Anything welding
Discussion in 'Garage / Workshop' started by EL TACOROJO, Sep 17, 2010.
  1. Mar 26, 2023 at 7:44 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Would you believe it's an 18 year old HF bandsaw I got free last year?
    Wasn't even running.
    Posted about it here -
    Fast forward maybe a week or so after that and I got her cutting square -
    MulletTaco, soundman98 and koditten like this.
  2. Mar 26, 2023 at 8:05 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I think he was looking at the bar reading being PSI now that I’ve thought about his explanation when we were checking it out.
    Bivouac[QUOTED] likes this.
  3. Mar 26, 2023 at 8:32 AM
    ejwan
    ejwan Well-Known Member
    I'm a hobbyists at best and I be lucky to even weld or cut once a month. That's why I chose to just give the cheap method a try and also transfer that knowledge into making a cnc router for my wood hobby too. Not hating on crossfire just know that they are entry level compare to what's out there. The jd design is very similar to the one you have too.
    That's it. I'll look into more details once I do a test run. Mainly plan to use it to make tabs and mounting plates. Does mach3 require a cost to use?
    Kwikvette[QUOTED] likes this.
  4. Mar 26, 2023 at 8:37 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    No worries.
    Just wanted to dispell the "buggy" rumor that's repeated by some out there.
    You see it on the Facebook group often and when asked a few questions you quickly find out that they have not only 0 welding experience, but 0 fabrication experience or even any metal work experience whatsoever.
    Fully expecting to just lay a sheet of metal, pressing a button, and poof instant sign. These are the same people that refuse to learn CAD and just buy all their designs off Etsy.
    As far as my work? I'm also just a hobbyist.
    soundman98 likes this.
  5. Mar 26, 2023 at 9:59 AM
    dk_crew
    dk_crew Well-Known Member
    Dave
    Austin, TX
    2005 Tacoma 4x4
    That’s awesome - love bringing older stuff back to life.
  6. Mar 26, 2023 at 6:24 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Retired Hobbyist but if you get any compensation you lose your hobby status !!
    I never learned CAD it was after my school days I learned Mechanical Drawing !
    I no doubt could pick it up if I really needed .
  7. Mar 26, 2023 at 9:25 PM
    ejwan
    I been going at it a bit more on my dump trailer build for once and it got me wondering I can have my life so much easier cutting the 3/4 plates with a table. It's easy enough to free hand for now but having a table would be nice for future cuts. I been holding off on the build since i dreading thinking about fabing the hydraulic mounting plates.
    Welding upside down was interesting with gravity.
  8. Mar 27, 2023 at 2:50 AM
    Bivouac
    Do you mean 3/4" plate going to need a decent output plasma machine 80 amps plus
    Kwikvette and koditten like this.
  9. Mar 27, 2023 at 5:35 AM
    ejwan
    No the Hypertherm 45 handle it just fine. I never had plasma experience and after reading about needing clean dry air and how much volume it takes I had to address that first. Ended up with a refrigerate dryer in addition the the dissicant plus another air compressor. Just a very long rabbit hole. I just didn't know any better until doing it.
  10. Mar 27, 2023 at 7:08 AM
    mjbtaco
    mjbtaco low and slow
    Michael
    Montclair , so cal
    Turbo'd 95.5 extra cab and 2013 Silver DCSB TRD Sport
    PERFORMANCE Custom Turbo Setup FRONT SUSPENSION Drop Spindles by Aaron Carswell 01-04 Swaybar Endlinks Energy Suspension Endlink Bushings Cando Upper Control arms QA1 coilovers with 8" spring Custom 4 pot Brembo BBK Modified lower control arms with mjbfab qa1 mounting plates and Poly bushing sleeves REAR SUSPENSION Chasis Tech drop leafs QA1 adjustable shocks weld in drop notch Gas tank cross member bridge 3" angled blocks 2013 Double Cab Short Bed TRD Sport Eibach Pro Truck Shocks front and rear Lifted to the 3rd setting on the front shocks
    New purge plugs for a future project
  11. Mar 27, 2023 at 7:38 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Yeah I didn't know what 3/4 plates were; makes sense.
    Fortunately a lot can hit that capacity. My chinese machine can do 7/8" plate, but many do 1" even.
    Hypertherm rates their machines conservatively as they cut thicker than they're rated for.
  12. Mar 27, 2023 at 8:55 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Welding overhead is easy!
    Plasma cutting overhead for me is where it gets interesting; was cutting overhead yesterday and I got some burn marks on my hoodie.
    Ricardo13x and Bivouac like this.
  13. Mar 27, 2023 at 8:59 AM
    Bivouac
    When you weld or cut at least one time you sooner or later will need to explain those interesting burns in the area of the family jewels .
    That look like something really nasty encountered while exploring .
  14. Mar 27, 2023 at 9:03 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Oh man...not looking forward to that one!
    I make sure to wear the 3350 hood for anything overhead; it protects against any slag, etc.
    I can't say the same for the 1740 hood (haven't bothered to read the specifications) but it's made of the same shell material as my friend's Miller that is not rated for anything overhead so why chance it?
    I've got a burn mark (permanent) that's on my tattoo...but on the lightly shaded part not the dark line fortunately.
    Just adds character right?
    I'm sure you've got a ton of burns.
  15. Mar 27, 2023 at 9:05 AM
    Bivouac
    Though most them when attempting to cook!:anonymous:
    Delta09 and Kwikvette[QUOTED] like this.
  16. Mar 27, 2023 at 9:08 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I would've taken you for a bonafide chef!
    My goods are nothing to brag about, but I have made contributions to the other threads (regarding baked goods).
  17. Mar 27, 2023 at 9:43 AM
    Bivouac
    Perhaps exhaust manifold cooking ! over a fire ! Big Chunks of meat!
    Now I am hungry!!
  18. Mar 27, 2023 at 4:55 PM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    Found a cut ready file with even MORE good advice!
    Pchop, KRAMERICA, RustyGreen and 5 others like this.
  19. Mar 27, 2023 at 4:57 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I saw that one! Almost got it for myself :rofl:
    Wsidr1[QUOTED] likes this.
  20. Mar 27, 2023 at 10:02 PM
    HCFab
    HCFab Hudson Custom Fabrication
    Zach
    Central Idaho
    Overland 04' v6 4x4 5spd Xtracab, Lunar Mist.
    On the hunt for a (lightly used/abused) small AC/DC TIG & ARC welder in Texas. Would I be happy with the "good" China boxes like the Vulcan Protig 205 or a Yeswelder? I'd buy a Lincoln/miller/hobart for the right price, but who has 3k+ to spare right now?
    I weld on a Miller every day, I can run a decent dime stack on the boss's 250DX, but I'm saving a little cash to start up a side hustle and get my personal tools up to scratch be more independent. Let me know if anyone who welds/fab privately has any advice on how they got started. I'm all ears.
    KRAMERICA and Bivouac like this.
