Anything welding
Discussion in 'Garage / Workshop' started by EL TACOROJO, Sep 17, 2010.
  1. Dec 27, 2023 at 8:28 AM
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    The pieces in the pictures were not welded going uphill. I just showed a sample of my practicing.
    How different are the settings?
  2. Dec 27, 2023 at 8:29 AM
    Scott B.
    Scott
    Georgia
    Interesting.
    I need to weld extended shock mounts on my truck, and they need to be welded vertically.
  3. Dec 27, 2023 at 8:32 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Fuck like 50-100ipm and maybe up to 2-3v difference
    Are you an experienced welder already? Trade work?
  4. Dec 27, 2023 at 8:38 AM
    Scott B.
    Scott
    Georgia
    No - hobby welder. Wanting to expand my capability/knowledge.
    I just did a quick search, and found on weldpundit.com talking about vertical welding. It described my issue exactly. I need to study page, and try again.
  5. Dec 27, 2023 at 8:44 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    There's countless arguments on when to use uphill vs downhill and whatnot
    Me, I've done uphill and downhill in the professional world, and do little of it as a side gig
    I only used vertical up when I was running on thick mild as I wanted to ensure penetration; on thinner you can easily develop a ton of undercut as your base metal soaks heat (heat rises) and will be super hot by the time you finish your weld up top
    Being a hobbyist, slow down, and practice but if you need to weld something now, work on downhill
    Remember, angle of your torch matters a lot when it comes to 3F or 3G
  6. Dec 27, 2023 at 8:51 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Why?
    I see no reason for that needing to be vertical welded.
    Can you elaborate on reason?
  7. Dec 27, 2023 at 8:58 AM
    Scott B.
    Scott
    Georgia
    I have all the time I need to practice. Parts have been sitting on my shelf for months - what's another year? LOL
  8. Dec 27, 2023 at 8:59 AM
    Scott B.
    Scott
    Georgia
    Simple.
    The brackets that mount to the frame have vertical legs that attach to the side (the vertical webbing) of the frame.
    koditten[QUOTED] likes this.
  9. Dec 27, 2023 at 9:17 AM
    koditten
    Kirk
    Central Michigan
    I assumed that was how they are mounted. I just don't know why they have to be uphill welded.
    Both frame and bracket are just degrees of sheet metal.
    60S welding wire has a sheet strength of 60,000 lbs/ inch of weld.
    The frame material will rip long before the weld fails.
    I just don't see this as something that needs the extra penetration of an uphill vertical weld. Its sheet metal. You will have no trouble getting penetration welding down.
    I do not have experience welding shock mounts, but I do have lots experience welding on truck frames.
    Kwikvette likes this.
  10. Dec 27, 2023 at 9:26 AM
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 OR DCFB
    Fox and Locked suspension 63's Skinny 33's
    Also if it is strictly a shock mount it only has to hold up to the dampening forces of the shock itself.
    ignore this if this is a coil over mount for a 3 link setup.
  11. Dec 27, 2023 at 9:35 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Frames are 1/8" thick; you do not need to weld uphill especially on thin steel as a novice
    koditten likes this.
  12. Dec 27, 2023 at 10:00 AM
    Scott B.
    Scott
    Georgia
    I did not realize there is such difference between uphill and downhill welding. I understand now (been doing some more reading).
    Yes, downhill will be plenty fine for the shock mounts.
    koditten[QUOTED] and Drainbung like this.
  13. Dec 27, 2023 at 10:01 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I'm just a hobbyist so take my advice with a grain of salt :D
    Drainbung likes this.
  14. Dec 27, 2023 at 10:10 AM
    Scott B.
    Scott
    Georgia
    If you are only a hobbyist, you are a very serious hobbyist. :)
    You are very correct about the settings. Thank you for the prompt to search - I've done some very interesting reading this morning and learned a lot.
    Now to go practice more...
  15. Dec 27, 2023 at 10:38 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Speaking of welding and truck parts, I just got an order last night for these
    Rear lower control arm mounts for a 4R
    malburg114, Vmax88, koditten and 2 others like this.
  16. Dec 27, 2023 at 10:40 AM
    Scott B.
    Scott
    Georgia
    You make it look easy...
  17. Dec 27, 2023 at 10:41 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    When you really enjoy what you do, it becomes easy
  18. Dec 27, 2023 at 11:10 AM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    koditten and Kwikvette[QUOTED] like this.
  19. Dec 27, 2023 at 12:22 PM
    Zebinator
    Zebinator Well-Known Member
    Norcal
    06 Tacoma TRD Offroad
    Soon you’ll be bending those up on your titan….
    Pyrotech and Kwikvette[QUOTED] like this.
  20. Dec 27, 2023 at 12:25 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    You mean outsource to you? :burp:
    I can't afford that thing, not on a fixed income! :rofl::bananadead:
    Drainbung and Zebinator[QUOTED] like this.
