Anything welding
Discussion in 'Garage / Workshop' started by EL TACOROJO, Sep 17, 2010.
  1. Aug 11, 2023 at 1:26 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Cut order from 1 - 8.
    Small bracket # 7 exhibited a slight jaggedness in the inner circle.
    Larger bracket exhibits the same jaggedness inside as well as a tiny bit on the outside.
    Drainbung likes this.
  2. Aug 11, 2023 at 3:19 PM
    Tacman19
    Tacman19 Well-Known Member
    Dave
    Mid Missouri
    19 Tacoma SOLD
    As many as I can fabricate
    Looks like a man's face and he's got a really bad headache in one eye. If I get time I'll sketch it out.
    Zim
  3. Aug 11, 2023 at 4:38 PM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
  4. Aug 11, 2023 at 4:57 PM
    soggyBottom
    soggyBottom Well-Known Member
    Can someone recommend a bender for DOM tubing? This is strictly for hobby projects so I can't justify spending thousands. On the other hand, I'm not going to just throw money away buying garbage.
  5. Aug 11, 2023 at 4:59 PM
    soggyBottom
    I really like metal art. This reminds me of a topographical map. CNC wood topo maps sell for crazy amounts of money on Etsy. I can't imagine what a metal one could sell for.
  6. Aug 11, 2023 at 11:24 PM
    mjbtaco
    mjbtaco low and slow
    Michael
    Montclair , so cal
    Turbo'd 95.5 extra cab and 2013 Silver DCSB TRD Sport
    PERFORMANCE Custom Turbo Setup FRONT SUSPENSION Drop Spindles by Aaron Carswell 01-04 Swaybar Endlinks Energy Suspension Endlink Bushings Cando Upper Control arms QA1 coilovers with 8" spring Custom 4 pot Brembo BBK Modified lower control arms with mjbfab qa1 mounting plates and Poly bushing sleeves REAR SUSPENSION Chasis Tech drop leafs QA1 adjustable shocks weld in drop notch Gas tank cross member bridge 3" angled blocks 2013 Double Cab Short Bed TRD Sport Eibach Pro Truck Shocks front and rear Lifted to the 3rd setting on the front shocks
    Holy fuck I suck at aluminum. Not even gonna post close ups lmao
  7. Aug 12, 2023 at 12:18 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Yeah...with the exception of using my spoolgun just some weeks ago, I don't TIG aluminum anymore.
    Last time I TIG welded aluminum -
    You have to move quickly and you need to pull your filler out your puddle; too far though and it gets contaminated damn near instantly.
    mjbtaco[QUOTED] likes this.
  8. Aug 12, 2023 at 12:26 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    No welding, but we post our CNC stuff here anyway.
    Another member made his own skid, having used foam board as his template. With no CAD or CNC experience, I brought his template to life and created a cut file for him to offer.
    He actually has a logo, and although he didn't request to have it added, I did it for him anyway.
    soundman98, Pyrotech and dk_crew like this.
  9. Aug 12, 2023 at 12:42 AM
    mjbtaco
    Michael
    Montclair , so cal
    That's alor better than what my shit looks like lol
    Kwikvette[QUOTED] likes this.
  10. Aug 12, 2023 at 12:49 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    You already know how to TIG weld, so aluminum will come easy to you.
    Need to treat it like you're robbing a bank; bring the heat and hit it fast.
    Longer you stick around, worse it gets.
    You'll want more heat than you think you do cause you want to penetrate that oxide layer right away to start welding; that layer has a higher melting point than aluminum itself.
    Going too low on the heat will only cause your work piece to heat soak, and by the time that oxide layer melts....everything else goes with it and your puddle ends up wide AF or buring right through.
  11. Aug 12, 2023 at 1:32 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Used Aluminum is all most impossible to get clean.
    Making good welds impossible.
    sometimes you can adjust the balance to get better cleaning action in the arc.
    Then the output of the machine it is a fine line between to cold and to hot. A nice puddle going right along then it all just falls.
    Practice /practice The best Aluminum welders for the most that is all they do.
    koditten likes this.
  12. Aug 12, 2023 at 7:09 AM
    Tacman19
    Dave
    Mid Missouri
    19 Tacoma SOLD
    There is really no "in between" It's $2000 or nothing. Tubing must me "drawn through with a heavy duty die and that's expensive. Otherwise it will wrinkle and collapse as you press down on it. Nothing harbor fright will do tubing. (even brake lines) LMAO. Hossfeld makes a good manual bender but it will kink also.
    Zim
  13. Aug 12, 2023 at 7:34 AM
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    Looks good!
    Make sure he wants you to add a logo. I wouldn't want one cut out of a skid as it would just help it fill up with mud :rofl:
  14. Aug 12, 2023 at 7:45 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    :rofl:
    We were texting back and forth; he was happy about the whole thing and when I asked about a logo, apparently he already had one. He had just lost his DXF file and would've wanted it used but said not to worry.
    Recreated it and he was stoked to have it on there.
    Granted, anyone using that file to cut that skid out would most likely have enough knowledge of how to remove the logo from their cut path.
  15. Aug 12, 2023 at 7:47 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    As mentioned, gotta spend money.
    JD Fab or Swag Offroad at the very least.
    Quality dies alone are in the 300-500 each.
  16. Aug 12, 2023 at 11:50 AM
    mjbtaco
    Michael
    Montclair , so cal
    I'll stick to steel lol
    soundman98, Bivouac, dk_crew and 2 others like this.
  17. Aug 12, 2023 at 12:13 PM
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    :rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl::rofl:
    Drainbung[QUOTED] likes this.
  18. Aug 12, 2023 at 12:58 PM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    All I know is I’m a lot cleaner at the end of a 10.5-12.5 hour day welding aluminum than I was welding steel ha.
    koditten, soundman98 and Bivouac like this.
  19. Aug 12, 2023 at 7:11 PM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    I finished paint on a few football helmets and cut some Grateful Dead bears and Harley signs. Dead Heads love the bears as they are from the 1st album cover.
    I paint them purple.
    koditten, Vmax88 and Drainbung like this.
  20. Aug 13, 2023 at 8:27 AM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    really looks to me like a computer issue.
    it's a rather large file, and other portions are cut correctly. almost like the steppers aren't getting the right signal at the right time to move.
