Anything welding
Discussion in 'Garage / Workshop' started by EL TACOROJO, Sep 17, 2010.
  1. May 8, 2014 at 11:15 AM
    #3421
    SOS CONCEPTS
    SOS CONCEPTS Bumper builder
    SOS
    Laurens SC
    17 sos buggy, 09 taco(in pieces), 14ram 3500
    Rock bouncer
    1" recovery point welded 100% with two grade 8 3/4" bolts. Gotta give them what they want[​IMG]
  2. May 8, 2014 at 11:24 AM
    #3422
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    Just keep in mind that you might have brake line running through the driver's side frame rail and to be careful about heating that side (2gen).
  3. May 8, 2014 at 11:27 AM
    #3423
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    Enginerds FTW! good post Nathan :) you perform or wittness that shear test you posted the picture of? titanium pin used?
    The issue then become usability and longevity. from a statics standpoint, or analyzing in a lab, the shackles we use are indeed overkill under ideal pulling conditions.
    first problem is that we don't operate under ideal conditions. as much as we try, shackles get side loaded and misused in other ways.
    second problem is that with most straps on the market, two strap eyes will not properly fit into a 1/2'' shackle. so even though it's factored safety rating is within the pull parameters, you're setting yourself up improperly before you even hop in the truck, by not havin a shackle that can properly hole two eyes of a tow strap. you end up spreading shackles at that point, which, like side loading, is not their intended operating conditions.
    the last area of concernt when going to a smaller shackle is the life of the shackle. I have yet to wear out a crosby shackle at the crown from use on my truck (though we see it all of the time on our job sites). however, i have elongated one. a smaller shackle will hold fine for most of our pulls, but after years of wheeling use, a 1/2 inch will not hold up as long.
    That'll be a fun time! I got to go see one of our supplier's testing facilities last summer. got to watch them pull apart some plasma line and some amsteel blue. very loud, and anyone who claims that synthetic line doesn't recoil with a harmful amount of force is a liar.
  4. May 8, 2014 at 11:28 AM
    #3424
    SOS CONCEPTS
    SOS
    Laurens SC
    Rock bouncer
  5. May 8, 2014 at 12:29 PM
    #3425
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    :laugh:
    You're doing the right thing.
    and while you're there, you might as well toss a blate on there that wraps around under the radiator support and ties into that mounting point.
    and if you have even more free time, gusset up the mounting points on the truck. plating up that 1/8'' steel that the 6 studs are pressed into is a quick job that really beefs up the front end.
  6. May 8, 2014 at 12:45 PM
    #3426
    Supermoto
    Supermoto Well-Known Member
    Landon
    Fallbrook
    Is that tubing or pipe?
  7. May 8, 2014 at 12:46 PM
    #3427
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    I'll add my .02 here, I went with 1" recovery points, welded through as well as to the winch plate on the sides. I went with 1" for a few reasons, yes they are likely overkill, but besides loading from a shackle during recovery, they are going to take a beating being on the front of the truck and encounter rocks as well. So, from a durability standpoint they are going to be better there.
    Following that, with all the calculations above, those are assuming an ideal metal and no dents, scratches etc that will reduce the loading required for failure. I also found them a good price, $30/pair, which was cheaper than most of the 3/4" weld through ones and even the flush mount ones.
    edit: welded in just like Eddy's, minus the bolts.
  8. May 8, 2014 at 12:50 PM
    #3428
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Yes
  9. May 8, 2014 at 12:57 PM
    #3429
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Now that's what i call overkill I like it!
  10. May 8, 2014 at 1:09 PM
    #3430
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    Kinda hard to ask $900 for a bumper without recovery points or a winch mount.
  11. May 8, 2014 at 2:07 PM
    #3431
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    To not argue about something you're wrong about? ..........
  12. May 8, 2014 at 2:13 PM
    #3432
    jeverich
    jeverich Well-Known Member
    Jake
    PNW/Kodiak
    07 2.7 4x4
    OME 886/Old Man Doug Suspension Lift, ARB Bumper, Bruteforce High Clearance w/Swing Out, De-badge, Block Heater, Homemade IFS Skid, 7" Kragens, Blue Seas Fuse Block, BlitzPro Fogs, 12k BadLands Winch, BAMF Sliders, ARB Locker, 4.88s Yaesu FT-1900R, Larsen 150B NMO Mount Antenna
    It's actually pretty cool that this conversation went in this direction.. Instead of "FU guy, it's big enough"..
