Anything welding
Discussion in 'Garage / Workshop' started by EL TACOROJO, Sep 17, 2010.
  1. Mar 4, 2014 at 8:40 PM
    #2941
    jeverich
    jeverich Well-Known Member
    Jake
    PNW/Kodiak
    07 2.7 4x4
    OME 886/Old Man Doug Suspension Lift, ARB Bumper, Bruteforce High Clearance w/Swing Out, De-badge, Block Heater, Homemade IFS Skid, 7" Kragens, Blue Seas Fuse Block, BlitzPro Fogs, 12k BadLands Winch, BAMF Sliders, ARB Locker, 4.88s Yaesu FT-1900R, Larsen 150B NMO Mount Antenna
    Or try Helicoils..
    Use them quite often on the boat; just make sure you take your time installing them..
  2. Mar 4, 2014 at 8:48 PM
    #2942
    Kanoodle
    Kanoodle Well-Known Member
    SLC, UT
    14 MGM. DC TRD-OR
    Wet Okole seat covers with heating elements Best Top soft topper Spidertax 1.25" wheel spacers Relentless Fab Hood hinge brackets with 18 watt LED Ditch Lights Prinsu Designs Cab Rack Tepui Ruggedized Autana RTT Expedition Orange Cooper SST MAXX E Rated tires Anytime Fogs mod
    Believe the reason easy outs reason for existence is broken off bolts. They dont always work but worth a try. But before trying spray broken bolt with pb blaster several times over the course of a day or two and give it a go.
  3. Mar 4, 2014 at 9:01 PM
    #2943
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    Just because something is made for a purpose doesn't mean it works. Rather then waste money on an easy out kit buy a drill/tap for $5 and be done with it. The tap can also be used to chase the other threads as they'll most likely need.
  4. Mar 4, 2014 at 10:20 PM
    #2944
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    Depends on the application. A drill and tap would make the existing hole over sized. A generous application of PB and an easyout-probably a better answer for parts that require it.
  5. Mar 4, 2014 at 10:31 PM
    #2945
    nagorb
    Alabama
    2001 dbl cab 4x4
    Worked fine on one of my bolts. Easy outs usually only work on bolts that are only just barely stuck. Skid bolts tend to rust and gall up for some reason, I tried it on mine cause I had a set already, no dice. If there isn't enough tread to re tap after you drill it out you can just use a larger bolt, there's plenty left.
  6. Mar 4, 2014 at 11:12 PM
    #2946
    Darth_Yota
    Darth_Yota I intend to live forever, or die trying.
    Cam-moron
    Somewhere USA
    Dented, broken-down ‘08 hoopty
    Ain’t good’nuff for insta
    asa5adu7_9932dd4e2761dd48fc446b236042210100420d51.jpg2adunypu_5229b7367008653527ad7e0ce1fb495682f83210.jpg4eqeqydu_545206fb643f5f89aba57067fabff766d27b8f7f.jpgbanepype_d0ff849a51d084d618ccf6d02c048a548468fc1b.jpg
    Made this brush guard for a friend.
    I know it's on a jeep, but it's what he wanted...
  7. Mar 5, 2014 at 1:22 AM
    #2947
    JuansTaco
    JuansTaco JuanInAMillion
    Juan
    gilbert az
    2004 PreRunner SR5 stormtrooper
    ESB long travel kit, Deaver f67s with DTF 12 inch shackles.
  8. Mar 5, 2014 at 3:53 AM
    #2948
    wildwr
    wildwr WildWR
    WayneR
    Pickering/Picton, Ontario
    TDR Sport
    Autostart remote starter Extang Hard Trifold tonneau cover Still surfing forums for ideas
    Yes this is the correct plug for your application.
    Have you purchased your welder yet and are you going to a building centre or an actual Welding suppply store for your purchase??
    I suggest pricing it out at an actual welding supplier who sells the gas consumables as there's always packages they'll offer to suite your needs. (i.e. Gas bottle-purchase/rent, spool gun for aluminum, wire etc...)
    Wth regards to building centres you may get a good deal on a welder, however the gas consumables and accessories may cost you full price.
    its just a suggestion from past experience.
    Good luck
  9. Mar 5, 2014 at 8:57 AM
    #2949
    shawnphoto
    shawnphoto Well-Known Member
    MT
    First Gen Tundra
    First Gen Tundra Linked and Long Travel
    check out Amazon... i bought my hobart 210 there. does both 110 and 220
    rented a huge 125 cylinder from a local welding place for 7.00 a month and 60/fill 'till i can get my hands on a customer bottle for a reasonable price.
    the local praxair tried to price me out to 285 for the tank.... sorry but no.
    check out dezertrangers if your in so cal, theres a shop owner who sells tanks around 120$ each
  10. Mar 5, 2014 at 9:04 AM
    #2950
    Whitecloud
    Whitecloud Cloudy-fabricator of things
    Johnathan
    Albuquerque, New Mexico
    Superwhite 06 DCLB
    ICON Extended travel Coilovers, Custom leaf pack, custom sliders and F&R bumpers, 295 75 17 Toyo Open Country MT's, On-Board air with F+R connectors, On-Board water with quick disconnect shower.Trimmed fenders and body mount chop. LOTS of wiring, dual battery setup, Solar charging system, with some random lights spread around here and there.
    Just ordered one of these with the TIG package..............:)
  11. Mar 5, 2014 at 9:41 AM
    #2951
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    Sweet! You'll love it.
    My 211i is pretty sweet with the whole shebang. Got the tig torch and foot pedal, as well as the spool gun for mine all wrapped on a custom dual cylinder cart I built.
  12. Mar 5, 2014 at 10:18 AM
    #2952
    JuansTaco
    Juan
    gilbert az
    Not yet. My dads going half on it so im waiting to make sure i get the right one. Im now looking at the millermatic 211 that has the dual plugs
  13. Mar 5, 2014 at 10:22 AM
    #2953
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    ^worth it, but the Hobart of the same size has them now too I think
  14. Mar 5, 2014 at 10:27 AM
    #2954
    JuansTaco
    Juan
    gilbert az
    Do you know the price? The miller is 1137 or something like that
  15. Mar 5, 2014 at 12:23 PM
    #2955
    Cr250jumper
    The moon
    50 shades of tan©
  16. Mar 5, 2014 at 12:24 PM
    #2956
    nagorb
    Alabama
    2001 dbl cab 4x4
    Check out the thermal arc, it has slightly better numbers then the 211 and also has dual input, plus if you ever want tig you can run it off the same machine.
  17. Mar 5, 2014 at 12:31 PM
    #2957
    M C M
    M C M Well-Known Member Vendor
    Matthew
    Sin City, Nevada
    91 Toyota Pick Up, 02 Toyota Tundra
    Lots of expensive shit
    Except Hobart has cheaper internals. More plastic, less metal. Both are good machines, but one might last 30 years longer
  18. Mar 5, 2014 at 12:32 PM
    #2958
    JuansTaco
    Juan
    gilbert az
    Hmmm decisions decisions
  19. Mar 5, 2014 at 12:35 PM
    #2959
    Cr250jumper
    The moon
    50 shades of tan©
    I agree but this is not for a business, welding all day every day I would say Miller hands down. Welding once every 3 months as a project or hobby and Hobart (and others) will work just fine
  20. Mar 5, 2014 at 1:50 PM
    #2960
    Milota95
    Milota95 Mall Crawling Specialist
    Qrampage
    B.F.E
    97 SX Single Cab V6 ~ 95.5 SX Single Cab 4c ~ 81 Pickup ~ 2021 Lamborghini SVJ
    Driven Safely
    x2 :)
