Anything welding
Discussion in 'Garage / Workshop' started by EL TACOROJO, Sep 17, 2010.
  1. Aug 25, 2023 at 8:31 PM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    I'm not happy with this at all, WTF...
  2. Aug 26, 2023 at 1:15 AM
    Speed Freek
    Speed Freek Tacoma Whisperer!
    Vista, Ca, Lake Havasu, Az.
    98 Tacoma V8 (LS1) swap
    LS1-T56 swap, Z06 ported heads, cam, Titanium valves, Kevlar clutch. Now building a forged stroker (383) and all the ponies! Old setup was rod-knockin on heaven's door...
    Fair is relative I suppose, its the prep and fitting that make the weld strong all things considered, as long as the installer/welder knows how to get full pen welds, etc.. Also when doing a CMR it is very important to make sure you lift that corner of the truck up and place the new mount where it needs to be, I have seen a bunch of these setup improperly and the front end ended up sagging and the door gap tightens toward the bottom since they didn't preload the new mount by placing it high enough unfortunately.
    If you are doing structural things its probably best to let an actual welder do it when it comes to critical things like this where strength is very important, but I still think you should get a welder and learn as well, once you feel comfortable you would be surprised how much of a benefit knowing how to weld is, opens a lot of doors if you are a person that likes to modify things, really cool knowing how to glue metals together..
    Here are a couple things for example you do.
    I'd vote for tack welding a few spots around the edge of the opening, metal etch any bare metal and then seam sealer afterward, and then body color paint if you want to go that far....
  3. Aug 26, 2023 at 2:25 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    I can`t call this one since I never touched a lego if the instructions were good no problem.
    Though I am used to working from prints.
    Depending on my mood I might just get up and leave.
    soundman98[QUOTED] likes this.
  4. Aug 26, 2023 at 6:30 AM
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    Thanks everyone who commented.
    This was my thought, as well, and I appreciate your response. I'll tack enough filler panels for the shifter boot bracket to sit level, get it all down to clean bare metal, prime, add seam sealer and paint-match with the Silver Sky Metallic 1D6 I already have on hand for where I added the clutch pedal.
    I finally found a pic of the stock 6spd trans tunnel and probably shouldn't overthink it too much.
  5. Aug 26, 2023 at 6:56 AM
    soggyBottom
    soggyBottom Well-Known Member
    I want to link my 3rd gen. I've never built links before. I think I want to use the front leaf mounts as a mounting point for the links.
    Rough stuff has a 3 link kit which has everything accept for the DOM, coilovers, and buckets, for $860. Should I take a different route, or is this a good place to start?
    https://www.ruffstuffspecialties.com/3LINKKT.html
  6. Aug 26, 2023 at 7:32 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I'd take those questions to the solid axle swap thread.
    Bivouac and koditten like this.
  7. Aug 26, 2023 at 7:34 AM
    soggyBottom
    Just to be clear, I'm not looking to link the front, I'm looking to link the rear.
    koditten likes this.
  8. Aug 26, 2023 at 7:39 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Gotcha, I still stand by it.
    Suspension thread will take care of ya.
    I say this because sure, a custom link setup requires welding and fabrication however, it's more fab work than anything. That and using calculators to figure out exact mounting points and link lengths to utilize as much travel as possible.
    A ton of people that have done custom link setups and other sort of similar work, aren't welders by trade. Nope.
    In fact, many of them aren't and simply picked up welding along the way as a hobby meaning most of them with experience with custom links don't even post here. I've seen some badass link setups with not-the-best welds but as long as it held together, that's all that mattered.
    Their work wasn't technical in a welding sense, calling for root passes and capping, etc like you would see mentioned here. Or what machine and difference between rods and uses, etc.
    We are on a truck forum, but I bet in this thread there are just as many people with stock trucks than there are custom.
    Just curious, why do you want to link the rear? Are you going to SAS the front?
    Bivouac, soundman98 and Drainbung like this.
  9. Aug 26, 2023 at 8:13 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  10. Aug 26, 2023 at 9:14 AM
    Caboose117
    Caboose117 foul mouthed Marine
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    smashed this, broke that, covered it up with tape and paint
    soggyBottom[QUOTED] likes this.
  11. Aug 26, 2023 at 9:34 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Just PM him
  12. Aug 26, 2023 at 4:48 PM
    mjbtaco
    mjbtaco low and slow
    Michael
    Montclair , so cal
    Turbo'd 95.5 extra cab and 2013 Silver DCSB TRD Sport
    PERFORMANCE Custom Turbo Setup FRONT SUSPENSION Drop Spindles by Aaron Carswell 01-04 Swaybar Endlinks Energy Suspension Endlink Bushings Cando Upper Control arms QA1 coilovers with 8" spring Custom 4 pot Brembo BBK Modified lower control arms with mjbfab qa1 mounting plates and Poly bushing sleeves REAR SUSPENSION Chasis Tech drop leafs QA1 adjustable shocks weld in drop notch Gas tank cross member bridge 3" angled blocks 2013 Double Cab Short Bed TRD Sport Eibach Pro Truck Shocks front and rear Lifted to the 3rd setting on the front shocks
    A couple projects this weekend. Shelf frames for my cousin. And....blocks lol
    Bivouac, Tacman19, Dalandser and 5 others like this.
