Anything welding
Discussion in 'Garage / Workshop' started by EL TACOROJO, Sep 17, 2010.
  1. Dec 30, 2023 at 4:54 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I do what I want :rofl:
  2. Dec 30, 2023 at 4:54 PM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    Hopping over to the guard unit back home. Gonna take a class at a local community College. I look for reasons too, just don't have the equipment to get it done. I've done side projects on some rigs for guys in the unit. Bumpers, sliders etc...I want a plasma table so I can do more projects like you've got going. Those dinos turned out fucking rad.
    Definitely get where you're coming from. I've had this machine since 2019/2020 and as of this year finally have the confidence to do stuff for other people. But like you said...the projects are few and far between. Definitely want to get better at mig before even thinking about trying to learn tig.
  3. Dec 30, 2023 at 7:40 PM
    Pyrotech
    Pyrotech Well-Known Member
    or use a copper backing plate. I had decent luck with that for small sections.
  4. Dec 30, 2023 at 7:42 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Good idea, I've only ever use aluminum for heat soaking never copper
    Drainbung, soundman98 and koditten like this.
  5. Dec 30, 2023 at 7:52 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I need to buy some PVC pipe, drains, strainers, a filter, and pump but the big item is here -
    With the Crossfire XL, I was only dealing with 7ish gallons which was easily dealt with a 5 gallon bucket.
    The Crossfire Pro holds about 15 gallons so getting this done will making drain and fill much easier when I need to clean scraps out.
  6. Dec 31, 2023 at 9:34 PM
    Gen1FTMFW
    Gen1FTMFW Well-Known Member
    2000 Tacoma 3.4 TRD "Stock AF" & 2006 GX470 Sport
    I bought the 220 because of the HF start and AC TIG thinking that I wanted to get back into TIG welding again. Took a year of welding classes at the local community college about 20 years ago and had a blast working the different processes. Did one quarter of oxy/stick, one quarter of MIG and 2 quarters of TIG.
    That said, I've yet to use TIG once on it. Have everything setup, but always find myself using MIG cause it's quick and easy. One of these days I'll bust it out if I can find the time.
  7. Jan 1, 2024 at 10:16 AM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    He t
    I took the easy, but a bit more expensive route, over the PVC. I used Sharkbite and made individual drain connections so I can easily disconnect from my tank and take it out from under the table for emptying/cleaning the crap from it.
    That's the fill wand hanging there. I just lay it in the tray and connect a battery charger to my pump to refill after draining.
    Kwikvette[QUOTED] likes this.
  8. Jan 1, 2024 at 10:54 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I haven't planned any part of it, and really I can only do that once the table is drained to figure out the size of the drain opening in the pan.
    I don't want enlarge the opening at all and would like to find a drain with strainer to drop in place (without modification).
  9. Jan 1, 2024 at 1:11 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    check the dollar store for solutions.
    drain strainers are pretty common, could even use a piece of window screen as well
    https://www.amazon.com/s?k=mesh+drain+strainer&crid=2Y10XAJ925FVS
    Drainbung likes this.
  10. Jan 1, 2024 at 1:21 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Oh for sure, I'm replacing the actual drain though so I'll need to find the right sized sink drain which will probably be an RV style.
    Just won't know until she's empty; emptying the table via conventional means is just a chore.
    And just for kicks, I'm going to wire up and mount a switch on my table for on/off for running the pump to fill.
    I could go beyond and add such a thing for opening and closing the drain too.
  11. Jan 1, 2024 at 1:32 PM
    motolife313
    motolife313 Well-Known Member
    Turn the wire/amps down a ways and turn youre volts down about 2-4 volta probably. U can also put a little tack weld down to have a shelf to start on can help. And u can weld a very wide gap like u have going up hill. U can have the biggest gap actually out of all the positions going uphill. This was Thursday at work running .052 flux core wire with gas, we run 1/16 wire too, overhead you can run hotter then uphill, I did turn the amps up a pinch but didn’t feel like going to climb for the inverter and turning it up but could have used another volt or so, and uphill welding u can make a really big weld and u weld it kinda slow and the weld may look like it will drop but won’t unless the welder is set to hot, it will drop right awayA07DA442-A3A5-46CF-A0CD-BAFD66A0114A.jpg6D4E0FA2-5A81-4581-9C4D-61F04288B97E.jpg DA60D609-6F6B-4EA7-A52F-F7AFFDC59E3E.jpg
  12. Jan 1, 2024 at 1:40 PM
    motolife313
  13. Jan 1, 2024 at 8:06 PM
    malburg114
    malburg114 Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
    I’m all self taught and mainly got the 215 because it was a sema demo and a good price when miller debuted it. I tried to learn dc tig but struggled with the scratch start so picked up a miller dynasty 180 I think it is and tried to learn tig again only to realize I have no real interest in learning it. I’ve kept the machine mainly to learn ac tig to do small aluminum jobs or maybe learn tig in general for those few occasions I need it. Overall, mig is my go to
    koditten and Gen1FTMFW[QUOTED] like this.
  14. Jan 1, 2024 at 8:15 PM
    motolife313
    Never heard of a dynasty 180. I take it u mean diversion 180??
    malburg114 likes this.
  15. Jan 1, 2024 at 8:35 PM
    malburg114
    Las Vegas, NV
    Yes sorry. Auto correct didn’t help me on that one.
  16. Jan 2, 2024 at 12:00 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    55" long x 33" tall
    Jiveydude, Bivouac, Vmax88 and 6 others like this.
  17. Jan 2, 2024 at 12:13 PM
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    Did you make your welding table and tabletop?
  18. Jan 2, 2024 at 12:15 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I made everything about it, minus the holes as I got that laser cut.
    If I had cut it out on my cnc table like I did my 21" x 21" mini table, I would've had to ream each hole out.
    Drainbung and Scott B.[QUOTED] like this.
  19. Jan 2, 2024 at 12:43 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    @Scott B.
    When I first welded it up
    Table top total was $158 ($171 with taxes) for the material and labor of cutting; 2' x 3' at 3/8" with 5/8" holes at 2" centers
    Square tube was spare stuff I had left over along with what a friend had left over so free
    This stuff I cut out was also scrap/left overs from previous jobs so also free
    When I welded it up
    I have $175 or so once you add the welding wire used lol
    Much cheaper and significantly thicker than those thin ass tables you find at online or even at Harbor Freight
  20. Jan 2, 2024 at 12:55 PM
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    What do you think it would have cost you if you didn’t have all of the free materials?
