Anything welding
Discussion in 'Garage / Workshop' started by EL TACOROJO, Sep 17, 2010.
  1. Nov 17, 2024 at 5:30 PM
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 OR DCFB
    Fox and Locked suspension 63's Skinny 33's
    So I am far from a pro but I just have different cheater bends that I make and use as a reference where to start and where bends will end.
    On these cheaters you mark every inch and then you can see how much tube a bend will take up and just go from there. There is also a mark of where to put the collar for the tube on there and how much spring back I get for each angle
    MagicToolbox and soundman98 like this.
  2. Nov 17, 2024 at 5:35 PM
    Watermallon
    Watermallon ID Tacooo
    Zach
    Idaho
    2006 TRD Sport
    I’m decent when it comes to arc length and the amount of material used in a specific bend. My question is more so when you have multiple bends in a piece where you’re visually seeing where you want your bends to be, how do you measure where all the bends are. This is really hard to explain, I need to draw lol
  3. Nov 17, 2024 at 5:39 PM
    spencermarkd
    spencermarkd Well-Known Member
    Spencer
    07 Driftwood Pearl 4Runner
    I think I get what you're asking. Don't they normally measure to the start of the collar/shoe/die? Or to a specific spot on the mandrel or bender? Like, side a was 10" to the clamp, side b needs to be 10" to the clamp and do things to the start of the bend. If it's the same diameter material and same bend angle, the result will be the same at the end of the bend, make it easy and measure from where it's still straight y'know.
  4. Nov 17, 2024 at 5:46 PM
    TacoTuesday603
    Jack
    New Hampshire
    2011 OR DCFB
    I hold up the cheater and measure where the bend should be. I’ve found tubework is a lot more eyeballing than anything. For example getting all the bends on the same plane, my front bumper has 4 of them, the only real way is to sight down the tube
  5. Nov 17, 2024 at 5:56 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    Below is an old post I made in the LT thread, which also pulls some stuff from my build thread. Much of it will be stuff you already know it sounds like, but there's a bit on visualizing bends in there. Specifically the part about using a flexible exhaust tube.
    Once you have your specific bender figured out, you can do all of it on paper before you even go into the garage. Hope this helps at least a little.
  6. Nov 17, 2024 at 6:03 PM
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    There doesn't have to be any guesswork or eyeballing in getting bends in the same plane. I have a handful of these in various sizes, but this specific one is all you need when you're talking roll cage/bumper sized tubing
    https://www.amazon.com/dp/B0CNRRY6ZV
    For tubes with multiple bends, I lock the tube in place in the bender, set up to make the first bend. Then I use this tool to punch 0 degrees every foot or two. Then when it's time for the second, third, fourth bend etc. the center punch sits perfectly in the bunch mark and allows you to finely adjust the tube to the same plane as the first bend. You can also spin the dial on the tool so that you know exactly how far to clock the tub in the bender for off-axis bends.
    The main hoop of my back half has 5 bends all in the same plane. This tool allowed me to nail it first try without any stress.
    not_nick and soundman98 like this.
  7. Nov 17, 2024 at 6:40 PM
    Topanga Taco
    Topanga Taco BUZZING NITRO
    Rick
    Topanga Strong Southern California
    2018 SR5 4x4 DCSB Harrop rear E-Locker
    The Magic of ALSD RCI-skid RAS-Sumos Bilstein 6112/5100
    Digging these magnets a whole bunch. They are strong enough to hold pieces in place for grinding and welding. Real good stuff.
    fatfurious2 and koditten like this.
  8. Nov 17, 2024 at 8:31 PM
    Pyrotech
    Pyrotech Well-Known Member
    Draw it out 1:1 scale on the garage floor an use that along with the cheater pipe to help. Also make sure the tube an bender.stay on the same plane when bending a center line mark on the tube helps along.with a digital angle finder. Zero it out on the bender frame then rotate the tube to match the 0 mark
    The fabrication series on youtube has some really good tube bending videos an i watched them alot when making my bed rack.
    Watermallon[QUOTED] likes this.
