Anything welding
Discussion in 'Garage / Workshop' started by EL TACOROJO, Sep 17, 2010.
  1. Nov 30, 2024 at 4:44 PM
    Topanga Taco
    Topanga Taco BUZZING NITRO
    Rick
    Topanga Strong Southern California
    2018 SR5 4x4 DCSB Harrop rear E-Locker
    The Magic of ALSD RCI-skid RAS-Sumos Bilstein 6112/5100
    Ah man, Jody is the man to answer that question.
    I have read about alloys that require different fillers to complete to specs. I don’t recall the alloys, but that’s damn trick.
  2. Dec 1, 2024 at 8:09 AM
    Topanga Taco
    Rick
    I was brain storming your idea, and thought of McMaster Carr. A clevis pin would be a good choice? Or modify a hitch pin to be able to lock in place.
  3. Dec 1, 2024 at 9:15 AM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    honestly, i avoid mcmaster. because it always leads me down rabbit holes far larger than my wallet. i'm never working on only one project, which means that once i find an oddball solution to one problem, i start trying to solve other pending problems, and suddenly i've got a cart with $9,000 of hardware in it. same with digikey. seems i can't leave either of those sites for less than $500.
    for instance, i also just picked up a 10 pound welding spool--because i'm blowing through 2 pound spools far too fast right now, and am brainstorming ideas for a mounting system on my welding cart, and adapting my current welder to accept it. it's a mount that needs to introduce a variable amount of friction to prevent the spool from bird-nesting, but also pull near-effortlessly-smooth because i don't think my welder wire feed has the balls for a spool that size... the simple/obvious answer here is to upgrade my welder, but that has some non-obvious downsides in terms of re-wiring the entire garage, which is a hiccup away from just building a new garage, and project scope creep on a new garage project means i need bezos kind of money to see it all through...
    and i've also got one of the mini-tool boxes right next to it-- being that harbor freights roller-bearing-equipped drawers are unobtanium, as well as don't even offer a lower 4-drawer unit, it's on my project list to start digging into finding full-extension drawer slides that i can adapt to the mini tool box space constraints. i want a nice one for use at work for all the knick-knacks i've got taking up an entire toolbox drawer that would be better served holding real tools.
    there's still plenty of improvement possible in the new hand truck design, but the major improvement point is that the pins aren't a primary structural component anymore as they were with the original iteration, and the steel additions carry about 75% of the load, with the pins themselves carrying the last bit of the load, but only in specific side-loading and twisting orientations. the steel additions limit how much sheer load is placed onto the pins, so given the pins are 5/16", it should work decently. and it used scraps and pins i had laying around, instead of buying additional stuff (pins were a bulk purchase from B&G discount, part of an idea for removable trailer fenders that aren't looking as workable as i thought).
    the difficulty in it is that i still use the hand truck as a hand truck, and am unwilling to modify it to making a dedicated trailer dolly
    the hitch pin/clevis might need to be worked in later on if these pins start bending--indicating my figuring on load carrying are incorrect, but i'm really hoping that's far enough down the road that i'll have time to build the power jack unit by that time, and it'll work better. the larger goal here is that i'm eventually planning on a towable camper purchase, and i'll need a 'yard dog' for that unit as well. but i'm also starting to consider a 4x4 ATV for screwing around, yard dog, and snow plowing...
  4. Dec 1, 2024 at 9:35 AM
    Topanga Taco
    Rick
    Get the clevis pins at your local hardware store.
    I use McMaster’s site to quickly find what I need. Well thought out.
    soundman98[QUOTED] and Zebinator like this.
  5. Dec 1, 2024 at 10:06 AM
    Zebinator
    Zebinator Well-Known Member
    Norcal
    06 Tacoma TRD Offroad
    They have the world’s best catalog and site. I miss using their book!
  6. Dec 1, 2024 at 10:16 AM
    Topanga Taco
    Rick
    Hear hear, we just had ours re-wired, but thankfully we finally did it. The homeowners before us didn’t wire it correctly. Sketchy garage, never cared for it. Now I’m ready to improve it. I now have a 240v outlet for the Eastwood TIG200, however, that leads me to have to change the 240v breaker in the rear near my saw shop. That has 2-30 amp breakers which helped power the Eastwood machine. Now with the CK Worldwide MT200, I was told it draws 38 amps, so CKW recommends a 50 amp breaker.
    Thankfully the plug is near the box. So I have to open it and find out what gauge wire leads to the 240v outlet. I’m not an electrician, so I might have to get the Moreno’s who wired the garage back here.
    OnHartung'sRoad and Drainbung like this.
