Anything welding
Discussion in 'Garage / Workshop' started by EL TACOROJO, Sep 17, 2010.
  1. Jun 22, 2024 at 3:24 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Oh trust me, some of the trucks y'all post in the "SHOULD I BUY THIS TRUCK?" and I about fall out of my chair :rofl:
    Then some mid-westerner comes on and says "she's fucking mint, go for it, hit it with some wool wax once a year and call her good"
  2. Jun 22, 2024 at 3:25 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    there's a growing list of compatible drums for that. eastwood was one of the originators of the tool, and has a nice backlog of alternative options for different uses
    https://www.amazon.com/stores/page/...e4516376536&store_ref=bl_ast_dp_brandLogo_sto
    i've got the same one, haven't really used it yet though.
    Drainbung, Pyrotech and Kwikvette like this.
  3. Jun 22, 2024 at 3:27 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    Been eyeing the Eastwood for years, then miraculously when HF came out with this one, Eastwood dropped their price significantly. Like so many hf things, turns out half of the parts between the two are interchangable.
  4. Jun 22, 2024 at 3:30 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Cause Harbor Freight is hooking up with the supplier itself (and benefits the poors like myself)
    I mean look at the many things shared between them, Eastwood, and other companies
    The little welding table is a great example of that since Klutch has their version, Eastwood, and HF as well
    Same goes for a bunch of other things
    Drainbung and soundman98 like this.
  5. Jun 22, 2024 at 4:12 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    There are entire forums/groups dedicated to "upgrading" HF tools with parts from other brands. Essentially turning your HF power tool into a bigger name brand for less than the cost of that tool. I'd love to see the factory where they're all made on one assembly line and then at the end split off to different paint booths :rofl:
  6. Jun 22, 2024 at 4:14 PM
    Pyrotech
    Pyrotech Well-Known Member
    been looking at one myself, seeing the expanded drum options from Eastwood is making this a much more likely purchase in the near future
    Drainbung likes this.
  7. Jun 22, 2024 at 4:14 PM
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    It’s all made in China anyway!
    Drainbung, OldSchlPunk and Kwikvette like this.
  8. Jun 22, 2024 at 4:32 PM
    soundman98
    NW Indiana
    there's even more off-brand options of drums on Amazon as well. there's also off-brand tools as well, including angle grinder adapters-- pre-adapted complete units, and the adapter kit.
    there's plenty of popularity around the tool design, so it seems there's a lot of development of new options for it. the twisted wire wheel drum is next on my list. and not listed on eastwood's amazon page are their narrow-width options for it.
    https://www.eastwood.com/eastwood-contour-sct-narrow-wheel-spacer-set.html
    https://www.eastwood.com/eastwood-contour-sct-narrow-scale-stripping-wheel.html
    https://www.eastwood.com/eastwood-contour-sct-narrow-finishing-wheel-80-grit.html
    the big thing is that it's designed for large flat surface prep-- like that saw blade. my project right now is the c-channel for the trailer. i could use the tool for the back side, but the inside part of the channel i need a normal angle grinder/wire wheel anyways. and being that i've already got the wire wheel loaded up, i just keep using it on the flat side as well...
    one of the finish guys at work uses one to finish off stainless steel to give it a uniform finish, not all that different than how they do bodywork on deloreans.
    Drainbung and Pyrotech[QUOTED] like this.
  9. Jun 23, 2024 at 9:08 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Aside from one sign another member made, it's been quiet in here!
    Drainbung and koditten like this.
  10. Jun 23, 2024 at 9:30 AM
    soundman98
    NW Indiana
    too hot to be in the garage!
    95 degree air temp means it's 110 degrees minimum in the garage.
    Pyrotech, Drainbung and koditten like this.
  11. Jun 23, 2024 at 9:33 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I got the same issue. I was gonna install a split system this year, but life got in the way.
    KRAMERICA, Pyrotech and Drainbung like this.
  12. Jun 23, 2024 at 9:40 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Gonna be 103 here :luvya:
  13. Jun 23, 2024 at 9:41 AM
    soundman98
    NW Indiana
    i'm just waiting for someone to hand me a winning lottery ticket.
    otherwise working 9 hrs a day 5 days a week in the heat, building and fabricating trucks, i'm not all that excited about doing the same things on the two days i have off.
    honestly, today is only supposed to be 80 degrees for a high, so i did consider going out, but cutting/welding/grinding takes a lot out of me, and will make an already long hot week feel even longer and hotter if i don't take a break from it on sunday--i can do it on saturday fine as long as i have sunday to reset for the upcoming week. but i've pushed hard to get projects done before over the weekend, and i usually end up with a far worse week from overworking myself, which is just not worth it for a self-funded project.
    my trailer build 'deadline' is entirely within my head, so i'm extending it. the benefits of controlling the little part of my schedule i can actually control.
    4th of july weekend i'll have a 4-day weekend. i'll likely make some time up then instead.
    Kwikvette and Drainbung like this.
  14. Jun 23, 2024 at 9:52 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Full time job puts a stop to a lot of things for sure
    soundman98[QUOTED] and Drainbung like this.
  15. Jun 23, 2024 at 10:00 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Although I kind of wish I had a project going on right now as I do that sort of work in the mornings
    It's hot in the shop and I'm running a clay bar to my rig :anonymous:
    soundman98 and Drainbung like this.
  16. Jun 23, 2024 at 10:10 AM
    Caboose117
    Caboose117 foul mouthed Marine
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    smashed this, broke that, covered it up with tape and paint
  17. Jun 23, 2024 at 10:14 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
  18. Jun 23, 2024 at 10:23 AM
    Caboose117
    Chad
    Kentucky
    ;IGY6 Rescue Truck
    I want one
    Of both
    Cause hot tortillas for home made breakfast burritos is the best
    :anonymous:
    My mom asked me to get her a set for her black stone :bananadead:
    Kwikvette[QUOTED] and Drainbung like this.
  19. Jun 23, 2024 at 11:02 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    But tortillas, you use your hands :luvya:
  20. Jun 23, 2024 at 11:49 AM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    Yes, was warm in the shop yesterday. Worked on cutting out parts for a custom front bumper base (winch mount with adapters for Roadmaster direct connect tow arms.)
    Shaitty video skillz but that's all I have for now. Will work on it again next weekend.
    Obviously I haven't added the 90' bend for the fairlead.
    soundman98, Kwikvette and Drainbung like this.
