Anything welding
Discussion in 'Garage / Workshop' started by EL TACOROJO, Sep 17, 2010.
  1. Jun 25, 2024 at 11:24 AM
    Pyrotech
    Pyrotech Well-Known Member
    The pins to hold the die are very tight. Even after polishing the bore and pin they are still extremely hard to remove.
    The antikickback pin is supposed to automatically set. But it has turned on me twice first time breaking an second time bending the top frame plate.
    After getting sent the wrong die. When i first ordered everything an being told to bad no refunds all sales final, And this die was for a different bender. The poor customer service on the previous two issues has really deterred me from being able to recommend them.
    soundman98 and Kwikvette like this.
  2. Jun 25, 2024 at 8:22 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Cut and bent
    Drainbung and wilcam47 like this.
  3. Jun 26, 2024 at 6:28 AM
    Zebinator
    Zebinator Well-Known Member
    Norcal
    06 Tacoma TRD Offroad
    Wait - “axle truss” - what??? Must investigate!
  4. Jun 26, 2024 at 6:44 AM
    Btwenzel
    Btwenzel New Member
    2023 TRD Off Road white black out
    Welded this up yesterday.
  5. Jun 26, 2024 at 7:08 AM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    chopped the back of my truck off to 4-link it. needed to reinforce the axle while at the same time putting link mounts in the right locations. tube truss is what i came up with.
  6. Jun 26, 2024 at 4:49 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    what, no rear steer?
    colinb17[QUOTED] and Drainbung like this.
  7. Jun 26, 2024 at 6:23 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Bought a lot of parts for this build from TMR Customs. Incredible company with top notch stuff. They put rear steer on their KOH truck this year......it broke. If they can't do it, I certainly can't.
    soundman98[QUOTED] and Drainbung like this.
  8. Jun 27, 2024 at 1:40 PM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    We've been spending more time on the dock at the lake than in the boat (boat is too small for two adults, a newborn, and a 80lb lab), and the wife wanted more shade for the newborn. So I picked up a cantilever umbrella and made an attachment plate so we didn't have to a heavy base.
    1/4" x 5" plate (wayyyyyyy overkill):
    Sorry, didn't have time to take pics of the bare welds. No grinding or clean on required on them though...
    Installed with galvanized hardware.
    Now we gotta up our chair game :facepalm:
  9. Jun 27, 2024 at 7:40 PM
    TacoTuesday1
    SD CA
    want to know what y'all think of my plan to put rear mudflaps (semi truck)
    1. copy ATHfab bed supports. I have a pair. It does not work due to my WarFab HC (too high)
    2. use 3/16" steel flat bar of same width. Approx 2' long.
    3. Line up with plastic bed "ridge" / "rib", mark, drill holes
    4. bolt to "rib"
    5. with flat bars sticking out (just like the ATHfab support), connect mud flaps to them. Trim as needed
    6. figure out dimensions. Apparently there's 100 different guidelines that none agree with eachother
    7. find a spot on WarFab bumper to hang a chain
    8. get MORE steel flat bar (try to find cheap), make plates at bottom of mudflaps
    9. using chain and hook, pull mud flaps from bottom steel plate so they're angled 45deg to kick rocks down, not up, like in AUS
    either re-use the stock 2 rivnuts, cut them put new ones
    or use rearward rib drill new holes
    however, more front may look better
    and allow to stick out wider at bumper, due to WarFab bumper narrowing as it goes rearward
    TL:DR; mount rear mud flaps using steel bar bolted to plastic bed
    KRAMERICA likes this.
  10. Jun 28, 2024 at 11:32 AM
    soggyBottom
    soggyBottom Well-Known Member
    I need some tie downs. This is what I came up with. I'm thinking I'll replace the washer with this. Total load would be less than 100lbs per mount. Thoughts/advice?
  11. Jun 28, 2024 at 11:41 AM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    Looks nice. Those crisp corners look great but I don't think they'll help you.. I'd consider radiusing them. The hole appears small-ish.. is it made for a specific fastener? (I ask as my tie down hooks wouldn't fit in the current size from what I can tell.)
  12. Jun 28, 2024 at 2:18 PM
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    Diddo on what Gen3 said. I think I'd double the size of the hole. You don't need that much metal to hold 100# and you don't want to fight to get a hook through.
  13. Jun 28, 2024 at 3:52 PM
    mjbtaco
    mjbtaco low and slow
    Michael
    Montclair , so cal
    Turbo'd 95.5 extra cab and 2013 Silver DCSB TRD Sport
    PERFORMANCE Custom Turbo Setup FRONT SUSPENSION Drop Spindles by Aaron Carswell 01-04 Swaybar Endlinks Energy Suspension Endlink Bushings Cando Upper Control arms QA1 coilovers with 8" spring Custom 4 pot Brembo BBK Modified lower control arms with mjbfab qa1 mounting plates and Poly bushing sleeves REAR SUSPENSION Chasis Tech drop leafs QA1 adjustable shocks weld in drop notch Gas tank cross member bridge 3" angled blocks 2013 Double Cab Short Bed TRD Sport Eibach Pro Truck Shocks front and rear Lifted to the 3rd setting on the front shocks
    This is the move for my non water cooled torch setup. My hand was getting extra toasty on longer runs, now I barely even felt any heat at all. Kevlar gloves under the leather ones.
    And the blocks I welded up.
  14. Jun 28, 2024 at 3:53 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Still feel like you have good filler control? I've been doing some work recently that cooked my fingertips off.
    Drainbung likes this.
  15. Jun 28, 2024 at 3:54 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    That's a common thing though?
  16. Jun 28, 2024 at 4:02 PM
    mjbtaco
    Michael
    Montclair , so cal
    I have no idea lol they were on sale so figured I'd give it a shot. Don't see too many people talking about gloves very often.
  17. Jun 28, 2024 at 4:03 PM
    mjbtaco
    Michael
    Montclair , so cal
    Yeah still had good dexterity. Both gloves are very soft and pliable.
    colinb17[QUOTED] likes this.
  18. Jun 28, 2024 at 4:11 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    No I mean, I've heard of that a lot as in...it's been common around people I've worked with
    When I was TIG welding at my last job, most of the guys did away with the pinky/bottom of the palm wrap in lieu of gloves underneath so it's what I did
    Only to hear it from a few other people elsewhere
    In other words, it works!
  19. Jun 28, 2024 at 4:19 PM
    mjbtaco
    Michael
    Montclair , so cal
    Yeah it definitely works. I just work alone in my garage so I had no one to show me lol I just gave it a shot and it worked. Cool to hear others are doing it too.
    Kwikvette[QUOTED] likes this.
  20. Jun 28, 2024 at 5:40 PM
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    https://weldmongerstore.com/pages/weldmonger-tig-finger
    The tig finger worked for me.
