Anything welding
Discussion in 'Garage / Workshop' started by EL TACOROJO, Sep 17, 2010.
  1. Jan 5, 2018 at 5:50 PM
    #7521
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    My main concern is that you have a clound of hydrogen gas in a fab shop when you do this; hydrogen gas is ~20x lighter than ambient air and with active ventilation, it may not be a problem, but i was just letting it be known that it could quickly become a problem under the right circumstances. And then i briefly tried to explain where the h2 came from and the by products of the reaction.
    Drainbung likes this.
  2. Jan 5, 2018 at 5:53 PM
    #7522
    HCFab
    HCFab Hudson Custom Fabrication
    Zach
    Central Idaho
    Overland 04' v6 4x4 5spd Xtracab, Lunar Mist.
    Do you guys want to see where my dangerous gases come from? :anonymous:
    wilcam47, jjsul, Drainbung and 2 others like this.
  3. Jan 5, 2018 at 8:28 PM
    #7523
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I agree. Causing an explosive condition will take a very tightly enclosed environment.
    The scenario is possible, but not likely.
    I compliment you on your chemistry lesson. It is very good to be aware.
    There is no sarcasm associated with my post.
  4. Jan 6, 2018 at 11:48 AM
    #7524
    WarrenG
    WarrenG Well-Known Member
    Here is my 2g TIG root (horizontal groove weld on 3/8” plate)Just finished my 2nd year schooling for welding here in Alberta.
    As a sheet metal worker, its a bit out Of my scope of work but new challenges are fun. Its not perfect, but not bad.
    For those who may not know, they really only care how the backside of the weld turns out.
    Drainbung and FastEddy59 like this.
  5. Jan 6, 2018 at 11:51 AM
    #7525
    jeffz0rz
    jeffz0rz Well-Known Member
    san diego
    1996 tacoma 4cyl, 5spd
    Spring perches for a Spring under install on a first Gen.
  6. Jan 6, 2018 at 11:54 AM
    #7526
    WarrenG
    Custom ;)
  7. Jan 6, 2018 at 12:09 PM
    #7527
    MKEN
    MKEN Member
    NH
    2017 White SR AC 4x4 MT with Utility Package
    I took a creative welding class through the adult education offerings at the high school, one night a week last fall. It was fun, I'll do it again
  8. Jan 6, 2018 at 6:38 PM
    #7528
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    What's the max amperage for romex 14/2 ?
  9. Jan 6, 2018 at 6:41 PM
    #7529
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    15A maybe 20 at peak. No more.
    Rakso[QUOTED] likes this.
  10. Jan 6, 2018 at 6:48 PM
    #7530
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    Would a 25ft run hold for this specs on 120V?
  11. Jan 6, 2018 at 6:54 PM
    #7531
    FastEddy59
    Eddie
    Think you should be OK. My welding plug is right by my breaker box & I use a heavy gauge extension cord built for the Mig & I believe it's 25ft long.
  12. Jan 7, 2018 at 3:34 AM
    #7532
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    If your running a new circuit go bigger .
    What breaker is on the circuit now ??
    FastEddy59 likes this.
  13. Jan 7, 2018 at 5:40 AM
    #7533
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    14-2 15amp.
    I would run 12-2 on a 20 amp breaker for that welder.
  14. Jan 7, 2018 at 9:52 AM
    #7534
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    I ran that circuit with a 15A breaker a few years back. I guess I can just replace the wiring and breaker. It Is basically behind the breaker box.
  15. Jan 7, 2018 at 9:56 AM
    #7535
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    Can a dual voltage outlet be install with the same cable? 110/220 @30amps?
    I would not run both voltages at once.
    Or should I just run two cables?
    I'm setting up my welder outlets in the garage.
  16. Jan 7, 2018 at 10:13 AM
    #7536
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    No, for a 30A breaker, you should be using #10 wire. Your breaker will determine your minimum wire size.
    FastEddy59 and llibrm like this.
  17. Jan 7, 2018 at 10:15 AM
    #7537
    deeezy
    Dana
    Hawaii
    And there is no dual voltage outlet. An outlet/receptacle is either 120v or 240v. You can wire in two different outlets, one 120v and another at 240.
    FastEddy59 and Rakso[QUOTED] like this.
  18. Jan 7, 2018 at 10:18 AM
    #7538
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    Cool thanks. I guess I meant having the 110 and the 220 outlets in the same box on the wall.
  19. Jan 7, 2018 at 10:19 AM
    #7539
    deeezy
    Dana
    Hawaii
    Yeah, you can do that. Just use the appropriate 240v outlet so someone doesn't accidentally plug in a 120v appliance into the 240v outlet. I've personally seen that happen.
  20. Jan 7, 2018 at 3:07 PM
    #7540
    Wyoming09
    New Tripoli Pa
    Super Springs
    First How much did you get paid to haul this away??
    Unless that was stored or used in a climate controlled area the last 20 years I will be surprised it still works
    The transformer insulation tends to break down.
    Works on the same principal as the newer ones a shunt moves in the transformer to change output .
    I would guess the battery charger might have a secondary transformer to regulate voltage if you pull the cover should be easy to figure out
    Then it could just pull out of the main transformer might be 6 volts
    I hope your used to Arc starting on AC
