Anything welding
Discussion in 'Garage / Workshop' started by EL TACOROJO, Sep 17, 2010.
  1. Feb 9, 2024 at 1:06 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    True but a lot of people blow it out of proportion, specifically those that repeat what they heard or read on the internet
    Those people being hobbyist types that have smaller tables, whether a cheaper turn key or DIY setup
    Being on a few groups and forums, with lots of people cutting aluminum, no such accident has ever occured
    One guy mentioned hearing a small faint pop of some sort, but it was like the tiniest firework
    Zebinator[QUOTED] and koditten like this.
  2. Feb 9, 2024 at 1:14 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Thanks for the details. I've cut aluminum on my water table often. I was not aware of the hydrogen development aspect.
    With that said, it would take a hell of a pocket of H to create a hazard.
    With the small parts we do, I can't see how a pocket of gas would develope.
    Regardless, I thank you all for the info.
    golfindia and Kwikvette[QUOTED] like this.
  3. Feb 9, 2024 at 1:47 PM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    How do I tell whether a 10 cu ft acetylene tank is full?
    I purchased a portable torch kit that came with oxy and acetyl tanks. I traded my brand spanking new tank in to my local gas supplier for the shittiest looking tank covered in a combination of floor debris and spiderweb with a cantankerous valve. I have a feeling hobbyist that stop in a very rare occasion get the shitty stuff. It feels about as light as the empty tank. How do I tell a "level" besides the regulator gauge showing life? TIA
    Kwikvette likes this.
  4. Feb 9, 2024 at 1:48 PM
    koditten
    Kirk
    Central Michigan
    It should show 2000 psi on the primary gauge and it should be much heavier.
    Kwikvette and Gen3TacomaOBX like this.
  5. Feb 9, 2024 at 2:06 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    This
    You don't get to pick your tanks when you do exchanges, but also why I tell people not to bother with getting a "pretty" tank unless you want to pay extra for the labor of filling
    Maybe go with a different supplier? All my exchanged tanks look practically new
    Gen3TacomaOBX likes this.
  6. Feb 9, 2024 at 9:10 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Pyrotech likes this.
  7. Feb 10, 2024 at 1:15 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Depends where you live !
    Every distributor is going to be different.
    The ones I go to check the pressure with a regulator before it leaves the dock
  8. Feb 10, 2024 at 12:08 PM
    Gen3TacomaOBX
    S
    Appreciate it gents. First time I cracked the valve w/the regulator hooked up and it shows exactly 1200 psi. This is a 10 cf acetylene tank.
  9. Feb 11, 2024 at 12:14 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
  10. Feb 11, 2024 at 3:37 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    you got your smiley faces mixed up. needing to use the 'less fire' option is always a sad face time.
  11. Feb 11, 2024 at 3:44 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I may have a sprinkler system in my garage but I still don't want my shit to burn down :luvya:
  12. Feb 11, 2024 at 4:41 PM
    soundman98
    NW Indiana
    my point still stands. at no point is using the less fire option a happy experience.
    Drainbung and Kwikvette[QUOTED] like this.
  13. Feb 11, 2024 at 4:44 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Then make me one and send it to me :luvya:
    Bivouac likes this.
  14. Feb 11, 2024 at 4:49 PM
    soundman98
    NW Indiana
    sure i'll just fire up my garage.
  15. Feb 11, 2024 at 4:56 PM
    soundman98
    NW Indiana
  16. Feb 11, 2024 at 5:03 PM
    koditten
    Kirk
    Central Michigan
    I dunno.
    A 100* beer can be cooled down with a CO2 extinguisher enough to make it taste pretty good on Uber hot day.
    When those extinguishers age out, might as use it for something useful.
  17. Feb 12, 2024 at 5:07 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    haha I was thinking the same thing
    So I found a deal that seemed too good to pass up this weekend down in RI. Its a well used machine but the screen is functional, just has a bit of paint splatter on it. The guy was wicked cool, seemed to know his shit. He fired it up on 240v and did a few nice welds.
    Came with just about everything I could need to start, all for $1800
    -C25 bottle & regulator
    -Spool gun
    -Tig torch
    -Has the K4104-1 Tig pedal adapter wired in already, though did not come with a pedal
    -Cheap little HF cart
    -Eastwood tungsten grinder
    -4 or 5 spools of wire including AL spools
    -Various types of sticks and filler rods
    -A whole case full of consumables, gas lenses, etc etc
    Unfortunately Im traveling for work all day tomorrow then the weather gets super cold here for the next few days. But I hope to lay everything out later in the week and take a full inventory. That blue tote is right packed with all the extra stuff that came with the machine
  18. Feb 12, 2024 at 8:14 AM
    Bivouac
    I think your smiley faces are correct !:thumbsup:
    More heat most often means a problem.
    Less Heat your saving $$$$ worth of tools!!:thumbsup::thumbsup:
    soundman98 and Kwikvette[QUOTED] like this.
  19. Feb 12, 2024 at 8:15 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I'm getting a replacement made anyway by @soundman98 :D
    Bivouac[QUOTED] likes this.
  20. Feb 12, 2024 at 9:32 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Glad you got the welder we knew you'd buy anyway :luvya:
    Bivouac, koditten and SR-71A[QUOTED] like this.
