Anything welding
Discussion in 'Garage / Workshop' started by EL TACOROJO, Sep 17, 2010.
  1. Aug 12, 2015 at 2:45 PM
    #5081
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Too poor to list anything interesting.
    95 taco likes this.
  2. Aug 12, 2015 at 2:54 PM
    #5082
    weldertaco
    weldertaco Mr.13%bodyfat
    texas
    TrailRunner
    4wd to 2wd conversion
    :laugh: at least the lady will know I wasn't bullshitting when I tell her I was having machine problems this morning.
    Gonna have to save up for a new machine tho after this job :pout:
  3. Aug 12, 2015 at 4:27 PM
    #5083
    weldertaco
    texas
    TrailRunner
    6:30p.m. tried to burn a few rods and the machine keeps dying.. Fuck this thing. Just gonna buy a new one and call it done.
  4. Aug 12, 2015 at 4:44 PM
    #5084
    weldertaco
    texas
    TrailRunner
    @achirdo I need some reviews on your Ranger 250! You've been welding with it for a while and I need some advice.
  5. Aug 12, 2015 at 10:34 PM
    #5085
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    Lincoln held up to there reputation with my machine. Welds good, great generator output, never given me a single problem. Fires up the first time every time. That being said I'd get the 305 if I were to do it again. I've never once used AC on it. I thought I would use it for TIG aluminum but I never have. Spool gun works just fine for that. The 305 I hear will have a better arc. Similar to am SA-200 from what I hear. And you can adjust the arc force. I also like the digital display, I never know exactly what amps I'm running.
    Although the only downside to the 305 is that it has a lot more electronics to go bad. The 250 and 225 don't. If you are trying to do this on the cheap the Ranger 225 would be a great choice.
  6. Aug 12, 2015 at 10:51 PM
    #5086
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    I was debating it. Was mainly interested in the panel adhesive for the simplicity and strength from what I have read in other forums. Plus my wire welder is a HF flux core. I ordered some cleco pins for building it, and I'll do some stitch welds then join them.
    I'm jealous of you folks with all the nice setups. I'd kill for a plasma cutter for this project.
    I'll get pictures if it as I go along. Just pulled the fenders and drained the coolant tonight, my back was toast after that.
    Ugly Betty likes this.
  7. Aug 13, 2015 at 7:22 AM
    #5087
    weldertaco
    texas
    TrailRunner
    Have you used it for gouging yet?
  8. Aug 13, 2015 at 8:46 PM
    #5088
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    I have not. One thing I don't have on my truck is Air.
  9. Aug 13, 2015 at 9:24 PM
    #5089
    weldertaco
    texas
    TrailRunner
    Dang. I would think gouging would be a pretty common thing in the field. I actually enjoy gouging a lot when it comes to thicker materials. Seems to work quick and accurate. Then again that's all I did at my last job so I guess it could be one of those things you enjoy once you get good at it.
  10. Aug 18, 2015 at 10:31 AM
    #5090
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Got my TIG welder the other day. Been trying to understand/learn the settings, to include proper use of the pulse and AC balance.
    My first few beads on aluminum getting some adjustments dialed in and a few beads adding filler wire.
    [​IMG]DSC00013 by Jonathan K, on Flickr
    Obviously still have lots of practice to do, but I tried messing with joints. It seems like the arc will favor one plate or the other, so one begins to melt away while the other seems virtually untouched. I can't seem to get it to focus on the joint itself.
    Any idea on what I need to adjust in order to keep the arc from wandering? More electrode stick out? More argon? Higher/lower frequency? More/less amps? Change in pulse rate? :confused:
    Thanks
  11. Aug 18, 2015 at 12:15 PM
    #5091
    INBONESTRYKER
    INBONESTRYKER Well-Known Member
    WY
    '96 access cab 3.4 5 spd manual 4X4
    Try placing your filler rod on the joint then initiate the arc on the rod.
  12. Aug 18, 2015 at 12:18 PM
    #5092
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    How is your tungsten grind? @45acp you could just need to fine tune your grind. Also what Tungsten are you using?
    steve o 77 likes this.
  13. Aug 18, 2015 at 12:38 PM
    #5093
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    I'm running 3/32 ceriated with a ball tip the width of the electrode, and ~1/8"-3/16" stick out from a #7 cup. Approximately 17cfh argon flow. 1/8" 6061 t6 plate.
  14. Aug 18, 2015 at 5:25 PM
    #5094
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    6061 is a bitch to weld, likes to crack. Get the blue tungsten, I think lanthanated. Works way better on ac. I also usually don't do a ball, either grind it flat or with a slight round.
  15. Aug 18, 2015 at 5:33 PM
    #5095
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Lanthana is (1%) is black.
  16. Aug 18, 2015 at 6:10 PM
    #5096
    nagorb
    Alabama
    2001 dbl cab 4x4
    2% blue.
    95 taco likes this.
  17. Aug 19, 2015 at 5:19 PM
    #5097
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    I switched to 1/16" 2% Lanthanated (Only other one I had), messed with the controls some more and it improved quite a bit. Not ideal yet, as it still tends to suck the puddle to one side or the other. It bridges the gap and I can fill most of the T joint, but with no real uniformity. I ran a second pass with pulse and no filler and it seemed to even out the puddle. Almost makes it look like I was being consistent. :laughing:
    [​IMG]DSC00014 by Jonathan K, on Flickr
    I cut a cross-section of the T joint and didn't see any signs of a gap.
  18. Aug 19, 2015 at 5:45 PM
    #5098
    STravis
    STravis Well-Known Member
    Travis
    Ruidoso, New Mexico
    2012 TRD Offroad
    Does anybody know the best place to get a JD2 model 32 bender from? Maybe somewhere with free shipping.
  19. Aug 19, 2015 at 9:04 PM
    #5099
    nagorb
    Alabama
    2001 dbl cab 4x4
    I'd go with a bigger tungsten, 3/32 should be good for 1/8 and 1/8 for 3/16 and 1/4. Even with tig I find joints to be weak so bevel everything.
    45acp[QUOTED] likes this.
  20. Aug 20, 2015 at 10:04 AM
    #5100
    95 taco
    95 taco Battle Born
    Looks better than mine, I had a few days at the end of semester last semester to play with TIG a little bit and it's fun, makes me want to get a TIG machine after we build the shop.
    Good to know, our welding book and instructor never mentioned a 2% lanthana filler rod.
