Anything welding
Discussion in 'Garage / Workshop' started by EL TACOROJO, Sep 17, 2010.
  1. Jun 28, 2024 at 5:48 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    I have one of those. Works great for it's intended purpose, but if you're running high enough amperage for long enough on a non water cooled torch, the torch itself will cook your hand. Tig finger does well for your hand resting on a hot workpiece, or the radiant heat off of the arc.
    soundman98, mjbtaco and koditten like this.
  2. Jun 28, 2024 at 5:58 PM
    mjbtaco
    mjbtaco low and slow
    Michael
    Montclair , so cal
    Turbo'd 95.5 extra cab and 2013 Silver DCSB TRD Sport
    PERFORMANCE Custom Turbo Setup FRONT SUSPENSION Drop Spindles by Aaron Carswell 01-04 Swaybar Endlinks Energy Suspension Endlink Bushings Cando Upper Control arms QA1 coilovers with 8" spring Custom 4 pot Brembo BBK Modified lower control arms with mjbfab qa1 mounting plates and Poly bushing sleeves REAR SUSPENSION Chasis Tech drop leafs QA1 adjustable shocks weld in drop notch Gas tank cross member bridge 3" angled blocks 2013 Double Cab Short Bed TRD Sport Eibach Pro Truck Shocks front and rear Lifted to the 3rd setting on the front shocks
    Yeah I have one of those.
    Nailed it! This is exactly why I was looking for a different option.
    colinb17[QUOTED] likes this.
  3. Jun 29, 2024 at 10:05 AM
    soggyBottom
    soggyBottom Well-Known Member
    Ta-da
    Yeah larger hole was better. I opened it up from 10mm to 16mm. There is probably enough space for 20 or so without remaking the bracket.
    I have some small straps that fit just fine.
  4. Jun 29, 2024 at 10:32 AM
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    That looks good.
    There's enough room left on the base you could weld some of these folding rings to the other side for additional tie downs.
    https://www.amazon.com/dp/B09G68DFM9
  5. Jun 29, 2024 at 10:49 AM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    thursday was a perfect 70 degree high. naturally, started making plans for working outside. today finally rolls around, and it's 87 with 100% humidity. real-feel is 102 degrees, in the open air, likely 110-115 in the garage, even with the fans going. not fun.
    i assembled my second axle, then called it quits. not worth it.
    Drainbung likes this.
  6. Jun 29, 2024 at 4:15 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Humidity :puke:
    It's dry out here
    Friends came by to stay at our house for the weekend, and one thing I was going to do is make a duplicate CAT skid for a 2nd Gen Taco
    Aside from the corners having a different size radius, everything else matches
    Opted to just drill the holes for the wings rather than plasma cut them since we deviated slightly from the original design
  7. Jun 30, 2024 at 6:41 PM
    soundman98
    NW Indiana
    i made a mess.
    got my two mistakes of main frame rails cleaned up, primed, and set to the side. yes, they're that crooked.
    the primer is really just so i don't need to sand blast them later. i can weld through it, touch up as needed, and it's still rust-proof enough to handle the weekends until i can raptor-line the completed assembly.
    and my front a-frame setup is bent as it needs to be, and 90% prepped as well. i wanted to install a cross beam to tie the two wider arms together, but decided to leave that until after i got the main trailer section done.
    koditten likes this.
  8. Jun 30, 2024 at 6:45 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Bwahahaha!
    I thought I was the only one with an elliptical in my shop!
  9. Jun 30, 2024 at 7:19 PM
    soundman98
    NW Indiana
    i was actually saving that from a scrap run, as the arms all have really nice bearings, and had thought about using it for a panhard bar. unfortunately, i only got one arm out of the deal, so not enough parts.
    the original plan had been to make my own panhard bar(was roughly following this build for it's simplicity), but i'm now starting to think of going with a flat triangulated 4-link setup, where the airbags are on the outer links, and the inner links would form a 'V' to the center of the axle.
  10. Jun 30, 2024 at 7:27 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    The rust :puke:
    soundman98 likes this.
  11. Jun 30, 2024 at 7:43 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Dirty, contaminated aluminum can be tricky
    Had to bevel it pretty well to get some metal in there
  12. Jul 2, 2024 at 1:38 PM
    koditten
    Kirk
    Central Michigan
    Made some progress on the tundra bumper.20240702_144458.jpg 20240702_144919.jpg
  13. Jul 5, 2024 at 9:52 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Been a little slow in the shop, on account that I've been doing most of my paid work via PC lately
    Decided to run a test with my easyscriber mainly cause I forgot how to use it :rofl:
    I had done this months back as some of you may remember, a little 3.5" x 2" card
    With extra scrap on the table, I thought I'd see what it looks like at a smaller scale, 2.4" x 1.5"
    Thinking I'll make an actual business card for myself seeing as how it can really create some fine details
  14. Jul 5, 2024 at 4:17 PM
    soundman98
    NW Indiana
    and progress was made.
    main goal today was just to get square tubing for the suspension arms. got the front panel 50% welded in, both axle locations marked, linkage lengths set up, and decking supports all cut out. i'm hoping i can use the supports to push/pull the frame rails straight without too much cutting and bending...
  15. Jul 7, 2024 at 6:29 AM
    soundman98
    NW Indiana
    far too much work for a saturday.
    ran out of welding gas 6 passes short of where i needed it to be. ended up finishing the tailboard with flux core, not at all fun.
  16. Jul 7, 2024 at 7:47 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Frame is looking good, but definitely buy more bottles!
  17. Jul 7, 2024 at 7:53 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    For each 150cf bottle of gas I have, I also keep an 80 that I just toss in the back corner of my garage and forget about. If I ever run out of gas after business hours on a Friday or over the weekend, the 80 is enough to get me through the weekend.
    Cost and storage space are very minimal for two 80cf bottle. One of argon and C25.
    KRAMERICA and Kwikvette like this.
  18. Jul 7, 2024 at 7:56 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I need another 80cf for such an occasion
    I only have 150cf bottles and they take up wall space they're leaning against cause I hang shit on the walls too :bananadead:
  19. Jul 7, 2024 at 8:03 AM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Yeah, bottle storage is tough no matter the size of the shop space you're working with. I found that when I TIG, 90% of the time I'm sitting at my welding table, so I just tucked the argon bottle in a corner where it wasn't in the way and ran a 40' hose with a quick release at the machine. I MIG all over the place though, so a decent welding card that that the C25 bottle can live on and roll around with was best for that scenario
    soundman98 and Kwikvette[QUOTED] like this.
  20. Jul 7, 2024 at 8:09 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Yeah
    One bottle sits on my cart of my MIG welder, non-issue
    And the only 80cf I have is argon, sitting on a mini cart
    But the others well, yeah shop space is smaaaaaaaaall here :bananadead:
    Don't even TIG much either, comes in handy more for my spoolgun than anything
