Anything welding
Discussion in 'Garage / Workshop' started by EL TACOROJO, Sep 17, 2010.
  1. Oct 9, 2023 at 4:46 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Don't forget your welding hoods this Saturday
    Slashaar, weldertaco and Drainbung like this.
  2. Oct 9, 2023 at 9:18 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    At arm's reach, you can see the flaws in the paint but at night, or even in the daytime while being hung, they're gonna look perfect (hopefully)
    Also going to see how this cuts out tomorrow
  3. Oct 10, 2023 at 5:37 AM
    weldertaco
    weldertaco Mr.13%bodyfat
    texas
    TrailRunner
    4wd to 2wd conversion
    Those are cool lol
    Kwikvette[QUOTED] and Drainbung like this.
  4. Oct 10, 2023 at 12:39 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    The 4R thread gets google hits, 3rd set I've made already
    Cleaned, packaged up, and ready to ship as he needs them right away
  5. Oct 10, 2023 at 4:18 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Putting some of that rod from last year to use
    Since the ghosts are mostly done, I'll put them away and paint the pumpkins soon
    Slashaar, Vmax88, soundman98 and 2 others like this.
  6. Oct 10, 2023 at 8:37 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Oh and @soundman98
    If I find some down time, I'll rewire my raw voltage on my plasma cutter :rofl:
    New rear CPC plug arrived from PrimeWeld so I can solder just the torch ON/OFF barrel plug.
    Also a new plug for + and - for tapping into that raw voltage.
    For the most 'professional' look, I really should just mount the plug to the rear so it comes out the same way the factory plug does since it's the same style port (but with a different attachment type and color to prevent confusion).
    soundman98 likes this.
  7. Oct 11, 2023 at 12:57 PM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    Going back to self-employment. Tried this W2 thing again for 13 months, didn’t stick.
    Anyone had any luck with the Miller Trailblazer with the air compressor built in? I’ve used an old simple machine but that piqued my interest.
    I’m looking at the Trailblazer 325 EFI
    but the 302 Air Pak has a built in air compressor for my plasma torch…
    Anyone used one? Not thinking the price hike for less capability elsewhere is the most tempting.
    Kwikvette likes this.
  8. Oct 11, 2023 at 3:03 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    3/8" thick and laser cut :drool:
  9. Oct 11, 2023 at 8:13 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    These actually came out pretty cool
    Delta09, soundman98, Slashaar and 5 others like this.
  10. Oct 12, 2023 at 6:34 PM
    weldertaco
    texas
    TrailRunner
    So it’s all tacked on…. And it looks AMAZING… only to discover that I need to think of new mounts cause after tacking the rack to the mounts I realized I don’t have access to the bolts. DO-OH. But lawd it feels good to see it on the car in place.
  11. Oct 12, 2023 at 7:35 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Well another member has spoken up about taking and disposing your rack for you
    I on the other hand propose disposing your tube bender cause clearly it's the tool's fault and not yours; you're way more precise than that thing could ever be
    Let me know when to send you the shipping label :burp:
  12. Oct 13, 2023 at 3:36 AM
    weldertaco
    texas
    TrailRunner
    I’d trade the bender for that fancy CNC you got :laugh:
    Slashaar likes this.
  13. Oct 13, 2023 at 6:54 AM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    Just make bolt plates that bolt to your mounts.
  14. Oct 13, 2023 at 7:11 AM
    weldertaco
    texas
    TrailRunner
    Problem is I don’t want the mounts to be bolted vertically. Because that leaves chance for the rack to shift when loaded. So I’ll have to modify my mounts from an angle design to a C design with nuts welded to the top plate then weld a plate to the rack for the bolts to go through basically.
    Slashaar[QUOTED] likes this.
  15. Oct 13, 2023 at 8:13 AM
    Slashaar
    Josh
    Kansas City, MO
    yeah, that's what I was thinking of.
  16. Oct 13, 2023 at 9:26 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Ooooh no no no no no, you and an angle grinder could run circles around what this thing could do
    You'd be going backwards and I can't let you do that so you gotta send me that tube bender:anonymous:
  17. Oct 13, 2023 at 5:40 PM
    la0d0g
    running for the hills
    For crawling not hauling
    I know there are a lot of variables but what should I expect to pay for 2" square tubing per linear foot approximately?
  18. Oct 13, 2023 at 5:53 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    The 20' of 3/16" square tube I bought was under $80...think it was like $74 or $78.
    Had bought some for my rear swingout on the Land Cruiser; used some of the remainder for my vise stand and whatever else shit I needed. Still have a bit left over.
    Unless it's scrap I can find, it's going to be new and in 20' lengths here.
    Drainbung and la0d0g[QUOTED] like this.
  19. Oct 13, 2023 at 5:57 PM
    la0d0g
    Thanks! I need about 60' to make an aquarium stand and kicking around cost to make versus buy. Of course making one will be much more fun and satisfying!
    Drainbung likes this.
  20. Oct 13, 2023 at 5:58 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    At 8lbs per gallon, aquariums get stupid heavy so I understand the need to overbuild.
    I take it you're creating an entire frame with this tubing?
