Anything welding
Discussion in 'Garage / Workshop' started by EL TACOROJO, Sep 17, 2010.
  1. Aug 25, 2024 at 4:31 PM
    Pyrotech
    Pyrotech Well-Known Member
    Kwikvette[QUOTED] likes this.
  2. Aug 25, 2024 at 4:32 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Zebinator likes this.
  3. Aug 26, 2024 at 7:53 AM
    Zebinator
    Zebinator Well-Known Member
    Norcal
    06 Tacoma TRD Offroad
    Well, um, it is. lol. I thought once you got through all the issues you liked yours. No? The 4x4 STV is still pretty big for my space and a bit more pricey…. I sorta shot my wad on the brake. Ha ha.
  4. Aug 26, 2024 at 8:07 AM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    Gonna depend on a few things like thickness of material.. 1/4" pierces with less than ideal air and consumables can throw some sparks a handful of feet plus. You're going to eventually have an issue where sparks are thrown.
    Zebinator[QUOTED] likes this.
  5. Aug 26, 2024 at 8:15 AM
    Gen3TacomaOBX
    S
    If you have enough room for the Langmuir Crossfire XR (4x8') go for that one.. it's the newer/latest generation Langmuir CNC plasma offering and is major bang for the $$ ($7500). I'm very happy with mine.
    As for the smaller table offerings.. STV is a better drive system and a MUCH bigger price. $9500 vs $2800 o_O
  6. Aug 26, 2024 at 8:20 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Langmuir is a hobbyist table, and it reminds you of that all the time. This applies to all their tables.
    The STV is far better in terms of quality, movement, software, everything.
  7. Aug 26, 2024 at 8:24 AM
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 OR DCFB
    Fox and Locked suspension 63's Skinny 33's
    This is also coming from a guy with a langmuir table IIRC
  8. Aug 26, 2024 at 8:25 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    This.
  9. Aug 26, 2024 at 9:30 AM
    Zebinator
    Norcal
    Yeah- I think for my needs and where I am in this process hobbyist might be ok. I don’t know what I don’t know yet. And I just don’t have room for anything big! But I will also check out arc light!
    Drainbung likes this.
  10. Aug 26, 2024 at 9:42 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I shouldn't make any assumptions really, but if you're a hobbyist and bought a Titan 25T just because, then you'll appreciate a table that's better built and has significantly better movement than any table by Langmuir.
    Even their "top of the line" XR table uses many of the same components outside of their ballscrew setup. Same cheap control box components, same basic VIM, same everything else like the cheaper tables. There's a reason why Langmuir pops up a lot, it's the cheapest table on the market.
    Because I'm poor and have a small garage, I'll be looking into buying a modular STV table in a 4x4 setup. I plan to get the Optimum control box and gear reduction upgrades which, does put you within $1,000 from their Pro model, but the modular can be upgraded to a 4x8 at any point.
    The Pro is nice because it is fully welded and arrives to you practically assembled.
    A truck with a 2 car trailer will show up to drop it off if you get the Pro so you'll want a forklift to unload it. They're out of Las Vegas.
    Arclight would be a really nice option if you're ok spending a bit more.
  11. Aug 26, 2024 at 9:50 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    With that said, I can't comment on other tables since I'm unaware but a company like STV designed their entire gjg around Hypertherm plasma cutters.
    They're an authorized retailer for Hypertherm so it only makes sense that the tables are designed for said plasma cutters.
    It doesn't mean other brands won't work, they do, they just require more from the end-user to "play well together".
    For instance, only Hypertherm has published information such as voltages for maintaining torch height. They also have ohmic sensing if a table supports that instead of your standard touch off switch. My buddy fumbled too much trying to use his PrimeWeld plasma cutter with his STV and finally opted for a Sync65.
    So I'd look at groups/forums to see if any one table favors a specific plasma cutter or not. If they do, it's either their own (like Go Fab or something) that the company offers, or a Hypertherm.
    Drainbung and Zebinator like this.
  12. Aug 26, 2024 at 12:30 PM
    Zebinator
    Norcal
    Yeah I have some research and shop reorganizing to do to make this work, whatever path I take. But it seems the quality of the parts you’re getting off your Langmuir are pretty good! Good enough for my one-offs!
    Drainbung and OldSchlPunk like this.
  13. Aug 26, 2024 at 1:03 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Dollar for dollar, for a value priced setup, I can recommend the Crossfire Pro any day of the week.
    The non-Pro is too small and you'll easily outgrow it, like I did. And the XR is priced too close to better table options to be recommended, which makes it a bad buy for me.
    But nothing comes close to the size and features of the Crossfire Pro and it handles mostly everything I do.
    Zebinator[QUOTED] and Drainbung like this.
  14. Aug 26, 2024 at 3:42 PM
    Zebinator
    Norcal
    This! The similar sized STV is almost I think two grand more… it’s foot print is a little smaller, which is nice but… Might be a lot for what I need!
  15. Aug 26, 2024 at 4:00 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Glad that helps.
    I don't mind saying something negative about a specific product I have experience with, regardless of the brand (whether I like it or not).
    The XR just doesn't give you much more for the money, and the non-Pro is too limited being priced so close to the Pro.
    I guess I'll be sharing my thoughts here in the next few months comparing the PrimeWeld I've had for 2.5 years with the Hypertherm I just picked up.
    Just need a machine torch but that fucker's like $800+ :violent:
  16. Aug 27, 2024 at 1:35 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    Is there any preference for wire diameter size for a 110v for 1/8" or so
  17. Aug 27, 2024 at 2:01 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I use .035 for everything, whether 16 gauge or 3/16", on 110 or 220
    You'll want to run it hot though and watch your duty cycle, but ultimately it comes down to you running some beads to dial it in
    koditten likes this.
  18. Aug 27, 2024 at 2:04 PM
    MonkeyProof
    SoCal- SGV
    Right on! I started practicing with .035 but man were the beads really wide. Ran out of that spool then I tried .030 and thought I had a better bead. I guess it all comes down to practice and time behind the gun.
  19. Aug 27, 2024 at 2:26 PM
    EubeenHadd
    EubeenHadd Bit of a derp
    Nick
    Indianapolis
    2005 T4R 4.7 AWD
    Encounter AT 32", OME 90021/885+63005/895
  20. Aug 27, 2024 at 2:28 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Going through that site is nauseating and the pictures not showing fully sucks. Sorry, not going to browse through it.
    What exactly scares you?
    Where did the OP mess up?
    soundman98 likes this.
