Anything welding
Discussion in 'Garage / Workshop' started by EL TACOROJO, Sep 17, 2010.
  1. May 4, 2023 at 3:02 PM
    mjbtaco
    mjbtaco low and slow
    Michael
    Montclair , so cal
    Turbo'd 95.5 extra cab and 2013 Silver DCSB TRD Sport
    PERFORMANCE Custom Turbo Setup FRONT SUSPENSION Drop Spindles by Aaron Carswell 01-04 Swaybar Endlinks Energy Suspension Endlink Bushings Cando Upper Control arms QA1 coilovers with 8" spring Custom 4 pot Brembo BBK Modified lower control arms with mjbfab qa1 mounting plates and Poly bushing sleeves REAR SUSPENSION Chasis Tech drop leafs QA1 adjustable shocks weld in drop notch Gas tank cross member bridge 3" angled blocks 2013 Double Cab Short Bed TRD Sport Eibach Pro Truck Shocks front and rear Lifted to the 3rd setting on the front shocks
    Welding and grinding PPE day.
  2. May 4, 2023 at 3:17 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Always important; cut stuff on the CNC today for a buddy and I was like here...you'll need these :rofl:
    mjbtaco[QUOTED] and Drainbung like this.
  3. May 4, 2023 at 3:20 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I gotta where earplugs plus ear muffs when I use mine.
    Drainbung and Kwikvette like this.
  4. May 4, 2023 at 7:56 PM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    I have the certiflat table (same I have on hold for you) and when I’m using it as a fixture, I’ll occasionally get too close to the table and give it a little zap. Doesn’t happen all the time, but it happens.
    Kwikvette[QUOTED] likes this.
  5. May 4, 2023 at 8:13 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    You have no idea how much I'm looking forward to using that thing.
    Just got my finger brake today.
  6. May 4, 2023 at 8:16 PM
    GHOST SHIP
    GHOST
    I might be heading to Pinnacles NP later this month. We could meet up somewhere close to you if it pans out.
    Zebinator and Kwikvette[QUOTED] like this.
  7. May 4, 2023 at 8:17 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I've got your number, I'll keep you updated.
    Still waiting on my wife to get better :fingerscrossed:
  8. May 4, 2023 at 9:32 PM
    mjbtaco
    Michael
    Montclair , so cal
    Sandwich mounts for my compressor and air tank. Installing air cups on my daily to get 2" of lift when entering driveways while still retaining my coilovers.
  9. May 4, 2023 at 10:50 PM
    GHOST SHIP
    GHOST
    How well does that mask hold up to grinding sparks? Or is it more of a “use it in till you can’t see shit and get another one” deal?
  10. May 4, 2023 at 11:11 PM
    mjbtaco
    Michael
    Montclair , so cal
    I'll let you know. First time trying it. They do sell the replacement lenses though
  11. May 5, 2023 at 12:22 AM
    GHOST SHIP
    GHOST
  12. May 5, 2023 at 12:23 AM
    GypSeafreak
    GypSeafreak New Member
    There are so many people on all these forms telling people how to do the wrong thing. If you need to just weld basic stuff just get a MIG. Make sure whatever your welding has been cleaned and fresh metal is present. If you're well looks like bubbles on top of the metal then you did not penetrate. You want it to look like a roll of dimes. Thinner the metal lower the speed lower the heat. Thicker the metal turn that heat up. Mess with the heat and speeds, practice makes perfect, good luck. Don't listen to people that try to sound smarter than they are.
  13. May 5, 2023 at 3:39 AM
    sdk1968
    sdk1968 Well-Known Member
    03 Taco TRD
    gonna sub to this thread & go back to the start & work my way thru it over the coming days/weeks.
    my welding is ugly... but it holds. looking to improve & gain some tips.
    note: im a jittery, hyper person who doesnt have steady hands. LMAO
    soundman98 likes this.
  14. May 5, 2023 at 4:33 AM
    koditten
    Kirk
    Central Michigan
    We must be lost brothers.
    Welcome!
    spencermarkd and Kwikvette like this.
  15. May 5, 2023 at 8:28 AM
    Zebinator
    Zebinator Well-Known Member
    Norcal
    06 Tacoma TRD Offroad
    Wife and I were talking about heading down there and maybe over in to the back of Big Sur, too, but it looks like tons of roads and camps are still closed (through June!) What a winter we've had. oof!
    GHOST SHIP[QUOTED] and Drainbung like this.
  16. May 5, 2023 at 8:29 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Tons of BLM out there.
    Actual camp spots have to be reserved months in advance; I used to live out there for over 11 years.
    Drainbung and Bivouac like this.
  17. May 5, 2023 at 8:39 AM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    forewarning, i'm just an idiot in my garage banging on stuff until it sticks together with a flux core:
    it really depends on what you're doing. my understanding is that mig is going to be more 'do-anything'(weld a frame, then maybe some body panels), where tig is more for precision/thin-wall stuff, or for metals other than steel or aluminum, where you can change the filler rod used. you can weld most things with mig other than thin materials, but it's less common to tig high-thickness materials.
    if cost is not a major factor, and you have 220v in your work area, i would highly recommend mig welder, with spool gun attachment. it would get you out of most situations you can put yourself into. worst case, you find out how expensive new argon tanks are, and you can just run a flux core welding wire like i do. flux core really only means extra spatter that needs to be cleaned up. it can be partly mitigated by using anti-spatter, but there's still more cleanup than when using shielding gas.
  18. May 5, 2023 at 8:58 AM
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    I'm far from being an expert, but I'd vote for MIG or maybe a combo machine with STICK. If it's windy where you live, use flux-core. If you can set up a canopy with some side walls to block most of the wind, then gas should work fine. STICK works almost anywhere on anything, but it's messy.
    Taco47[QUOTED] and soundman98 like this.
  19. May 5, 2023 at 9:01 AM
    koditten
    Kirk
    Central Michigan
    IO really like that post.
    I have been a proponent of MIG from the start. My MIG welder has made me a lot of folding money over the years.
    Don't get me wrong, there is a bit of beauty seeing a colorful, perfect TIG weld, but I prefer to look at naked ladies when I want porn, not welds. Everyone has their tastes.
  20. May 5, 2023 at 9:17 AM
    mjbtaco
    Michael
    Montclair , so cal
    GHOST SHIP[QUOTED] likes this.
