Anything welding
Discussion in 'Garage / Workshop' started by EL TACOROJO, Sep 17, 2010.
  1. Jul 11, 2014 at 8:59 PM
    #3921
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    When I was looking for mine everything I found was either parts or priced almost new. I looked multiple times everyday for a few months, along with plasma cutters. I just ended up going new, why take the chance on a used machine just to save 1or 200 on a $1000+ machine.
  2. Jul 12, 2014 at 6:14 PM
    #3922
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    Anyone have a problem with a hobatt 140 spitting put wire at full speed? Dial no longer works
  3. Jul 12, 2014 at 6:52 PM
    #3923
    Dragons Taco
    Dragons Taco Well-Known Member
    Derek
    Cary/Raleigh NC
    06 Black TRD-S 4WD 4D 6SPD and MINE!
    Can ya spell Tonneau
    That should be fixable.
  4. Jul 12, 2014 at 7:02 PM
    #3924
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    [​IMG] clear coat is drying now install tomorrow. Had a rough day so i opted out on the side braces i was gonna do. Ill get a skid plate on there eventually, but done for now
  5. Jul 13, 2014 at 1:54 PM
    #3925
    yota243
    E.J.
    north Alabama
  6. Jul 13, 2014 at 4:17 PM
    #3926
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    I'd say get something on there ASAP before you destroy your radiator.
  7. Jul 13, 2014 at 4:39 PM
    #3927
    SOS CONCEPTS
    SOS CONCEPTS Bumper builder
    SOS
    Laurens SC
    17 sos buggy, 09 taco(in pieces), 14ram 3500
    Rock bouncer
    so it can twist around plus its normal up and down flex
  8. Jul 13, 2014 at 4:43 PM
    #3928
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    That's a leaf spring slider box. Its suppose to give you "more travel" without over extending your springs and replaces the shackles. There are mixed reviews on them.
  9. Jul 13, 2014 at 4:53 PM
    #3929
    SOS CONCEPTS
    SOS
    Laurens SC
    Rock bouncer
    Things must be diff in the south. Because at B&R offroad where i use work. We put these on baja crawlers for Rick Hendrick jeep so the rear axle could twist during cornering big ass rocks
  10. Jul 13, 2014 at 5:01 PM
    #3930
    JLee
    Jerry
    Grass valley CA
    Just replacing the shackles you would still need to solid mount the front hanger.
  11. Jul 13, 2014 at 5:04 PM
    #3931
    yota243
    E.J.
    north Alabama
    Yeah its gonna get something soon
  12. Jul 14, 2014 at 12:01 AM
    #3932
    DWreck
    DWreck Famous Retrieval Vendor
    Derek
    Las Vegas, NV
    2004 Tacoma Smurf Truck
    Plasti-dip paint, TRD S/C, MCM Fab LT kit, bunches of my fab
    Genious idea no doubt. However, function hindering. These move forward and back. A shackle moved forward, back, up and down. A shackle would provide further movement it appears.
    In other news, I finished up the skid plates on my Retrieval truck today. Now I can ride the ruts in confidence when I'm chasing down race vehicles.
  13. Jul 14, 2014 at 10:25 AM
    #3933
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    I got to work and was told I need to pass a AWS 3G weld test today. I don't think I've welded 3G more than 5 minutes in my life. :eek:
  14. Jul 14, 2014 at 10:47 AM
    #3934
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    Gmaw. I have to do a 3G root in 3/8" plate with a backing plate. That's about all I know until I get back from lunch.
  15. Jul 14, 2014 at 1:16 PM
    #3935
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    Hold your sides don't spend time in the middle
  16. Jul 14, 2014 at 3:03 PM
    #3936
    CASTRATE
    CASTRATE Well-Known Member
    Gabe
    SW of Tulsa, OK
    2012 4x4 SR5 6spd
    Walk in there, drop your trousers, lay down the most drop fuckin' dead sexy tig welds they've ever seen, and forget about the rest.
    Since you already work there, that ain't gonna work.
    I've been fortunate enough to always start out with tig when testing for a new job. Never have had to take their other pre-employment weld tests.
  17. Jul 14, 2014 at 3:07 PM
    #3937
    yota243
    E.J.
    north Alabama
    Is there a functionality benifit to dropping it? I just wanted to follow stock lines as close as possible
  18. Jul 14, 2014 at 3:10 PM
    #3938
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    When the frame flexes you won't hurt your fenders.
  19. Jul 14, 2014 at 6:33 PM
    #3939
    Spagget13
    Spagget13 Well-Known Member
    Drew
    Lake Havasu City
    01 TRD off road ext cab
    Mcm Fabrication4x4 long travel kit, ADS coilovers, ADS bumps Deaver h70/e30 Leafs, 2.5x16 king double bypasses, straight pipe after cat, Glassworks Fiberglass front and rear.
    Got miggy with it at work the other day. Too much slag though :(
  20. Jul 14, 2014 at 7:16 PM
    #3940
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    I ended up not needing to test today because the power went out right after lunch and we all went home. Spent my afternoon picking up a free oxy acet torch setup, and looking at a bigger shop to move into.
    I didn't have to do a pre-employment weld test. The welding manager just looked at the bumpers on my truck that I welded and said I was good. That's all flat or horizontal welding though.
