Anything welding
Discussion in 'Garage / Workshop' started by EL TACOROJO, Sep 17, 2010.
  1. Sep 6, 2023 at 4:36 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I'm no wood worker so let's see if I don't fuck up the wood top :anonymous:
    Bivouac, Drainbung and koditten like this.
  2. Sep 6, 2023 at 4:40 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    It's no different than metal fabrication. Wood work is the same. You cut the piece too short, you just glue it back together...it just takes longer...
    Drainbung likes this.
  3. Sep 6, 2023 at 4:48 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I have no intention of buying tools either :bananadead:
    At least not a router which I need so I'll just file a radius/corner down with hand files
  4. Sep 6, 2023 at 4:51 PM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
  5. Sep 6, 2023 at 4:51 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Speak for yourself!
    I am only allowed to touch wood to burn or get tossed into the dumpster.
    Kwikvette likes this.
  6. Sep 6, 2023 at 4:53 PM
    SamSpade
    SamSpade Well-Known Member
    Rob
    Riverside, CT
    White ‘01 4x4 2.7L 5M
    Hey guys, I would like to learn to weld for my own personal projects. Been looking at community colleges, adult education programs, trade schools, YouTube, Khan Academy, etc. I’m in southwest Connecticut very close to I-95 and the NY border. Any recommendations?
    Initially, I have two simple projects to accomplish. But once I get going, I’m sure I’ll find many more.
    (The projects are
    1. Weld in a couple of pieces of angle iron support for the backyard skid plate my buddy @Arcticelf helped me with last year.
    2. Cut 1.5” off the ends of my All-Pro tube bumper and reseal where the tires hit at full lock / compression)
    After some initial research I think a MIG welding machine would be best for my needs. I’m pretty good with mechanical stuff, so I’m confident I could learn to be a decent welder.
    Would love to find a local shop to do this with. Saw the post about the Eastland stores and their Saturday workshops, but the closest one is about 90 minutes away. Would be totally awesome if a TW member somewhere nearby would be open to spending a few hours with me here and there in exchange for beer, but that’s probably a long shot!
    Thoughts & recommendations?
    Thanks!
  7. Sep 6, 2023 at 4:54 PM
    koditten
    Kirk
    Central Michigan
    Yeah. I hate it too. Unfortunately my wife knows I'm good at it.
  8. Sep 6, 2023 at 6:27 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    my thoughts?
    buy a welder. get some steel to play with--scrap or new, doesn't matter. some welders come with a 'what went wrong' card for what the weld that should look like:
    many will also have a metal gauge vs. settings reference guide on the inside cover to get baseline settings dialed in.
    play with sticking together the metal and getting the speed and settings close--it's much more your rythm that sets the quality than the machine settings in many cases-- as long as the settings are close, they'll fly.
    build up your confidence with that, then find a stupid/insignificant but structurally-worthwhile project to further build your confidence before moving onto the projects you really want to use it for.
    in my case, it was a flag pole for the truck. i don't ever use it. 5' of 1/2" IMC conduit, and some chain links cut in half.
  9. Sep 6, 2023 at 6:43 PM
    SamSpade
    Rob
    Riverside, CT
    Okay. Any recommendations on welding machine brands? I’ve seen MIG machines going for $200 - $4000. I’d like to spend on the lower end of that range.
  10. Sep 6, 2023 at 7:04 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    PrimeWeld MIG180
    Welcome25 for your coupon code
    Send me a pack of your favorite hazy IPA as you'll thank me later
  11. Sep 6, 2023 at 7:16 PM
    soundman98
    NW Indiana
    i'd be remiss if i didn't suggest looking at primeweld!-- either the 160 or 180 should suit your needs just fine.
    i personally use an eastwood 90 for little home projects, and at work, use a lincoln 225. the eastwood definitely has some quirks that nicer welders don't exhibit, but i had it before i had heard of primeweld...
    SamSpade and Drainbung like this.
  12. Sep 6, 2023 at 7:39 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Having used everything from a transformer-based, 3 phase Miller CP to single phase Miller 350P's and many things in between, I can say without a doubt that a PrimeWeld 180 will last you for awhile.
    I only got rid of mine because I have a Miller that's more compact, and my larger machine is a PrimeWeld 285.
  13. Sep 6, 2023 at 11:01 PM
    kylehorvath
    kylehorvath Well-Known Member
    Kyle
    Humboldt/Tuolumne/Stanislaus
    2007 Access Cab, 4x4
    Over GVWR and I keep adding more metal
    An alternator-powered mobile-welder would be clutch in the Black Rock Desert right now
    koditten and Drainbung like this.
  14. Sep 6, 2023 at 11:13 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Two batteries, cables, stinger, some 7018 rod and a shade 10 lens is all you need
  15. Sep 7, 2023 at 3:24 AM
    Bivouac
    Happy Birthday @Kwikvette !!
    You made it another year.
    SamSpade and Kwikvette[QUOTED] like this.
  16. Sep 7, 2023 at 6:10 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Thanks!
    Feels even more rushed each and every year :rofl:
    Bivouac[QUOTED] and Drainbung like this.
  17. Sep 7, 2023 at 6:48 AM
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 OR DCFB
    Fox and Locked suspension 63's Skinny 33's
    Id also recommend the PW Mig 180. They have the best customer service I have ever seen. I bought one never mig welding before (only a few hours tig welding and a bit of fluxcore with a HF shitbox) and found it super easy to use and setup.
  18. Sep 7, 2023 at 7:03 AM
    Bivouac
    Being the Tacoma World Prime Weld Sales Person.
    I think you should be getting demo machines to review . Is that a Good idea?
    soundman98 and Kwikvette[QUOTED] like this.
  19. Sep 7, 2023 at 7:05 AM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    Happy Birthday!!! Hope it's a good one.
    ....but:
    You're reaching the "age acceleration point" on the graph. Age is linear when you are younger, but it accelerates to an exponential curve once you reach around 40.
    You need to go ahead and start thinking about at what age you'll buy your "last new truck", where you'll live in Florida, and how you'll look wearing a white belt. :)
    To stay on "Anything Welding" my advice is to start practicing welding with a shield that you scuffed up the lens with a 60 grit flap disk, cause soon you eyesight will make your welding look like you attended the Stevie Wonder School of Welding. Ask me how I know. I have 20/800 in both eyes and have bifocals. :anonymous:
    Okay, I'm done. Enough birthday harassment.
  20. Sep 7, 2023 at 7:06 AM
    Bivouac
    Enough just by a Prime Weld 180 and be done.
    My second choice would be the Hobart line!
    Look to your future needs plan ahead.
    SamSpade[QUOTED] likes this.
