Anything welding
Discussion in 'Garage / Workshop' started by EL TACOROJO, Sep 17, 2010.
  1. Mar 17, 2014 at 3:20 PM
    #3021
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    Another vote for band saw way more versatile and less shit to clean up.
  2. Mar 17, 2014 at 5:02 PM
    #3022
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    What about a reciprocating saw? Wouldn't they work basically the same?
  3. Mar 17, 2014 at 5:05 PM
    #3023
    4banger4x4
    4banger4x4 Probably should'nt have done that.
    Eric
    Whorelando, Fl
    not welding, more of fabrication, BUT what do you guys think of a 1/4" 6061 aluminum rear High clearance bumper? the cnc guy at work said he could design one for me on the computer and cut it out but im not sure how i feel about an aluminum rear bumper.
  4. Mar 17, 2014 at 5:06 PM
    #3024
    4banger4x4
    Eric
    Whorelando, Fl
    i hate portoband saws, i always grab the recip saw when i need to make a cut
  5. Mar 17, 2014 at 5:10 PM
    #3025
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    Makes crappy cut.
    Porta-band with the Swag stand.
    A chop saw is nice but abrasive blades throw sparks & crap all over the place and that pretty much wrecks the table. You can get steel blades but they're expensive.
  6. Mar 17, 2014 at 5:27 PM
    #3026
    littledvl
    littledvl ride BMX!
    Eric
    Saint Leonard MD
    08 taco dc 4x4 / 15 tundra dc 4x4
    Too many to list
    Another vote for porta-band
    When I cut its usually a porta-band, zip, or torch.
  7. Mar 17, 2014 at 5:32 PM
    #3027
    4banger4x4
    Eric
    Whorelando, Fl
    Wait, dont let this one slip past you guys
  8. Mar 17, 2014 at 7:04 PM
    #3028
    nagorb
    Alabama
    2001 dbl cab 4x4
    This^
  9. Mar 17, 2014 at 7:45 PM
    #3029
    02coma
    02coma Well-Known Member
    la puente
    02 dc
    any1 here using lincoln welder handy mig or lincoln 140 hd, im plan getting 1 but dont know which should i buy. any input pls
  10. Mar 17, 2014 at 8:21 PM
    #3030
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    Well I ended up getting a chop saw. I couldn't justify the extra cost of the portaband. Got the Ridgid chop saw. Lifetime warranty
  11. Mar 17, 2014 at 8:30 PM
    #3031
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    When you start cutting with the abrasives, coat the table part of the saw with something to keep it the material from sticking to it.
  12. Mar 17, 2014 at 9:07 PM
    #3032
    nagorb
    Alabama
    2001 dbl cab 4x4
    Better yet build a covered rolling table with an open slot in the back for all the crap to fall to the bottom. It will still get all over the place but it keeps most of it contained, we had one for a job we cut miles of aluminum and brass, it helped keep cleanup to a minimum. Though we were using a compound miter saw with a blade but same idea.
  13. Mar 17, 2014 at 9:17 PM
    #3033
    TruckyTruck
    TruckyTruck Well-Known Member
    Tundra Crewmax TSS Off-Road 4x4, sr5/leather
    Tig welding, my last class in the welding program I'm in, started today. I'm pretty excited.
  14. Mar 17, 2014 at 9:18 PM
    #3034
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    My favorite process by far
  15. Mar 18, 2014 at 11:39 AM
    #3035
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    I don't know a whole lot about aluminum other than with proper design, it can be made as strong if not stronger than steel on a per-weight basis. it may take extra gussets and other reinforcements here and there but you will end up accomplishing the same goal with less weight.
    downsides would be cost, and aluminum is much more prone to disappear when drug over rocks
  16. Mar 18, 2014 at 7:57 PM
    #3036
    TruckyTruck
    My first crack at it wasn't so hot... Ha. But I'll get better quick I'm sure. So much cleaner
  17. Mar 19, 2014 at 5:52 PM
    #3037
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Go with the Longevity Migweld 140.. Almost the same exact welder but for alot cheaper and it has a longer warrenty.. (5 year I think)
    I love mine!
  18. Mar 19, 2014 at 5:56 PM
    #3038
    CASTRATE
    CASTRATE Well-Known Member
    Gabe
    SW of Tulsa, OK
    2012 4x4 SR5 6spd
    I used to build armor for military trucks. We ran spray arc on all the heavy stuff. It was hot, but fun. I run a lot of spray arc with my LN-25 at home.
  19. Mar 19, 2014 at 9:31 PM
    #3039
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    Or even better get a tweco fabricator 141i
    Better company than longevity.
  20. Mar 19, 2014 at 10:48 PM
    #3040
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    http://www.youtube.com/watch?v=gTFhh8dAK10