    Totally agree with the lifetime of the shackle; with regards to sizing. I've seen shackles fail due to being worn, some of them just broke immediately due to the fact that they were shitty Chinese black iron.
    Definitely find all of this fascinating, especially the particulars of synthetic rope. Agree that typical recoveries are in less than ideal situations. Working part time at Masterpull and fabricating recovery straps for MRAPs and other military vehicles was a pretty cool experience. One thing that I can't stress enough is the importance of treating your synthetic rope properly.
    I know I've said it before, but ALL synthetic rope stores kinetic energy. It's still one hundred times safer than wire rope - but it'll still kick your ass.
    I've got a few hammerlocks by Gunnebo - ideally, they'd be what everyone would be using in their recovery points, then into the hammerlock with a shackle/hook, etc. I feel as though the fundamental design of recovery points will induce severe side loading on the shackle.
    http://gunneboindustries.com/en/Lif...s---Classic/Couplers/Coupling-link-G-Classic/
    And Kase; you're doing the right thing. I know with the bit of fabrication work that I've done, I've strayed away from bumpers or anything with a recovery/tow point. Do your research, get insurance - consult with a lawyer. If you're not willing to do it, then I'd suggest putting down your welder.. I know it's shitty to even say that, but it's a product of the litigious society we live in. I've seen a few multi-million dollar lawsuits won on boats due to the plaintiff's own ignorance. It would be fuckin' shitty if one of the bumpers you built killed or severely injured someone.
    End. Rant.
    Colin, what do you do??
  13. May 8, 2014 at 2:15 PM
    #3433
    Supermoto
    Landon
    Fallbrook
  14. May 8, 2014 at 2:49 PM
    #3434
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    I agree. Fun conversations when you bring in some good data. good reply, and those coupling links are nice. every once in a while you see an off road shop with a couple in stock, but it's rare. I've started using a soft shackle a lot more to avoid all improper loading situations.
    I'm an engineer for a heavy industrial construction/engineering company.
  15. May 9, 2014 at 6:43 AM
    #3435
    dispatch55126
    dispatch55126 Well-Known Member
    MN
    2004 Xtracab SR5
    Complete OME kit w/ 881's and dakars. All-Pro Sliders, CB, HAM Radio and various other minor stuff.
    This has probably been asked hundreds of times but...
    Do I or should I disconnect the battery if I'm welding on a vehicle? I'll be welding my sliders this weekend and was wondering if it needs to be disconnected before starting.
  16. May 9, 2014 at 6:48 AM
    #3436
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Probably fine without, but for 5 seconds of your time, I say do it. I forgot to do it once, no issues, but again better safe than sorry.
  17. May 9, 2014 at 6:56 AM
    #3437
    SOS CONCEPTS
    SOS
    Laurens SC
    Rock bouncer
    Only time I disconnect is with tig. If not just ground on the part your tacking. Muffle shops mig hundreds of cars and never have a prob
  18. May 9, 2014 at 7:41 AM
    #3438
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    I always disconnect the battery. Like wishbone said, for the few seconds it takes I prefer the peace of mind knowing I can't potentially mess up some expensive electronics
  19. May 9, 2014 at 8:02 AM
    #3439
    Socalduckslayer
    Socalduckslayer Pelfreybilt Off-Road
    Tyler
    San Diego, Ca
    12 Tacoma
    Odds and Ends
    I always disconnect the ground. Better safe than sorry. One of my guys toasted a CPU in a landcruiser at a previous job, no idea how but I don't want that risk.
  20. May 9, 2014 at 8:13 AM
    #3440
    SOS CONCEPTS
    SOS
    Laurens SC
    Rock bouncer
    Damn looks like I'm the only one. Hell at my job we are armoring 20 sl500's haven't done it yet. Good thing we got GL lol
