Anything welding
Discussion in 'Garage / Workshop' started by EL TACOROJO, Sep 17, 2010.
  1. Oct 7, 2023 at 8:56 PM
    weldertaco
    weldertaco Mr.13%bodyfat
    texas
    TrailRunner
    4wd to 2wd conversion
    I was a welder for about 8 years and recently switched to QC/QA and it’s definitely been interesting seeing how different people can interpret things lol
    Slashaar likes this.
  2. Oct 8, 2023 at 12:02 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    This 4' x 2' of steel has been staring at me for a long time, used 2/3 of one and still got another one left
    Delta09, Drainbung, koditten and 2 others like this.
  3. Oct 8, 2023 at 2:15 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Cut a few more :anonymous:
    Figured I'd have a whole big batch to paint all at once
    Thinking the ghosts will all be for hanging and the pumpkins get welded some steel rod for planting in the ground
    Delta09, Slashaar, Drainbung and 2 others like this.
  4. Oct 8, 2023 at 3:13 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    weld some small pieces of tubing to the back side, and you can run some orange christmas light strings along behind them for a walkway lights...
  5. Oct 8, 2023 at 3:23 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    They're gonna get steel rod welded to the backs of the pumpkins for mounting in the ground
    But little holders for lights is a great idea
  6. Oct 8, 2023 at 4:40 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Why buy/ use rod?
    Cut some narrow strips, weld some strips perpendicular to them to make them rigid.
    Good use for the scraps I would think.
    Drainbung likes this.
  7. Oct 8, 2023 at 4:43 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I have some 40-50' of rod that is scrap (about 25' of it here behind the square tube)
    I'm only welding rod to like 15 pumpkins total
  8. Oct 8, 2023 at 4:48 PM
    koditten
    Kirk
    Central Michigan
    Good deal!
    I'm hording my rod( hee, hee), since it's much more spendy than sheet steel.
  9. Oct 8, 2023 at 4:50 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    You had the right idea though, really just left over flat stock but I have more rod than anything else :bananadead:
    Rod is all left over and really I'm trying to keep this as cheap as possible offering the extras at $15 each for the ghosts and $20 each for the pumpkins
    I scaled the ghosts down to .60 for a small 7.5" tall piece and the pumpkins are only between 5-6" round
    Drainbung and koditten[QUOTED] like this.
  10. Oct 8, 2023 at 5:37 PM
    Pyrotech
    Pyrotech Well-Known Member
    Slashaar, Drainbung, Bivouac and 2 others like this.
  11. Oct 8, 2023 at 5:40 PM
    Pyrotech
    I try to save the bolts from the wire reels at work. cut the hex head off and the threaded portion, I end up with a few feet of rod size depends on the reel size
  12. Oct 8, 2023 at 5:44 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Already dry to the touch
    I'll flip them tomorrow and paint the backside then hang them out to cure the day after
    Delta09, Slashaar, soundman98 and 2 others like this.
  13. Oct 8, 2023 at 6:23 PM
    weldertaco
    texas
    TrailRunner
    So so so SO close to being done. Reallly love how this project turned out. Way too many bends tho :puke: but worth it. Except somewhere somehow there’s a little twist because when it’s on the car one corner is just bareeeelllyyyy higher than than the others (like 1/8”) and I’m debating on how to fix or find it. Or just keep it for a prototype and build the next one lol.
  14. Oct 8, 2023 at 7:45 PM
    soundman98
    NW Indiana
    an 1/8" over that distance could easily be thermal cycling from welding.
    that's really good, better than i normally get.
    Drainbung and Kwikvette like this.
  15. Oct 8, 2023 at 8:07 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Ooooooor just make the 'mounting points' with enough play to adjust that last bit of 1/8" out.
    Drainbung and Pyrotech like this.
  16. Oct 9, 2023 at 4:59 AM
    weldertaco
    texas
    TrailRunner
    Problem is the very front of the rack doesn’t have “mounts”. It’s gonna have feet but won’t be bolted down. Only the back and center gets bolted down. So I’m worried about when the back gets bolted down it’s going to tweak the front some. But I guess the center mounts should stop that.
  17. Oct 9, 2023 at 5:01 AM
    weldertaco
    texas
    TrailRunner
    Problem is an 1/8” over 4-5ft grows drastically and if there’s other tubes in front of it or in line with it then it just stands out worse lol. Hard to see in the pic but the very back bar is ever so slightly out.
    Slashaar and Drainbung like this.
  18. Oct 9, 2023 at 5:19 AM
    KILLINTIME
    KILLINTIME Like a Villain
    Gotcha I’ve been welding for 26 years.
    I like that
  19. Oct 9, 2023 at 10:16 AM
    spencermarkd
    spencermarkd Well-Known Member
    Spencer
    07 Driftwood Pearl 4Runner
    Well shit, better throw it away then, if you bring up here to WA I'll help get rid of it, we can even put it on top of my 4runner to take it to the uhh.. dump.. yeah.. definitely not bolt it onto it permanently :anonymous:
    I feel like this is one of those things where since you were the one to make it and spent so much time staring at it, you'll see every tiny imperfection that no one else will over notice. We're our own harshest critics scenario. I think it looks great, FWIW. I'd put it on my 4R.
  20. Oct 9, 2023 at 12:10 PM
    weldertaco
    texas
    TrailRunner
    Haha thanks man. And big big facts on our own critics. I think it’s just a pride thing. Like will it be fine? Yes. Will most notice it? Probably not. But I know it’s there. And that’s what bothers me lol. I’m hoping to go into production of these for locals at around $800-$1,000 so it’s not going to be cheap. Won’t be as expensive as the big brands. But I still want it right. So nailing this first one down has been seeking perfection at every fit and bend.
