Anything welding
Discussion in 'Garage / Workshop' started by EL TACOROJO, Sep 17, 2010.
  1. Jan 11, 2015 at 3:01 PM
    #4561
    Ravic
    Ravic Artisan in DIY mods
    TP
    North Augusta, SC
    2013 DCSBMGM OR 4x4
    DIY Mods-BHLM, Plastidip Rims (now spares), color matched Grille, Plate Bumper, bilstein set @2.5 (self installed no spring compressor), 2" Rough Country AAL, LR UCAs. Non DIY- 285/75r16 duratracts, procomp 7031.
    That looks boss man! Great job!
  2. Jan 11, 2015 at 6:30 PM
    #4562
    shawnphoto
    shawnphoto Well-Known Member
    MT
    First Gen Tundra
    First Gen Tundra Linked and Long Travel
    wow good work, one of the better looking plate bumpers i've seen
  3. Jan 11, 2015 at 8:31 PM
    #4563
    ruggedT
    ruggedT The Sticker Guy
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    Any idea's why the spoolgun would arc back to the tip instantly? Like the whole length of stickout gone as soon as it arced.If I kept it going it would get some spray on the material but as soon as I stop the tip would fuse... and this mess happened. Was about 3/4" away. If I tried lower power it would just pop and arc. Miller 211, spoolmate 100
  4. Jan 11, 2015 at 9:02 PM
    #4564
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    check your plug. You may have lost one of the 120v legs. Its happened to me twice. Trying to push that many amps thru 1 leg will vaporize the tip.
    If not that, your heat and speed is way off.
  5. Jan 11, 2015 at 9:11 PM
    #4565
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    Make sure it's feeding consistent. If it's binding it'll spray like that and burn back as if there is high voltage or extremely low wire speed
  6. Jan 11, 2015 at 9:44 PM
    #4566
    jeverich
    jeverich Well-Known Member
    Jake
    PNW/Kodiak
    07 2.7 4x4
    OME 886/Old Man Doug Suspension Lift, ARB Bumper, Bruteforce High Clearance w/Swing Out, De-badge, Block Heater, Homemade IFS Skid, 7" Kragens, Blue Seas Fuse Block, BlitzPro Fogs, 12k BadLands Winch, BAMF Sliders, ARB Locker, 4.88s Yaesu FT-1900R, Larsen 150B NMO Mount Antenna
  7. Jan 11, 2015 at 9:57 PM
    #4567
    koditten
    Kirk
    Central Michigan
    Should cut down on the black boogers. Must respect the lungs. I'd say that will be a good investment.
  8. Jan 11, 2015 at 10:35 PM
    #4568
    jeverich
    Jake
    PNW/Kodiak
    07 2.7 4x4
    Yeah; especially useful if I decide against a water table on my cnc plasma...
  9. Jan 12, 2015 at 6:42 AM
    #4569
    Ravic
    TP
    North Augusta, SC
    2013 DCSBMGM OR 4x4
    Thanks man!
  10. Jan 12, 2015 at 8:07 AM
    #4570
    ruggedT
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    Ok thanks... ill check that tonight. I did check the wire speed and it seemed ok.
  11. Jan 12, 2015 at 5:42 PM
    #4571
    weldertaco
    weldertaco Mr.13%bodyfat
    texas
    TrailRunner
    4wd to 2wd conversion
    Anyone hiring someone for some tig welding or know anyone who is? Or stick ?
    Anything is better than this boring and repetitive brainless welding we do here lol.
    Flat flux core. On the same groove. On the same poles. Every day. All day.
    I need something thats a little more mentally challenging.
  12. Jan 12, 2015 at 5:46 PM
    #4572
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    Start a project at home Kase!
  13. Jan 12, 2015 at 6:00 PM
    #4573
    jeverich
    Jake
    PNW/Kodiak
    07 2.7 4x4
    Alaska always needs welders...
    Contact the Resolve shipyard in Dutch Harbor.
    You might not be able to see the light at the moment, but you DO have a job.
    Be mindful that everything posted on the interwebs is public.
  14. Jan 12, 2015 at 6:02 PM
    #4574
    weldertaco
    texas
    TrailRunner
    Idk if I'm that desperate yet lol. I'm working with a guy who used to work in a shipyard and said it was the worst job he's ever had...
  15. Jan 12, 2015 at 6:07 PM
    #4575
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Not sure what you expected as a production welder. Most weld shops make many of the same or similar part. It's going to be boring unless you're in a custom fabrication shop.
  16. Jan 12, 2015 at 6:10 PM
    #4576
    jeverich
    Jake
    PNW/Kodiak
    07 2.7 4x4
    First and foremost, figure out what you want to do and determine the steps you need to do to make it happen...
    I know the refineries in my area are usually hiring; my friends that are pipe welders do well - but it's a constant commitment.
    Stick it out. It looks pretty shitty if you have 3 different places of employment within your first year of being a professional.
    Save your money.
    Don't buy needless shit.
    If you decide to purchase equipment on your own, being able to provide a nice down payment and a positive credit score will reflect very highly on you. I've got all of my equipment paid off (~5k), just through using my head (hood), it's a pun.
    The shipyards/small independent guys in Alaska actually get to do some interesting work. It's far different work than burning tanks out of a ship down on the canal... That sucks.
  17. Jan 12, 2015 at 6:10 PM
    #4577
    weldertaco
    texas
    TrailRunner
    Yea I know. I took the job cause it was a for sure job lined up after school.
    So now I'm just looking around to see if I can get closer to the welding I enjoy.
  18. Jan 12, 2015 at 6:13 PM
    #4578
    jeverich
    Jake
    PNW/Kodiak
    07 2.7 4x4
    But think of where and how you'll be able to bolster your own personal skill sets...
    I go through it with the green horns that approach me asking for a crew position "But I flew here, and I am a hard worker - and I saw it on TV."
    Make sure that you can walk the walk before you talk the talk!
  19. Jan 12, 2015 at 6:16 PM
    #4579
    weldertaco
    texas
    TrailRunner
    Yea I know the speech about sticking through things.
    I just hate flux core so bad :frusty:
    Its not pretty, its smokey and involves zero skills
    I just feel like I'm waisting my time when I could be welding with stick or tig stacking dimes or walking cups.
    I'm not gonna quit or anything but I'm just trying to see what I gotta do to go up this ladder I'm on rather than get stuck on the first floor with everyone else.
  20. Jan 12, 2015 at 6:24 PM
    #4580
    jeverich
    Jake
    PNW/Kodiak
    07 2.7 4x4
    It's hard to try and focus on improving your talent when you know that it's not going to happen where you're at... I've been there.
    Especially when it's pretty clear that you're never going to get above step 2 on the ladder.
    I'm sure you could be the best TIG welder in the world, and it wouldn't matter at all where you're at. I'm sure a lot of your co-workers are totally fine with slogging into work in the morning and shutting their brains off, then getting a check on Friday.
    You don't seem to be that way.
    I can't speak with much experience of the welding industry; but I'd imagine just like everyone else, you've got to pay your dues.
    Then maybe take the leap and go out on your own.
    I wouldn't trade being self-employed for anything in the world.
