Anything welding
Discussion in 'Garage / Workshop' started by EL TACOROJO, Sep 17, 2010.
  1. Jan 3, 2024 at 3:29 PM
    Pyrotech
    Pyrotech Well-Known Member
    temporary solution.. Once I get the machine going I can cut the same style out of some aluminum plate.
    And I was thinking if I crash it the mounts are disposable, an hopefully break before something else.
    Drainbung likes this.
  2. Jan 3, 2024 at 3:53 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    it's winter for a lot of people! most people living in sub-40 degree weather aren't choosing to weld something unless it broke!
    i'm slowly assembling the parts for my possibly-for-profit trailer build. got the tubing to widen the axle, d-rings, front storage compartment, and a tentative facebook agreement to buy a similar non-titled weather-beaten trailer for cheap-ish to use for similar-type metal stock.
    still need brake drums, axle straps and spring relocation parts, lights, winch, wheel wells, flooring, wiring, battery, battery box, and some warmer weather! and after all that, comes the fun legalese part of attempting to title the whole thing.
  3. Jan 3, 2024 at 5:50 PM
    "OldManTan"
    "OldManTan" Bye bloody Taco... Hello MGM Burrito!
    Buffalo, NY
    '16 Tundra DC
    Holy chit, I've done a lot already!!
    Says the retired guy...:rolleyes: We working stiffs enjoy living vicariously through you, dreaming of those days :amen:
  4. Jan 3, 2024 at 6:09 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I'm incarcerated in SC until March.
    I'm estranged from my shop. About the only tool I can have access to is a pocket knife.
    Believe me! I will be "cracking out" on projects when I get back to home base.
    Roughly 74 days, 9 hours, 34 minutes and 44 seconds.
    43 seconds.
    40 seconds...
    la0d0g, Drainbung and soundman98 like this.
  5. Jan 3, 2024 at 6:22 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Sir, I don't think swapping out my CPU is anything anyone dreams of doing :rofl:
    Drainbung and koditten like this.
  6. Jan 3, 2024 at 6:41 PM
    Slurmin Furrmen
    Slurmin Furrmen Welder / Fabricator
    Probably
    Northern Colorado
    21 OR DCLB
    Bearing wear
    Increase your wire feed speed and voltage, get a smaller diameter tip in the "extended / stick out" flavor that allows the contact tip to extend past the end of nozzle, increase gas flow, and shorten your wire stickout.
    This is referred to as a Skewed T Fillet and can be difficult due to larger nozzles creating longer stickout. Overhead (4G / 4G) with GMAW is perfectly acceptable and with proper settings can be run very well, but suffers from too much stickout (CTWD - Contact Tip to Work Distance) worse than other positions at lower amperages due to the increased weight of the droplet pulling the droplet down instead of across the arc.
    We prefer flush for most welding, recess for heavy welding, and extended for skewed T or difficult to reach areas.
    For example: (Since I dont care to know what machine you are using)
    Miller 250 MDX Recess Nozzle - https://www.millerwelds.com/consuma...rifice-18-tip-recess-copper-1-per-pkg-nm5818c
    Miller 250 MDX Flush Nozzle - https://www.millerwelds.com/consuma...58-orifice-flush-tip-copper-1-per-pkg-nm5800c
    Miller 250 MDX 1/8" Extension Nozzle - https://www.millerwelds.com/consuma...-18-tip-extension-copper-10-per-pkg-nm58xtc10
    soundman98 and Bivouac like this.
  7. Jan 3, 2024 at 6:42 PM
    Slurmin Furrmen
    Probably
    Northern Colorado
    21 OR DCLB
    Bearing wear
    why are you running ram in single channel instead of dual channel? Are you afraid of system performance? :rofl:
  8. Jan 3, 2024 at 6:55 PM
    Slurmin Furrmen
    Probably
    Northern Colorado
    21 OR DCLB
    Bearing wear
    Noice.
    malburg114 likes this.
  9. Jan 3, 2024 at 7:46 PM
    malburg114
    malburg114 Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
    la0d0g, soundman98, allenfab and 4 others like this.
  10. Jan 3, 2024 at 8:09 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Gaming doesn't discriminate :luvya:
    soundman98 and Drainbung like this.
  11. Jan 3, 2024 at 8:33 PM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    koditten[QUOTED] and Kwikvette like this.
  12. Jan 3, 2024 at 8:36 PM
    Slurmin Furrmen
    Probably
    Northern Colorado
    21 OR DCLB
    Bearing wear
    :thumbsup:
    I have an itchy trigger finger right now for a Z790, 14900K, DDR5, RTX 4080 build ....
  13. Jan 3, 2024 at 8:44 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    DDR4 is still plenty enough and fast, so if you've got cash burning a hole in your pocket go for it!
    14th Gen performance is way too close to 13th Gen, but a 4080 for sure would be nice!
  14. Jan 3, 2024 at 9:06 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    :rofl:
    koditten likes this.
  15. Jan 4, 2024 at 1:12 PM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    Glued this MOVE bumper together for a coworkers sierra
  16. Jan 4, 2024 at 1:17 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Good stuff!
    I was literally on my last bead (welded up another set of mounts earlier today) when I ran out of wire already
    Fortunately I always have a few extra 11lb spools on stand by but I swear this last 11lb spool lasted me only a few months
  17. Jan 4, 2024 at 1:22 PM
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    Maybe because you're welding a lot more than you used to? Just a thought... :D
  18. Jan 4, 2024 at 1:26 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I don't even remember using it though :rofl:
    I know what it is, I've been welding a lot more but for customers and less for myself
    So when I'm in the garage, I don't see anything "new" so I'm like wtf lol
  19. Jan 4, 2024 at 1:52 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Think about you and welding You really don`t have all that many months working for someone else.
    That is when it gets to be almost a job to just pay bills . The nice thing the hood comes down your almost in your own world.
    I need to build a bumper for the 4Runner my hip and knees have been just hurting all the time.
    Soon I hope to have some ambition .
    Kwikvette[QUOTED] and soundman98 like this.
  20. Jan 4, 2024 at 2:00 PM
    Bivouac
    Do you need to be rescued??
    Is your wife holding you prisoner since you state your incarcerated??
    Maybe a leg Iron with enough chain to move slightly.
    I would be glad to take you back to your shop.
    Kwikvette and koditten[QUOTED] like this.
