Anything welding
Discussion in 'Garage / Workshop' started by EL TACOROJO, Sep 17, 2010.
  1. Mar 24, 2016 at 8:17 AM
    #5541
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    I think my problem is either in the trigger or whatever that spring thing is when you take off the tip.
  2. Mar 24, 2016 at 8:18 AM
    #5542
    wilcam47
    Will
    Bourbon state
    I just keep the wire in the machine
  3. Mar 24, 2016 at 8:22 AM
    #5543
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    That is your liner. It runs all the way back to the welder. I would start there. They are somewhat universal. You buy one longer than your lead and cut to size.
  4. Mar 24, 2016 at 8:28 AM
    #5544
    wilcam47
    Will
    Bourbon state
    Im hoping its just dirty, like I said I havent used it much to warrant being changed IMO...Im talking less than 5 hours total use if that. Ive just welded one game camera box and half of another and couple small welds so it shouldnt be worn out. I'll look into cleaning and see how that goes.
  5. Mar 24, 2016 at 9:46 AM
    #5545
    weldertaco
    weldertaco Mr.13%bodyfat
    texas
    TrailRunner
    4wd to 2wd conversion
    If the wire is old and rusty then get new wire as well.
    wilcam47[QUOTED] likes this.
  6. Mar 24, 2016 at 1:35 PM
    #5546
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    You can try and lead them to water but they just fall in.
  7. Mar 24, 2016 at 2:04 PM
    #5547
    weldertaco
    texas
    TrailRunner
    Meanwhile...uploadfromtaptalk1458853466343.jpg lol fuck cubicles... Love my job. So blessed
    rileySB and Rakso like this.
  8. Mar 25, 2016 at 5:58 AM
    #5548
    KaptainH
    KaptainH Well-Known Member
    Kris
    Gainesville, GA
    Black 2013 DCLB Sport
    I'm interested in tinkering with welding- I don't want to spend a ton of money on a welder.
    My goal is to weld between 1/16" steel to MAYBE 1/4" steel but I don't even know what I would make with that. I would think my typical project would be 1/8". I wouldn't hate trying to tack together some aluminum either (even though the machines I'm looking at say they aren't for aluminum)
    I'm set on trying a cheap harbor freight welder...
    So my question is: Which of these two should I get? I have watched a days worth of videos on stick welding vs flux core welding but I still haven't fully answered my question as to which is the better value for what I want to weld.
  9. Mar 25, 2016 at 6:14 AM
    #5549
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    Save your time and money with those machines. I say that having made that same mistake.
    95 taco and KaptainH[QUOTED] like this.
  10. Mar 25, 2016 at 6:17 AM
    #5550
    KaptainH
    Kris
    Gainesville, GA
    What you recommend?
  11. Mar 25, 2016 at 6:18 AM
    #5551
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Yep don't do it buy a quality machine or you will regret it there are tons of good affordable machines out there HF is not the place to be looking for a welder. Start on Craigslist for a good used one.
  12. Mar 25, 2016 at 6:20 AM
    #5552
    ckeene9
    Chesterfield, VA
    See Build Thread
    Pick up a miller, Lincoln, or Hobart and a bottle of gas. Look for a used one or save up a bit.
  13. Mar 25, 2016 at 10:39 AM
    #5553
    Wyoming09
    New Tripoli Pa
    Super Springs
    If your buying new go for the Hobart Good Hobby machine
    Used Miller Lincoln or Hobart.
    Take someone along who can weld down load and read through the operators manual of machines you might like.
  14. Mar 25, 2016 at 10:40 AM
    #5554
    wilcam47
    Will
    Bourbon state
    I think Ive gotten my problem with my welder fixed. I had to take apart the trigger and clean the contact inside. It wasnt real dirty looking but there was some corrosion and the little washer looked like it was hanging up and not engaging correctly so I lightly sanded it down and it seems to be working better now. I also sprayed the tip of the liner off with brake cleaner as it seemed to be dirty. I tested it a little last night and it seems to function better than it has.
  15. Mar 25, 2016 at 2:51 PM
    #5555
    At The Helm
    At The Helm ATH Fab Vendor
    Morgan
    Gardnerville, NV
    2015 AC 4x4 TRD OR & 2019 T4R
    Kings, TC UCAS, SCS SR8's, ATH bumpers
    Change out those parts you cleaned with brake cleaner right away and don't use them. Welding on parts that were cleaned with brake cleaner produces phosgene gas, which is deadly!
    JLee likes this.
  16. Mar 25, 2016 at 3:42 PM
    #5556
    JLee
    Jerry
    Grass valley CA
    X2 remove everything and toss it in the trash!
  17. Mar 25, 2016 at 3:48 PM
    #5557
    Wyoming09
    New Tripoli Pa
    Super Springs
    If you want to clean consumables wire wheel or scotch brite pads
    He might be lucky and have the not so deadly brake clean!!
  18. Mar 25, 2016 at 4:02 PM
    #5558
    JLee
    Jerry
    Grass valley CA
    I wouldn't take that chance it's a few bucks vs your life!
  19. Mar 25, 2016 at 4:52 PM
    #5559
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Hobart 140 and call it a day. Don't mess around with those garbage welders.
  20. Mar 25, 2016 at 5:29 PM
    #5560
    Wyoming09
    New Tripoli Pa
    Super Springs
    They did not want to install a new liner for sure they will use what they have as well
    To some $$$ is more important
