Anything welding
Discussion in 'Garage / Workshop' started by EL TACOROJO, Sep 17, 2010.
  1. Sep 19, 2023 at 5:44 PM
    mjbtaco
    mjbtaco low and slow
    Michael
    Montclair , so cal
    Turbo'd 95.5 extra cab and 2013 Silver DCSB TRD Sport
    PERFORMANCE Custom Turbo Setup FRONT SUSPENSION Drop Spindles by Aaron Carswell 01-04 Swaybar Endlinks Energy Suspension Endlink Bushings Cando Upper Control arms QA1 coilovers with 8" spring Custom 4 pot Brembo BBK Modified lower control arms with mjbfab qa1 mounting plates and Poly bushing sleeves REAR SUSPENSION Chasis Tech drop leafs QA1 adjustable shocks weld in drop notch Gas tank cross member bridge 3" angled blocks 2013 Double Cab Short Bed TRD Sport Eibach Pro Truck Shocks front and rear Lifted to the 3rd setting on the front shocks
    A couple welds from a customer order. They bought everything I make.
  2. Sep 19, 2023 at 5:55 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Man, I'm really surprised you just don't cut your own parts on a table!
    You have enough orders.
    KRAMERICA, wilcam47 and Bivouac like this.
  3. Sep 19, 2023 at 6:23 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
  4. Sep 19, 2023 at 6:28 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    :rofl:
    But it's already all hooked up!
    Trust me, the CPC port only setup was as clean and professional looking as it gets.
    Unfortunately divided voltage via CPC port is not as reliable as raw voltage is.
  5. Sep 19, 2023 at 6:42 PM
    mjbtaco
    Michael
    Montclair , so cal
    I have 0 room left in my garage for a table. Would be nice but my workspace is small.
    koditten and wilcam47 like this.
  6. Sep 19, 2023 at 6:56 PM
    soundman98
    NW Indiana
    personally, i'd pull some other wires off the cpc port to make it do my bidding...
    Kwikvette[QUOTED] and koditten like this.
  7. Sep 19, 2023 at 7:09 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Expand into the living area!!
    My Tool boxes are in the living room.
    soundman98, koditten and KRAMERICA like this.
  8. Sep 19, 2023 at 7:19 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    The port does have pins for raw voltage, apparently 5 and 7
    I bet I can get PrimeWeld to send me a new plug to solder up some new wires
    I'd end up messing up the existing cable setup as the pins are crazy tight together and I put a heatshrink on each cable (4 total), a heatshrink per pair (2 total), and a final one for the whole cable (1, for a total of 7).
    Drainbung, Bivouac and koditten like this.
  9. Sep 19, 2023 at 7:21 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    @Wsidr1
    Curious, why did you tap into your plasma cutter instead of using pins 5 and 7?
    You went straight to raw voltage right?
    I went divided voltage with my plug which is why I went into the machine when I went raw. I didn't ask for a replacement plug.
  10. Sep 19, 2023 at 7:27 PM
    Bivouac
    Keep your connections to as few as possible.
    Since this is a trigger signal. Every connection can degrade the signal .
    Kwikvette[QUOTED] likes this.
  11. Sep 19, 2023 at 7:28 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Between you and @soundman98 wanting to make changes to my setup, you guys should just fund the endeavors for me :rofl::luvya:
    soundman98 and koditten like this.
  12. Sep 19, 2023 at 7:31 PM
    Bivouac
    Then you would need to switch to Hypertherm !!
    I would hear about that from my Hypertherm Rep till I died.
    If you were closer!!
  13. Sep 19, 2023 at 7:35 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Oh I hear a lot of good about Hypertherm, but even their 45 amp plasma cutter is over $2,200.
    Sad thing is, buddy that lives half hour away (he has a Pro table) had a Hypertherm fail and has been using a CUT60 successfully.
    When you're retired on a fixed income, it's a little harder justifying a second plasma cutter! The CUT60 cuts phenomenally well though! The issue I had was related to the Langmuir module only fortunately!
  14. Sep 19, 2023 at 7:38 PM
    Bivouac
    You do not need to tell me about living on my $900.00 a month income.
    plus a few extra $$ here and there.
  15. Sep 19, 2023 at 7:39 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    You've had your tools for years though! I obviously got into all of this way late :rofl:
    soundman98 and Bivouac[QUOTED] like this.
  16. Sep 19, 2023 at 7:41 PM
    Bivouac
    very true I might have not bought any new tools for 3 years.
  17. Sep 19, 2023 at 7:46 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Yeah it was rather...expensive last year
    Down payment for the house, plasma cutter, cnc table, welder, several power tools, wedding, all in one year :bananadead:
    Then this year, baby lol
  18. Sep 19, 2023 at 7:48 PM
    Bivouac
    I guess that was a chunk of money.
    Is #2 on the way soon?
  19. Sep 19, 2023 at 7:49 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    You must be rich....;)
    soundman98, KRAMERICA and Bivouac like this.
  20. Sep 19, 2023 at 7:51 PM
    Bivouac
    I think the word should be WAS rich!!:thumbsup::rofl::rofl:
