools
  17. Mar 16, 2023 at 1:25 PM
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    Anyone know where I can get Rex-Cut discs?
    I have a Megabrite finishing flap disc, fine grit, which is now worn out. Great disc, but I can't find any retailers.
    I've looked on their web site - they list the fine grit, but don't allow it to be purchased.
    I wonder if they've stopped production or just have supply chain issues.
  18. Mar 16, 2023 at 2:04 PM
    Bivouac
    Good luck with your new machine!
    Keeping the little one?
    Do the guns interchange ? I have always found it easier to swap guns when going from .023 to .045 rather then liners in the gun. Plus the other assorted parts.
    Kwikvette[QUOTED] likes this.
  19. Mar 16, 2023 at 2:07 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Don't believe the guns interchange since the new machine is larger and pulls more current.
    The rollers are interchangeable though and I can use the spoolgun from my smaller MIG180 with the new setup.
    I'll be getting rid of it though since I already have a Miller that runs dual shield. That and I don't really have room for 3 welders, a plasma cutter, cnc table, and fab table all on one side of the garage :rofl:
  20. Mar 16, 2023 at 2:44 PM
    Bivouac
    Since your selling the MIG180 I just wondered if the guns back ends were the same size.
    No comment on your lack of space:anonymous: You would just use that space as well.
    soundman98 and Kwikvette[QUOTED] like this.
