Anything welding
Discussion in 'Garage / Workshop' started by EL TACOROJO, Sep 17, 2010.
  1. Oct 10, 2015 at 2:44 AM
    #5221
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    It really will not matter on the heavy hauler there is no vertical load the three pieces of bar stock would be enough to hold it together .
    More then likely just to add some weight to front of the tractor
    I would guess the other welds are just for pretty and to keep dirt out.
    Wow you put the plates on the outside rather then the inside of the coal hopper /bin around these parts we put the wear plates on the inside.
    Did a few in Stainless to make things flow easier.
    It is a shame some people take no pride in there work then some just don`t care.
  2. Oct 10, 2015 at 4:33 AM
    #5222
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    it's 100% to add weight. I forget what the stamp on it said, but they had the front bumper weight, and then a 12.5 ton weight strapped to the flatbed. this load was only 350,000 lbs, but with our heavier loads, the truck needs some ass to maintain control at "higher speeds" on public roads, and to keep from spinning tires on the construction roads.
  3. Oct 10, 2015 at 6:23 AM
    #5223
    weldertaco
    weldertaco Mr.13%bodyfat
    texas
    TrailRunner
    4wd to 2wd conversion
    I would be worried about the weight of it mixed with the jarring of potholes and stuff on the road cracking the welds but I guess this is where engineers know more and better(Not sarcastic or rude BTW).
    And yea we had to put em on the outside since the silos have some liner on the inside that they didn't want welding on apparently. But idk that for sure. I'm not the boss. Just a hand.
  4. Oct 10, 2015 at 7:21 AM
    #5224
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    If you look at the front face of the bumper, those three circles you see are pins that go straight through all 8 inches of steel, and are welded on either side. They look like 4" round stock, so it'd be pretty hard to shear all three and break the welds before someone catches it.
  5. Oct 10, 2015 at 7:22 AM
    #5225
    Wyoming09
    New Tripoli Pa
    Super Springs
    Just where are you working ??
    if you drove that any place close no matter how long and the number of axles bridges would be falling down
  6. Oct 10, 2015 at 7:26 AM
    #5226
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    There are plenty of ways to get good penetration on thick plates. That's why different weld processes exist. I've seen welding processes as high as 1500 amps, and have personally welded on 2" thick bull dozer tracks with 700 amps. A 300 amp mig welder isn't shit.
    JLee likes this.
  7. Oct 10, 2015 at 8:11 AM
    #5227
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Southern Maryland, right on the Chesapeake Bay.
    we built a barge trestle where all of our big or heavy loads come in. they get off-loaded from the barge and set up on the heavy haul trailers there, and then are driven ~5 miles up the road to the plant. no bridges to cross or go under, and no overhead power lines to go under, so really the biggest obstacle is just coordination with state and local police to get the 3:00 am escorts. luckily I don't have to do that. I only take charge once it's on site.
  8. Oct 10, 2015 at 11:35 AM
    #5228
    weldertaco
    texas
    TrailRunner
    Daammnnnn! That's some heavy weight
  9. Oct 10, 2015 at 12:20 PM
    #5229
    Wyoming09
    New Tripoli Pa
    Super Springs
    Just about strong enough to move my Ex-wife now that she put some weight on.
  10. Oct 10, 2015 at 2:15 PM
    #5230
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
  11. Oct 19, 2015 at 6:27 PM
    #5231
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Taking a test November 30th and if I pass (bend and visual) I'll be hired at a local shipyard.
    Test is going to be vertical 7018 and dualshield, bevel plates with backing strap, 1/8" gap.
    If I'm hired I'll have 2 weeks of training and then I have to pass an all positions test, I believe it's dualshield and 7018 with X-Ray.
  12. Oct 20, 2015 at 12:28 AM
    #5232
    Wyoming09
    New Tripoli Pa
    Super Springs
    Best of Luck !!
    Seeing some of the welds at the old Philadelphia Naval Yard it is a wonder the ships don`t sink when the dry dock is flooded
  13. Oct 22, 2015 at 5:04 AM
    #5233
    fireman903
    fireman903 Well-Known Member
    new jersey
    06 taco
    3 inch lift 33 in tires undercover emergency responder light 30 rigid led light bar bed lights engine compartment lights
    any one ever build a welding cart with a 250v 50 amp 2 plug extension cord attached to it? if so how did you wire it up? or how would you ?
  14. Oct 22, 2015 at 6:27 AM
    #5234
    RAT PRODUCTS
    Farmington, MN
    Cummins Coal Roller
    I've made a few welder extension cords. Just buy a welder plug receptacle and wire it to your 6 or 8ga drop cord. You need 2 wire. So 2 hots and a ground. Don't need a neutral. I've also found that buying the 50' welder extension cord off eBay is only a few bucks more than making your own and it's durable as hell.
  15. Oct 22, 2015 at 7:00 AM
    #5235
    fireman903
    new jersey
    06 taco
    yea I looked at just buying one but I need two plugs for a multi-process welder and a plasma cutter so I don't have to keep switching plugs every time I need to change
  16. Oct 22, 2015 at 2:09 PM
    #5236
    Wyoming09
    New Tripoli Pa
    Super Springs
    Buy yourself A 100 amp sub panel mount this to your cart 2 50 amp breakers at least one or two 15 amp breakers for lights grinders etc. Feed this by a 100 amp breaker in your main panel.
    I run 3 50 amp breakers off a 60 amp breaker two xmt-304 welders and my plasma cutter of course only one at a time gets used plus a 15 amp breaker for 120vac
    Hardwire your welder and plasma cutter to the breakers that way your circuit protection is right there
    A 50' length of 8/3 SOOW if you only plan one process at a time.
    JLee and weldertaco like this.
  17. Oct 22, 2015 at 3:31 PM
    #5237
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    What are you guys paying to exchange/refill a #4 acetylene bottle? Tractor Supply Co wants $90.
  18. Oct 23, 2015 at 12:29 AM
    #5238
    Wyoming09
    New Tripoli Pa
    Super Springs
    This is a regional thing But I will have to check today
  19. Oct 23, 2015 at 3:39 AM
    #5239
    fireman903
    new jersey
    06 taco
    I cant jut put 2 outlets in 2 junction boxes and run a 10 ft cord with a plug to the pre existing outlet hooked to a 50 amp breaker
    I only plan on using one at a time
  20. Oct 23, 2015 at 2:07 PM
    #5240
    Wyoming09
    New Tripoli Pa
    Super Springs
    It is your project I told you a easy way .
    How I did in fact do mine.
    The length of you input is what ever you need.
    Just curious how you would split the 8/3 into 2 50 amp plugs
    Since Inverters can be very expensive when they go Kaboom!!!! and the magic smoke escapes
    I also have fast blow 40 amp fuses mounted in both legs of the input cord in case any one has inverter welders repair costs could be several hundred compared to several thousand.
