Anything welding
Discussion in 'Garage / Workshop' started by EL TACOROJO, Sep 17, 2010.
  1. Apr 11, 2024 at 8:17 AM
    soggyBottom
    soggyBottom Well-Known Member
    Over engineered where's Waldo?
    wilcam47[QUOTED] and KRAMERICA like this.
  2. Apr 11, 2024 at 8:20 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    1 raptor and 1 pterodactyl
    Still have 2 raptors to cut so hoping I can buy some steel today to cut over the weekend
    This was the raptor, before clean up (already shipped)
    And the Pterodactyl all cleaned and ready to ship
  3. Apr 11, 2024 at 10:26 AM
    weldertaco
    weldertaco Mr.13%bodyfat
    texas
    TrailRunner
    4wd to 2wd conversion
    What does the page say that you ordered from? It's not uncommon in the off-road world to have 2-3 month wait times. Nobody can really answer this without more info
    Kwikvette likes this.
  4. Apr 11, 2024 at 10:41 AM
    Y2kbaja
    Y2kbaja Well-Known Member
    Sacramento
    05 Total Chaos Tacoma
    Total Chaos
    I made a springer spaniel yesterday out of scrap and an old coil spring. I didn't plan too much and just started cutting and welding. He's inside now but he'll be an outside dog.
    jubei, soggyBottom, Vmax88 and 6 others like this.
  5. Apr 11, 2024 at 10:43 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Ha, that's awesome!
    Mine got rehomed a few weeks ago
    soundman98, wilcam47 and Drainbung like this.
  6. Apr 11, 2024 at 12:58 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    My wife wanted the baby monitor installed just off and above the crib, but didn't want holes in the wall or the crib, so I made a mount:
    Complete with foam bits on the bearing surfaces so it doesn't mark the crib.
    I was told this was overkill and took too long... To which I responded that my alternative was to model it have it 3d printed (from a print service), which would have taken longer. :notsure:
    jubei, soundman98, mjbtaco and 5 others like this.
  7. Apr 11, 2024 at 1:01 PM
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    You should ziptie the cord up out of the way, so the baby can't grab it and pull it out.
  8. Apr 11, 2024 at 1:03 PM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    Cable management and a 1/4" neoprene wrap on the mount are in the works :thumbsup:
  9. Apr 11, 2024 at 1:12 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Ours used only 1 screw so why not
    wilcam47 likes this.
  10. Apr 11, 2024 at 1:17 PM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    :notsure: I don't know, but I got to go play with my tools rather than change diapers, so I was happy to not make holes in things :rofl:
  11. Apr 11, 2024 at 1:23 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Sounds like you're not pulling your weight :luvya:
    Speaking of, kid and I just got back from Target
    koditten and wilcam47 like this.
  12. Apr 11, 2024 at 1:33 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Real talk though, looks good!
    Good thing babies aren't judgemental :rofl: jk
  13. Apr 11, 2024 at 1:47 PM
    spencermarkd
    spencermarkd Well-Known Member
    Spencer
    07 Driftwood Pearl 4Runner
    Pottery barn crib? I think we have the same one :rofl:
    I need to move our monitor though and this is good inspiration for a mount, thanks. We rent (ugh) and get charged per hole in the wall on move-out.
  14. Apr 11, 2024 at 1:57 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    The plastic cablesleeves are great for hiding cables, they have 3M double sided tape (foam) so it sticks to the wall nice and tight
    Came with the camera but they're available everywhere
  15. Apr 11, 2024 at 2:03 PM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    Pretty sure it's pottery barn :notsure: My only suggestion would be to make the "mast" higher than I did by ~2"...
    Just mocked it up with card board first, and then cut the pieces from 16ga bar stock, 3/16" for the mast to match the gap in the plastic monitor mount. The mount strap, I cut V shaped wedges with the cut off wheel, folded them over and only had to weld the cut side. Really only took 2 hours from start to finish, plus whatever time for the paint to dry. The mount is as wide as the space between the rails so fingers wouldn't fit between the mount and rails.
    Drainbung likes this.
  16. Apr 12, 2024 at 2:26 PM
    mjbtaco
    mjbtaco low and slow
    Michael
    Montclair , so cal
    Turbo'd 95.5 extra cab and 2013 Silver DCSB TRD Sport
    PERFORMANCE Custom Turbo Setup FRONT SUSPENSION Drop Spindles by Aaron Carswell 01-04 Swaybar Endlinks Energy Suspension Endlink Bushings Cando Upper Control arms QA1 coilovers with 8" spring Custom 4 pot Brembo BBK Modified lower control arms with mjbfab qa1 mounting plates and Poly bushing sleeves REAR SUSPENSION Chasis Tech drop leafs QA1 adjustable shocks weld in drop notch Gas tank cross member bridge 3" angled blocks 2013 Double Cab Short Bed TRD Sport Eibach Pro Truck Shocks front and rear Lifted to the 3rd setting on the front shocks
    Made another shoe rack for my brother. He swapped out my motor mounts and I made this in exchange for the work.
  17. Apr 12, 2024 at 3:54 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Less than 5 months ago, water table was completely cleaned
    This is all the crud just between a few slats now
    Nice to finally touch the bottom of the water table but holy shit there's so much crud :rofl:
    Still have 2/3 left to clean :bananadead:
    koditten, wilcam47 and 308savage like this.
  18. Apr 12, 2024 at 5:24 PM
    soggyBottom
    Usually ships in 2 to 3 weeks
  19. Apr 12, 2024 at 5:59 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Dino #4 in less than a week
    Dino #5 gets cut tomorrow while this one gets cleaned up and packaged
    Drainbung, koditten and wilcam47 like this.
  20. Apr 12, 2024 at 6:46 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Gonna have to start keeping things on the " down low". Don't want the tax man to come knocking.
    Lol.
    Drainbung and Kwikvette[QUOTED] like this.
