Anything welding
Discussion in 'Garage / Workshop' started by EL TACOROJO, Sep 17, 2010.
  1. Sep 11, 2015 at 3:51 AM
    #5141
    weldertaco
    weldertaco Mr.13%bodyfat
    texas
    TrailRunner
    4wd to 2wd conversion
    That's a lot of spatter too... What's your arc length like?
  2. Sep 11, 2015 at 9:59 AM
    #5142
    weldertaco
    texas
    TrailRunner
    The more I weld out here at the plants, the more I realize how many different rods there are and how much more learning I have to do.
  3. Sep 11, 2015 at 12:16 PM
    #5143
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    Does anyone know a legitimately knowledgable laser cutter technician that works on LVD CO2 lasers? My laser used to cut great, but lately it has been decreasing in quality. I can't find anyone that knows what is going on and it's irritating me.
  4. Sep 11, 2015 at 12:21 PM
    #5144
    coffeesnob
    coffeesnob Well-Known Member
    VA
    2010 access 4 cyl 2 wd
    you guys ever weld titanium?
  5. Sep 11, 2015 at 1:11 PM
    #5145
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I did back a few years ago !! No doubt more then a few years maybe 20
    I have not really followed any advancements but it used to be a major problem keeping the weld puddle in gas coverage as it cooled.
    You always did get lots of splatter with 6010
    Your not trying to whip in vertical are you ??
    Thing is we all find what works best for us.
    Being comfortable !!
    Being able to see the joint your welding
  6. Sep 11, 2015 at 2:08 PM
    #5146
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Ok, thanks for the tips.
    The teacher told us to leave it at 88 amps, he said when we run it more and get used to it to vary the amps and find where we weld best at.
    I did run a few beads at 86 amps and I didn't notice a difference.
    Arc length was to long for the first 5-6 passes, I'm getting better at keeping a consistent and correct arc length.
    There are quite a few electrodes that our book lists that I'd never heard of and even a few that my teacher hadn't seen in his 42 year welding career.
    I'm interested in this as well, been thinking of a titanium tube for a suppressor build.
    Yes, the only way my teacher will let us run 6010 is whip and pause.
    Yeah, some more practice and I'll get it, it's just a little frustrating.
    The teacher stresses comfort, I'm pretty comfortable until I get to the last 2" of the plate, then it's a little bit high, so I lowered the bar.
    I do need to find a better position so I can see my puddle and joint better.
  7. Sep 11, 2015 at 3:03 PM
    #5147
    weldertaco
    texas
    TrailRunner
    You do whip 6010 vertical. Not downhill but uphill yes.
    And yea your teacher says comfort is key and blah blah blah(been there done that in school) but in the real world you're often welding uncomfortable and in awkward positions. So if I was you, I'd actually make it more difficult to weld so when you get a job or something, you're prepared for it.
    Just my .02 after going from school to workforce.
  8. Sep 11, 2015 at 4:00 PM
    #5148
    Wyoming09
    New Tripoli Pa
    Super Springs
    That is where terms mean different things to different people .
    One might be forced into a uncomfortable position to be able to see but for sure your welding is going to suffer
  9. Sep 19, 2015 at 2:05 PM
    #5149
    weldertaco
    texas
    TrailRunner
    uploadfromtaptalk1442696542929.jpgflux core weave game strong !
  10. Sep 19, 2015 at 2:18 PM
    #5150
    95 taco
    95 taco Battle Born
    Got past vertical 6010 last week, then did overhead, passed flat 7018 with only 5 beads, vertical 7018 was kind of a pain, and now I'm on overhead.
    Finally got the blue star 2E running today to repair a disc, it welded great until I had 2 beads left that I wanted to run (mainly for looks) and then it would only run at half choke so I need to figure out why I'm having issues with fuel delivery.
    Also today was the first time I've welded with a 7018 AC rod, with a DC machine.