  13. Aug 26, 2023 at 7:20 PM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    I decided a few days ago to stop using my Asus laptop for cutting with my CNC table. Too much metal dust in the air to risk this $1600 laptop. Thursday, I ordered a mini PC, monitor, and mounting arm. Got it setup tonight. Haven't used it yet. Will update tomorrow with specs if all goes well. Great repurpose for my old HF welding table.
    Also finished up painting a couple more Grateful Dead 1st album cover tribute items I will offer up at a craft fair in September. I am accumulating signs for two fairs at the end of Sept.
    Update:
    Here is what I bought:
    PC
    https://www.amazon.com/dp/B09HC73GHS?ref=ppx_yo2ov_dt_b_product_details
    Monitor
    Amazon.com: SANSUI Monitor 22 inch 1080p FHD 75Hz Computer Monitor with HDMI VGA, Ultra-Slim Bezel Ergonomic Tilt Eye Care LED Display for Home Office (ES-22F1 HDMI Cable Included) : Electronics
    Stand
    https://www.amazon.com/dp/B081YBBXYL?ref=ppx_yo2ov_dt_b_product_details
    KB
    Amazon.com: Lovaky MK98 Wireless Keyboard, 2.4G Ergonomic Wireless Computer Keyboard, Enlarged Indicator Light, Full Size PC Keyboard with Numeric Keypad for Laptop, Desktop, Surface, Chromebook, Notebook, Black : Electronics
    Total cost $250 plus taxes.
  14. Aug 26, 2023 at 8:19 PM
    soggyBottom
    What is that white box with the red and black tubes/cables coming out of the top?
  15. Aug 26, 2023 at 8:58 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Refrigerated air.
    Bivouac, Wsidr1 and koditten like this.
  16. Aug 27, 2023 at 8:53 AM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    i've tried a few of those mini pc's. everyone pushes for the celeron-based and/or i3/i5 models because they're cheaper. i've had nothing but issues for even something as simple as streaming a youtube video with anything smaller than an i7 with 8gb ram. i blame modern software... though it seems it's mostly the graphics processing, as rendering or outputting decent video takes either a dedicated graphics with a lower power processor, or a better processor that can take on some of the graphics processing.
    Wsidr1[QUOTED] likes this.
  17. Aug 27, 2023 at 9:17 AM
    Wsidr1
    Indiana
    I hear you, but I have no high expectations for this mini. Just wanting it to run the CNC software, which other users have said it does without issue. My Asus is I7. It was sold by Republic of Gamers and is setup pretty well. Too well to keep exposing to metal dust.
    PC
    Monitor
    Stand
    KB
    Again, just for my CNC work. I just finished the setup. It went smoothly and everything is working, including my CNC controller.
    For $250 and taxes, I'm happy with what it does, which is run my CNC controller and most importantly, keep me from taking my Asus out to the garage.
  18. Aug 27, 2023 at 9:23 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Yeah you'll be fine.
    I run my old laptop with Fusion, Firecontrol, browse the forums, and stream all at the same time without issue.
    Even if not running a dedicated GPU, one does not and would not need an I7 as that's completely overkill. At that point I'd blame the end user for ensuring resources aren't being hogged by bloatware and other programs.
    My Lenovo is years old, full of metal dust, and is never shut off only put in stand-by mode as I just shut the display. I wouldn't bother to say one would even need anything more than an I3 (if going Intel).
  19. Aug 27, 2023 at 10:05 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    @Wsidr1
    Have to say, I really like how compact that whole setup is behind the monitor
    Wsidr1 likes this.
  20. Aug 27, 2023 at 1:17 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Almost 9 months of use, I figured I'd flip the slats over but first I needed to knock off some slag so they seat correctly
    One of them didn't want to seat, so check out all the gunk I removed just from the area between the two slats
    I went ahead and also squared up my gantry tube once more, but also set the preload again on my bearing blocks
    From one end of the table
    To the other
    She's back to new
    Fulfilling 4 orders, but I still noticed the tiniest bit of beveling (extremely minor) which tells me I need to reset my torch cut height in my programming once I figure out the actual height from the work piece
    That's for a different day
    Have to say, I'm loving the new eyepro my friend surprised me with delivered right to my doorstep; 100 times better than the Milwaukee eyepro I regularly use
    Also since we were all talking about computers, the old laptop I use in the garage for Fusion, Firecontrol, streaming, and web browsing
    koditten, Drainbung and KRAMERICA like this.
