Anything welding
Discussion in 'Garage / Workshop' started by EL TACOROJO, Sep 17, 2010.
  1. Mar 12, 2015 at 11:32 AM
    #4821
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Looks good. But I'm an amature so not like my opinion holds any weight.
  2. Mar 12, 2015 at 11:47 AM
    #4822
    la0d0g
    running for the hills
    For crawling not hauling
    Thanks! I don't know what the F is going on either :p
  3. Mar 13, 2015 at 12:52 PM
    #4823
    nelztaco
    nelztaco Well-Known Member
    Neil
    Levittown, PA
    09 TRD Sport DCLB 4x4 SW
    UNDERCOVER, EIBACH COILS, TSB 4 LEAFS, TRD WHEELS, 255/85R16 KM2
    I just ordered my dynasty today. Never laid a tig weld but anxious to learn.
  4. Mar 13, 2015 at 3:12 PM
    #4824
    Hockeyman90
    Hockeyman90 Well-Known Member
    Kaleb
    Craig, Co
    2001 Gold SR5
    Custom front bumper, bed liner, 33" wrangler duratracs on 16" ATX series Mojave rims, OME 3" suspension, 882 coils, custom rear bumper
    Have a Hypertherm Powermax 30xp being delivered. Should be here about Wednesday. Excited to have a nice plasma to start working with
  5. Mar 14, 2015 at 9:03 AM
    #4825
    NewRider
    NewRider Well-Known Member
    Travis
    Charlottesville , Va
    '87 4runner
    Welded up a front driveshaft extension yesterday... One of the last tweaks on puttin a 350 small block in a 94 Toyota Pickup[​IMG]
  6. Mar 14, 2015 at 2:56 PM
    #4826
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    I hate you
  7. Mar 14, 2015 at 3:06 PM
    #4827
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Ran thru the last of the 2lb spool that came with my eastwood 250 today welding some.braces on an old cattle gate. Laid a few inches of bad beads and couldnt get anything goin to start, just thoughy it was cuz i was welding some dirty stuff or maybe cuz the gate was 1/8 and the brace was 3/16". i started at what i thought was the recommended setting for 1/8" so i was gonna turn up to 3/16" and when i check the chart i noticed i had it set for the 110v not the 220v. Thimgs went much smoother the rest of the job ha.
  8. Mar 14, 2015 at 3:13 PM
    #4828
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    That's funny you should mention wire. I just finished up a 44 pounder that was absolutely shit! I was honestly thinking that my skills were fading. New roll of wire and it was majical. That will be the last time I buy wire over the internet.must have been some serious impurities.
  9. Mar 14, 2015 at 4:54 PM
    #4829
    jeverich
    jeverich Well-Known Member
    Jake
    PNW/Kodiak
    07 2.7 4x4
    OME 886/Old Man Doug Suspension Lift, ARB Bumper, Bruteforce High Clearance w/Swing Out, De-badge, Block Heater, Homemade IFS Skid, 7" Kragens, Blue Seas Fuse Block, BlitzPro Fogs, 12k BadLands Winch, BAMF Sliders, ARB Locker, 4.88s Yaesu FT-1900R, Larsen 150B NMO Mount Antenna
    Are you confident in the structural integrity of that weld? Looks like there's a little mis-alignment...
    Did you sleeve that?
  10. Mar 14, 2015 at 6:15 PM
    #4830
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    I'm curious about the balance too.
  11. Mar 14, 2015 at 8:01 PM
    #4831
    yota243
    E.J.
    north Alabama
    Hes puttin gm parts in his truck, the drive shaft is prolly the least of his worries
  12. Mar 14, 2015 at 8:03 PM
    #4832
    medic2230
    Murph
    Bama! Roll Tide
    Very valid point.
  13. Mar 14, 2015 at 8:56 PM
    #4833
    Milota95
    Milota95 Mall Crawling Specialist
    Qrampage
    B.F.E
    97 SX Single Cab V6 ~ 95.5 SX Single Cab 4c ~ 81 Pickup
    Driven Safely
    Noo she wasn't ready ... Also curious about balance going down the highway
  14. Mar 14, 2015 at 9:36 PM
    #4834
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    No thank you.
  15. Mar 15, 2015 at 9:46 AM
    #4835
    NewRider
    Travis
    '87 4runner
    We'll see how it holds up under load but if any of my other projects are a testament to the strength of my welds then I think it'll be fine... So far norther the bumper or sliders have even flexed and there both taken some serious beatings. But in terms of balance, also not too worried about it, is the front shaft so it only spins in 4wheel and that'll only really be used at low speeds... It is sleeved so hopefully that helped with the alignment. In the end, it was more of a "we've got the parts, let's try it" type project just to get the thing on the road, if it doesn't hold, we'll replace it with a new one...
    Also, I didn't do the actual welds but I helped when we cut 3 inches outa the rear shaft, and after seeing the truck go down the road yesterday that made me much more confident for the front one.. The rear seems to be completely balanced, now to see if it can handle the stress of a mud hole
  16. Mar 15, 2015 at 10:36 AM
    #4836
    ImplicitlyAlberta
    ImplicitlyAlberta VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
    It'll be more than just drive shaft to replace if it goes........just sayin.
  17. Mar 15, 2015 at 4:07 PM
    #4837
    NewRider
    Travis
    '87 4runner
    If it goes it'll proba be in a low speed high torque situation, so ya it might ding some things up but shouldn't cause any serious damage... And anyway, it's a toy, things are gonna break
  18. Mar 15, 2015 at 4:36 PM
    #4838
    Trailworx
    Trailworx Active Member
    Dave
    Texas
    08 FJ Cruiser Prerunner
    Trailworx front and rear bumpers, Icon coilovers, method double standards, General Grabbers
    I'd throw a drive shaft hoop in there. Looks out of balance for sure.. carry an extra joint and tools to replace it on your test drive.
  19. Mar 15, 2015 at 8:58 PM
    #4839
    Milota95
    Qrampage
    B.F.E
    Driven Safely
    then do you trust the guy who did weld this? just doesn't looksafe an the liability
  20. Mar 15, 2015 at 9:31 PM
    #4840
    nagorb
    Alabama
    2001 dbl cab 4x4
    So the boss man tasked me with finding a new mig welder with alum capabilities for a new job coming up. material will be 1/4" not sure the alloy but assume 6061. I know nothing of mig alum other then you need a spool gun or push pull, only know about tig. Anyone have any suggestions on machines/guns?