  11. Sep 19, 2015 at 9:35 PM
    #5151
    Wyoming09
    New Tripoli Pa
    Super Springs
    Fuel filter full of dirt or water from this sitting so long??
    A Miller Bluestar 2E very seldom is any of those
  12. Sep 21, 2015 at 6:21 PM
    #5152
    weldertaco
    texas
    TrailRunner
    uploadfromtaptalk1442884839458.jpg little flux action from today. Vert up of course.
  13. Sep 21, 2015 at 7:43 PM
    #5153
    95 taco
    95 taco Battle Born
    Probably dirt in the tank or filter, it's been sitting for a few years (been many years since it was used, and until a few months ago it was started and run every few months), but I ran 1.5 tanks of gas through it Saturday, it still has about a half tank but the fuel can that was used to fill it had dirt in the outside.
    Gonna check for a filter ( none visable at a glance, and I haven't had time to get involved with it), and probably add one just below the tank.
  14. Sep 22, 2015 at 1:21 AM
    #5154
    Wyoming09
    New Tripoli Pa
    Super Springs
    Not sure how I chopped off the rest of my post.
    I started to say I don`t see many of those.
    Water in the carb is not uncommon . Varnish from the gas drying in the carb can make a mess
    There should be a fuel filter unless someone thought it was not needed
  15. Sep 25, 2015 at 2:25 PM
    #5155
    95 taco
    95 taco Battle Born
    Finally got some time today and pulled the tank and cover off of it, no filter, gas flows great out of the tank, no gas in the bowl on the carb.
    If I mounted the fuel tank higher could I remove the fuel pump and use the machine with just gravity flow? If I have to replace the pump I'd rather go electric, but I don't know if I can find one with low enough PSI, and I don't think the carb is set up for a return line.
  16. Sep 25, 2015 at 2:47 PM
    #5156
    At The Helm
    At The Helm ATH Fab Vendor
    Morgan
    Gardnerville, NV
    2015 AC 4x4 TRD OR & 2019 T4R
    Kings, TC UCAS, SCS SR8's, ATH bumpers
    Pulled the trigger on a 40" press brake kit. The frame is going to be built from I beam with 1/4" plate reinforcements (purple outline in the cad drawing) and powered by two 20 ton air/hydro bottle jacks.
    BC907D60-5632-4739-9922-F4AE6E4BE663_zps_cc2b170e86e641b9c7bbf0946db3962f0b09f088.jpg
    687DC35F-F782-44AF-B028-B00ABB6CB3DA_zps_9e34173b1710b6257e590fd3f00ad3f6edfe14a5.jpg
  17. Sep 25, 2015 at 3:04 PM
    #5157
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    Is that the SWAG brake kit?
  18. Sep 25, 2015 at 3:07 PM
    #5158
    At The Helm
    Morgan
    Gardnerville, NV
    Yes it is..
    I already have their 20" finger brake, but I want a wider capacity.
  19. Sep 29, 2015 at 7:34 AM
    #5159
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    Sorry for the novice question, but it needs to be asked. I have experience with oxy/acetylene torches both from using my Uncle's and setups at work. Because of that, I've never gone through the experience of getting the cylinders filled/exchanged. Google searching makes the process sound a little complicated, depending on who "owns" the tanks. I was recently given two oxy and one acetylene tank. One of the oxy tanks has "Praxair" stamped on the collar, the other "Silver State Supply". The acetylene tank has a Praxair sticker. Do I have to take these back to Praxair to have them refilled or exchanged? Can I just take them to Airgas or some other industrial supply and have them filled?
  20. Sep 29, 2015 at 9:42 AM
    #5160
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    You are going to need an account with your local welding supply house. Once you have an account, all you do is switch tanks out. You own your tanks, so you will be swapping with the welding supply house. Your empty for their full can. They may want to bill you for a hydro test, usually around $10. You will have to pay for the gas that is in the new can.
    The welding supply house doesn't care who's name is on the can. You will see all sorts of different companies on the bottles.