  7. Dec 1, 2024 at 10:28 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    I charge my lithiums on it in case one pops- I tested it out on the stove with high flame and it worked without doing anything except turning red underneath. I don’t know how well it weathers though.
    Drainbung likes this.
  8. Dec 1, 2024 at 11:22 AM
    Pyrotech
    Pyrotech Well-Known Member
    did they stop sending out the catalogs completely? last I knew you had to order multi thousand dollars a year then the catalog would just show up. the last one I was gifted is #118
  9. Dec 1, 2024 at 3:20 PM
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    Why? You can search on their website via multiple parameters, plus they store all of your prior purchases so you never have to look for something twice.
    I dont miss JC whitney catalogues either.
    koditten likes this.
  10. Dec 1, 2024 at 5:07 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Can't use the website as a kid booster seat.
  11. Dec 1, 2024 at 6:12 PM
    soundman98
    NW Indiana
    I always preferred books, especially for the times where I know what I need, but everyone else in the industry calls it something else.
    Zebinator, Drainbung and koditten like this.
  12. Dec 3, 2024 at 10:09 AM
    Topanga Taco
    Rick
    6061 is today’s material to fab. This metal is bad ass:hattip:
  13. Dec 3, 2024 at 10:19 AM
    Topanga Taco
    Rick
    I forgot to mention what I like the most about McMaster-Carr, and that is what seems like an infinite amount of choices for drill bit sizes. Bits you won’t find at your local hardware store EVER that will make or break your game. I used them quite a bit when I was building saws.
    soundman98 and Zebinator like this.
  14. Dec 3, 2024 at 12:05 PM
    Zebinator
    Norcal
    Oh, I love their website, and their app, but sometimes it is just fun to flip pages and see all the stuff you never knew existed! +1 on the booster. McMaster's secret is they almost never offer two of the exact same product. The only place I find brand-names is in the adhesive section.
    Funny: having the catalog was such a thing, folks would write their name across the pages so folks wouldn't steal 'em. But then someone discovered the unknown utility of the disk sander. Then we all had to start putting our name on our 'secret page.' lol!
  15. Dec 3, 2024 at 12:06 PM
    KRAMERICA
    KRAMERICA Old Man Mike
    Middle Tenn
    '18 F250 Super Duty
    A couple of rear window decals...
    McMaster-Carr are great about having just the right size thingamajig you need. What I don't like are there shipping costs. Order a pack of 1/4" roll pins. Probably weights 1/3oz, will fit in a small envelope, and cost less than a $1 to mail to you. It might cost you a $1.5 for the roll pins, but they will charge you $10.95 for shipping. :annoyed:
    It really has to be something no one else has to get me to order from them. :pout:
    OldSchlPunk, Drainbung and Kwikvette like this.
  16. Dec 3, 2024 at 12:20 PM
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 OR DCFB
    Fox and Locked suspension 63's Skinny 33's
    You could check out belmetric, local place that I know also ships. Great selection and same day pickup.
    Not sure about shipping prices but it doesnt seem hard to beat mcmasters
    https://belmetric.com/
  17. Dec 3, 2024 at 12:27 PM
    Topanga Taco
    Rick
    Tell me, the days where I only needed a drill, and not a tapping set to go with it…it was tough to eat the shipping costs. But, that was in the build cost, personally, I would absolutely need it!
  18. Dec 3, 2024 at 12:31 PM
    Topanga Taco
    Rick
    Woodworking (and a square file:0) to the rescue with the Workmate. Aluminum be tough to prop sometimes.
    Mind you, I use it mostly for my saw wrenching. But as you folks that own one knowest best, it’s extremely hard to get an answer No from the B&D:hattip:
    Drainbung and Zebinator like this.
  19. Dec 3, 2024 at 12:41 PM
    Zebinator
    Norcal
    Unless you're taping a tiny drill bit inside a letter and sticking on a stamp, I don't know where you're shipping anything for less than $9!
    Drainbung, Kwikvette and Topanga Taco like this.
  20. Dec 3, 2024 at 12:53 PM
    OldSchlPunk
    OldSchlPunk I'm not sick, but I'm not well
    Rich
    East Central Wisco
    '17 AC OffRoad Silver Sky Metallic
    Small lift, slightly oversized tires, well...
    I understand you have to pay order pickers, but really?! A stamp is $.72. How many orders do your pickers pick in an hour? What are they being paid? Either I'm getting screwed at that price or someone's very inefficient. Sure they have things that nobody else has, but Amazon also gives me access to things nobody carries and ships for free (or a very reasonable price).
    And that $10.95 is the same if I have it shipped to the local store. Complete bullsh$t. I'm quite sure they get a re-supply at least once a week (likely more often), get it in their store shipment.
    Their business model sucks.
