Anything welding
Discussion in 'Garage / Workshop' started by EL TACOROJO, Sep 17, 2010.
  1. May 8, 2023 at 6:57 PM
    mjbtaco
    mjbtaco low and slow
    Michael
    Montclair , so cal
    Turbo'd 95.5 extra cab and 2013 Silver DCSB TRD Sport
    PERFORMANCE Custom Turbo Setup FRONT SUSPENSION Drop Spindles by Aaron Carswell 01-04 Swaybar Endlinks Energy Suspension Endlink Bushings Cando Upper Control arms QA1 coilovers with 8" spring Custom 4 pot Brembo BBK Modified lower control arms with mjbfab qa1 mounting plates and Poly bushing sleeves REAR SUSPENSION Chasis Tech drop leafs QA1 adjustable shocks weld in drop notch Gas tank cross member bridge 3" angled blocks 2013 Double Cab Short Bed TRD Sport Eibach Pro Truck Shocks front and rear Lifted to the 3rd setting on the front shocks
    I had a jazzy 10 clear lense that I never used and dropped it off my table last week lol
    Slurmin Furrmen likes this.
  2. May 8, 2023 at 6:58 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Oof...it's cool and all but I'm good with a regular cup
  3. May 8, 2023 at 6:59 PM
    mjbtaco
    Michael
    Montclair , so cal
    I dont have a spool gun. Just ac/dc tig and mig.
  4. May 8, 2023 at 7:01 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Dammit, was hoping you'd make one.
  5. May 8, 2023 at 7:09 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    My mistake. You mentioned Argon tank and I assumed it was for aluminum welding with a spool gun. I apologize.
    mjbtaco[QUOTED] likes this.
  6. May 8, 2023 at 7:19 PM
    mjbtaco
    Michael
    Montclair , so cal
    Material is too expensive lol I'm poor
    soundman98 likes this.
  7. May 8, 2023 at 7:21 PM
    mjbtaco
    Michael
    Montclair , so cal
    A little start to finish of another set of blocks I just made.
    Kwikvette likes this.
  8. May 8, 2023 at 7:24 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Material really that expensive there?
  9. May 8, 2023 at 7:33 PM
    mjbtaco
    Michael
    Montclair , so cal
    If I were to build something the way I wanted it I'd probably be in it like $350-$400 just in materials. I bought 5' of 2x5 rectangle tube a couple weeks ago and it was $96.
  10. May 8, 2023 at 7:50 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Dang, super fancy cart setup I take it?
  11. May 8, 2023 at 7:56 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    @mjbtaco what do you prefer to sharpen your tungsten with?
    At school I just used a grinding wheel/tool but at work they let us use a dedicated grinder.
  12. May 8, 2023 at 8:04 PM
    Slurmin Furrmen
    Slurmin Furrmen Welder / Fabricator
    Probably
    Northern Colorado
    21 OR DCLB
    Bearing wear
    :annoyed:
    R.I.P.
    Same. I have never been a fan of the glass lenses.
    The BBW, SSBBW, Fupa, and MK, on the other hand, are worth it.
    I thought they were snake oil, honestly, until I broke down and tried them this winter. I am now a believer.
  13. May 8, 2023 at 8:06 PM
    mjbtaco
    Michael
    Montclair , so cal
    I have a dedicated Milwuakee rotary tool with this attachment I found on Amazon. Works perfect and doesn't cost too much.
    3mirrors ALUMINUM Tungsten... https://www.amazon.com/dp/B08F9YBCL2?ref=ppx_pop_mob_ap_share
  14. May 8, 2023 at 8:10 PM
    Slurmin Furrmen
    Probably
    Northern Colorado
    21 OR DCLB
    Bearing wear
    If you have any other furick gear you dont use, I am always accepting donations.
    :D
    soundman98 and mjbtaco[QUOTED] like this.
  15. May 8, 2023 at 8:13 PM
    mjbtaco
    Michael
    Montclair , so cal
    Lol I just never got the chance to try it. Fail haha
    I just got his torch holder a couple weeks ago
  16. May 8, 2023 at 8:32 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Oooh...ok I'm totally just going to draw that and cut one out myself.
    mjbtaco[QUOTED] and koditten like this.
  17. May 8, 2023 at 8:48 PM
    Shmellmopwho
    Shmellmopwho Well-Known Member Vendor
    Lomita CA
    2013 White DCLB TRD sport
    Bunch of stuff
    Finally started making sliders for Tundras
    Installed the first set today. Pretty similar to a DCLB Tacoma just more support and different leg/frame mounting positions
  18. May 8, 2023 at 9:50 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    We had something similar, but costing way more than that.
    Ordered thanks.
    Now to pick up that tool at Home Depot; they've got a free battery and charger thing going on so it looks like returning it will get me back $44 bucks.
  19. May 9, 2023 at 10:33 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    @mjbtaco this will be my first and only non-Fuel Milwaukee so hope it lasts! Bought it cause you recommended it :rofl:
    Just need to wait for the battery-charger combo to arrive so I can return them. Makes this a $54 tool after the refund.
    soundman98 and mjbtaco like this.
  20. May 9, 2023 at 12:39 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Good Luck !! I have been using a dedicated grinding wheel for years .
    If I was going to do more Tig i might get one of those fancy tools.
    Kwikvette[QUOTED] likes this.
