Anything welding
Discussion in 'Garage / Workshop' started by EL TACOROJO, Sep 17, 2010.
  1. Nov 17, 2011 at 9:57 PM
    #601
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    Yeah I've actually been thinking it would be nice to get one for my shop for occasional use where I dont need my 210 or its too big, and also to mess around on and improve my tig skills, plus it could serve as a backup welder if my 210 goes down for some reason.
  2. Nov 17, 2011 at 10:02 PM
    #602
    mhuff29
    mhuff29 TÅpƐwo®m
    Arvada, CO
    05 Tacoma Double Cab SR5
    Air Filter (K&N) Wheels & Tires
    No clue on how to weld, but would like to get started. Haven't read through all the pages yet, but will. Was going to take a course at the community college but all full.
  3. Nov 17, 2011 at 10:33 PM
    #603
    cummins6speed
    cummins6speed Well-Known Member
    '05 4Runner Limited Edition
    Custom extended travel 2.5" King RR coilovers, 1.25" Camburg uniball uppers, homebuilt tube bumper
    It would be a nice machine to work on your tig skills and for portable welding. Too bad its only DC though
  4. Nov 17, 2011 at 10:36 PM
    #604
    RelentlessFab
    Eric
    Sparks, NV
    yeah wish is was AC/DC so it could do aluminum TIG.
    That might be a deal breaker really, since there probably isnt much that I'd be interested in TIG welding thats not aluminum. :(
    Would be a great small welder for other stuff still though.
  5. Nov 17, 2011 at 10:58 PM
    #605
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    This was the big gotcha I noticed too.
  6. Nov 17, 2011 at 11:04 PM
    #606
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    Def great for other stuff.
    I was pricing AC/DC units a while back and it seems like you're into one of those for almost $3k. Unless you're looking at Everlast or something similar.
  7. Nov 17, 2011 at 11:09 PM
    #607
    RelentlessFab
    Eric
    Sparks, NV
    http://store.cyberweld.com/mitigwedi180.html
  8. Nov 17, 2011 at 11:09 PM
    #608
    cummins6speed
    You could start doing chromo roll cages :D
  9. Nov 17, 2011 at 11:10 PM
    #609
    cummins6speed
  10. Nov 18, 2011 at 8:02 AM
    #610
    Anthony250
    Anthony250 Ex Fabricator
    Anthony
    Rialto CA
    99 Tacoma LT Prerunner
    LSK Race Kit, King Shocks, Methods, Glassworks, Baja Designs, Built by myself.
    When welding spindle gussests you just remove everything you can , and weld in different spots to prevent warp?
  11. Nov 18, 2011 at 8:09 AM
    #611
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Don't forget to clean the metal on the spindle before welding. Grinding wheel does the job quick.
  12. Nov 18, 2011 at 8:15 AM
    #612
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    I stitch weld spindle gussets in 1.5 to 2" stitches spacing them about 3" apart to not over heat the spindle and warp it. Just pull the ball joints before you weld them I don't pull the Bering or anything.
  13. Nov 18, 2011 at 8:17 AM
    #613
    Anthony250
    Anthony
    Rialto CA
    Oh ok thats where i was worried if i had to pull the bearing.Going long travel ! . Ill have to get some spindle gussets,
  14. Nov 18, 2011 at 8:25 AM
    #614
    JLee
    Jerry
    Grass valley CA
    I've never over heated a Bering just let it cool completely before you start the other stitches.
  15. Nov 18, 2011 at 8:32 AM
    #615
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    Haha it isn't ideal that I usually wear synthetic underwear too :/ but I've got a pair of pants that are now designated for welding..there's a shit ton of tiny black burn holes in them
  16. Nov 18, 2011 at 9:16 AM
    #616
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
  17. Nov 18, 2011 at 9:59 AM
    #617
    RelentlessFab
    Eric
    Sparks, NV
    no problem man! If I were getting an entry level TIG, that would be my choice.
  18. Nov 18, 2011 at 10:05 AM
    #618
    cummins6speed
    I agree with stitch welding them but also, if you plan on really beating on them, I also suggest pre- and post-heating the spindle so you don't weaken them.
    I have heard that if you beat on a stock spindle it will probably just bend but welded cast spindles usually crack when they are beat on too hard and I would bet its because of not pre- and post-heating them
  19. Nov 18, 2011 at 10:08 AM
    #619
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    Seems like a good choice. At some point, I might look around for a used one at my local shop--they seem to have stuff every once and a while.
  20. Nov 18, 2011 at 10:25 AM
    #620
    RelentlessFab
    Eric
    Sparks, NV
    Hmmm. And with that in mind, maybe UCA's or even LT down the road. My truck needs some new UCAs and rather than forking out the cash on some, I was considering building some but I would want to TIG those.
    :D
    Ya me too. Seem to be a pretty good little setup for occasional projects.