  9. Nov 18, 2024 at 7:06 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Hey guys, Ive been thinking more and more about getting into Tig. Ive been trying to figure out what I want to weld as well, and narrowed things down to aluminum and stainless, minimal mild steel. Based on that, Ive also been researching welders, and kind of narrowed my thoughts to an Everlast PowerTig 200DV or a PrimeWeld Tig225X. I definitely want a pedal too. Does anyone have any experience or thoughts on these?
    I have a Hobart 140 mig already, along with a 30A fuse and a 110 plug, but it could be changed to a 220 if really needed. Im going to be teaching myself too. My neighbor used to be a welder, and I have another friend who builds custom motorcycles that I can bounce ideas off of too. But both of them have Millers, which is way out of my price range for now.
    Topanga Taco likes this.
  10. Nov 18, 2024 at 7:20 AM
    Topanga Taco
    Rick
    @fatfurious2, I have experience with the Everlast 200 DV, very nice Analog inverter machine. But kinda loud, as the fan was always on. I’m not familiar with the Primeweld.
    I know people will make fun of the Eastwood TIG 200, square wave inverter, but that machine can weld very very well. Not that loud, just doesn’t have a lot of bells and whistles. Very basic, no pulse. I have this machine in my garage.
    I just recently picked up a CK Worldwide MT200 for my saw shop, and the square wave inverter is the kind. It has fan on demand. The machine is quiet most of the time. Half the cost of a HTP. Check IOS for best pricing. And wait for Black Friday to pull the trigger!!
    soundman98 and fatfurious2 like this.
  11. Nov 18, 2024 at 7:25 AM
    Topanga Taco
    Rick
  12. Nov 18, 2024 at 7:31 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
  13. Nov 18, 2024 at 7:33 AM
    fatfurious2
    David
    Ashburn, VA
    I think the price is a little out of my range right now. Based on the other 2 I mentioned, I think my range is $1100 and below. It does look like a nice machine.
    I will also admit I am not up to speed on the meanings/uses of square wave inverters, etc. The loudness doesnt bother me as much.
  14. Nov 18, 2024 at 7:38 AM
    Topanga Taco
    Rick
    That’s what I thought too. But you truly get what you pay for. I’d put it in the cart and “think about it.” IOS is good at sending emails with a “what if we were to give you another…off.”
    If you’re at all worried about finances, buy the Eastwood and don’t look back.
    fatfurious2 likes this.
  15. Nov 18, 2024 at 7:42 AM
    Topanga Taco
    Rick
    Striking an arc on a CK Worldwide is like striking gold. Very nice stability.
    Either way, good luck fellas for TIG Friday:hattip:, the possibilities are endless with a TIG torch.
  16. Nov 18, 2024 at 7:47 AM
    TacoTuesday603
    Jack
    New Hampshire
    2011 OR DCFB
    I do not have this welder but when I get a TIG machine it will be a PW tig 225X. They have impressed me with customer service and pushing my MIG 180 more than I probably should have. Reviews seem great and has all the features I could want.
    Again I dont have any personal experience with the 225 but I am in a similar spot as you are.
  17. Nov 18, 2024 at 7:53 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Having owned (and learned on) a 225X I can't recommend PrimeWeld enough.
    Then again a lot of other members here will tell you I recommend just about anything that comes from PrimeWeld.
    And yes, I've used machines like a Miller Dynasty in the trade.
    Drainbung and fatfurious2 like this.
  18. Nov 18, 2024 at 8:01 AM
    Topanga Taco
    Rick
    And fellas, just to get ya’ll fired up. For those with a 3rd Gen, you can fab the aluminum crossover coolant pipe with a TIG torch handy with no warping.
    Just saying :alien: would be perfect for someone looking to make a living here at TW…BOOM!)
    soundman98 and koditten like this.
  19. Nov 18, 2024 at 8:08 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Not sure the intent behind the statement, but for those not familiar with TIG (that are watching/reading), any AC/DC TIG welder is capable of welding aluminum.
    No "firing anyone up" just a matter of a machine's ability.
  20. Nov 18, 2024 at 8:10 AM
    Topanga Taco
    Rick
    Intent? Trying to help someone who is in need was the intent. I let my portfolio take care of me now a days…
    Aluminum or magnesium, along with a lathe or mill, job done.
    EDIT: Forgot the propane torch to preheat.
