Anything welding
Discussion in 'Garage / Workshop' started by EL TACOROJO, Sep 17, 2010.
  1. Aug 13, 2011 at 9:18 PM
    #361
    SATXguy
    SATXguy Well-Known Member
    San Antonio
    2017 4x4 TRD Off Road
    Mobtown Front Recovery bar Relentless Fab Bed bars (3) Quickfist 2 pair Husky Floor Liners Cali Raised bed channer stiffeners Cali Raised low profile ditch light bracket 27 watt ditch light pods w/ side projection OEM Ditch Light switch Roam Adventure Co. Roof top tent Roof top tent annex Costway 54 Quart Portable Refrigerator/Freezer Compact Smittybilt 2789-99 Transit Bag NOCO GC019 12-Foot 12V Adapter Plug Socket Extension Cable Scoshe Magic Mount for Iphone plus Hypertech Speedometer calibrator BFG KO2 AT 265/75/16 JDMCar Center Console Organizer TRD pro Grill TRD PRO Grille Vinyl Decal Gloss Super White X-Bull Recovery Traction tracks 3rd gen CamPark ACT 74 Action Camera DC cargo 2" Diameter Black Steel V-Ring BoltOn Trailer Cargo Tie-Down CLC 1173 32 Pocket Socket Tool Roll Pouch Viair 00088 88P Portable Air Compressor Toyota Accessories PT580-35050-SB Bed Mat for Select Tacoma Models Rhino USA shackle hitch receiver Toyota Accessories PT580-35050-SB Bed Mat for Select Tacoma Models Smittybilt 3x30 recovery strap 30,000 lb capacity Smittybilt 3/4" D-Ring Shackle (Black) 4.75 ton rating 12V 140 Amp Dual Battery Isolator by KeyLine Chargers - Voltage Sensitive Relay Gen 3 Tacoma Auxiliary Battery Tray
    I bought the smallest industrial mig welder from Northern Tool that works off a 110 outlet. It works great I can use gas or flux core wire. It works great. I have built crank up deer feeders and some elevated deer blinds. I took an adult education summer class at a local high school and learned how to weld safely for $90.00 I couldn't see spending thousands of dollars to purchase on these things so I learned the skill. Yes I am an beginner at welding but my welds hold up great. Not as pretty as the ones posted above but it a hobby for me.
  2. Aug 13, 2011 at 9:33 PM
    #362
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    Congrats on learning a new skill.
  3. Aug 14, 2011 at 7:36 AM
    #363
    SATXguy
    San Antonio
    Thanks! I've had fun! I didn't realize how expensive metal was until I started welding. I can see why people charge so much. :)
  4. Aug 15, 2011 at 3:46 PM
    #364
    mntbiker2008
    mntbiker2008 First I derp.. then I herp
    Aaron
    Cincinnati, OH
    93 Pick up 4x4 (sold), 10' Mazda 3
    found a Miller Millermatic 130 for 375 comes with a 5 lb roll of .30 flux. Is this a decent deal or machine for that matter?
    I am planning on only welding small stuff.
  5. Aug 25, 2011 at 4:15 PM
    #365
    amaes
    amaes Cuz Stock Sucks
    Alex
    Phoenix, AZ
    2011 FJ Built
    ICON Stage 6, RCI Skids, Blacked out
    anyone welding with straight co2 instead of a 75/25 mix?
  6. Aug 25, 2011 at 4:22 PM
    #366
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    I used straight CO2 on mine when I first got it from my buddy. I thought it was welding ok but then I switched it out for 75/25 mix and it makes a world of difference
  7. Aug 25, 2011 at 4:32 PM
    #367
    cummins6speed
    cummins6speed Well-Known Member
    '05 4Runner Limited Edition
    Custom extended travel 2.5" King RR coilovers, 1.25" Camburg uniball uppers, homebuilt tube bumper
    I think its easier to weld with 100% CO2. It will create more spatter than mix gas, but it runs hotter so you will get more penetration, which is nice if you weld thicker material
  8. Aug 25, 2011 at 4:43 PM
    #368
    Cr250jumper
    The moon
    50 shades of tan©
    True. Most of the stuff I read says 100% co2 is not any weaker (better in some cases as you said), just not as pretty as mix
  9. Aug 25, 2011 at 4:45 PM
    #369
    amaes
    Alex
    Phoenix, AZ
    2011 FJ Built
    yeah thats what I read also. Just got a tank for my welder so figure I'd ask some people. Beats fucking with flux core. lol
    and I can clean the welds with a dremal anyways nbd
  10. Aug 25, 2011 at 4:46 PM
    #370
    cummins6speed
    Its just as strong but will burn hotter, so at the same voltage/wire speed it will have more penetration so you will have to compensate for that if you are using mix gas. I use mix gas though because it makes a nicer weld with less spatter
  11. Aug 25, 2011 at 4:48 PM
    #371
    cummins6speed
    Straight CO2 is also a good bit cheaper than mix gas IIRC but even mix gas isn't that expensive
  12. Aug 25, 2011 at 4:50 PM
    #372
    amaes
    Alex
    Phoenix, AZ
    2011 FJ Built
    yeah, sdhq can fill co2 tanks at the shop so Its faster and easier for me to get 100% co2 because I'm there once or twice a week. The welding shops are a little longer drive and have weird weekend hours.
  13. Aug 25, 2011 at 11:12 PM
    #373
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    Have to realize that the weld will get really globular (as thats what CO2 is used for most often.)
  14. Aug 26, 2011 at 6:53 AM
    #374
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    You get a bunch of different answers as to what's better. I think the trade off is whether or not you want to do a lot of cleanup. If you don't, c-25 (75/25) is the way to go. Straight CO2 would be the way to go for heavier material.
    If you're welding outside in a breeze, flux core is the way to go as wind blows the shielding gas away.
  15. Aug 26, 2011 at 8:11 AM
    #375
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    I use a 75/25 mix. The dealer says I should use "30-35" on the tank. Is that with the trigger in or not?
  16. Aug 26, 2011 at 8:56 AM
    #376
    Cr250jumper
    The moon
    50 shades of tan©
    ^Your talking about flow? I was told 15-20 while its flowing (trigger in)
  17. Aug 26, 2011 at 12:14 PM
    #377
    cummins6speed
    I set my flow rate depending on the conditions I'm welding in. If I'm in the garage ill usually have it aroused 10-15cfm.
  18. Aug 26, 2011 at 7:05 PM
    #378
    Matic
    Tricky Dick
    Easley, SC
    Yea sorry. I meant "flow". I always weld in the garage with the door up, usually little to no breeze. I'll try lowering it down to 15 or so. I'm just not quite getting that "sizzle".
  19. Aug 26, 2011 at 11:59 PM
    #379
    SurfInferno
    SurfInferno Dont be stupid, its not smart.
    Dylan
    Littleton, CO
    2001 DC
    i weld with 10-15, do you have enough power to supply it? thick enough extension cord? I tried welding something at a buddies house and his plug wasnt powerful enough to weld thicker material and it didnt sound good haha.
  20. Aug 27, 2011 at 12:52 AM
    #380
    Matic
    Tricky Dick
    Easley, SC
    Yea. I got good power but the guy at the welding shop told me 30-35. I'm a newb to welding but as a machinest at work I have an ear for things. I heard my buddy weld and it was like a steak sizzling on the grill, Very sweet.
