Anything welding
Discussion in 'Garage / Workshop' started by EL TACOROJO, Sep 17, 2010.
  1. Oct 20, 2018 at 5:03 PM
    #9541
    dofartshavelumps
    dofartshavelumps Well-Known Member
    NH
    2015 SR DCSB 4x4 4.0 MT
    Anyone ever build their own welder from a spare gas engine and alternator? I read something about this a while ago and may give it a whirl.
  2. Oct 20, 2018 at 5:09 PM
    #9542
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    You can do it cheaper with a couple of 12 volt batteries, too.
    I'm good with buying a welding machine.
  3. Oct 20, 2018 at 5:17 PM
    #9543
    dofartshavelumps
    NH
    Yea I hear you, I have 3 that work perfectly fine. It is more just for something to keep me off the streets. I don't think you can do anything thick and the beads don't look good and I agree it is easier and probably not much more to just buy one. Having said that I like to tinker and find things out the hard way.
    koditten[QUOTED] likes this.
  4. Oct 20, 2018 at 6:41 PM
    #9544
    RickyTaco77
    RickyTaco77 Well-Known Member
    Steven
    Gastonia, NC
    2016 TRD Off Road 4x4/ 1995 4runner 4x4
    A couple boat anchors made from some scrap dom tube.
    Shmellmopwho and koditten like this.
  5. Oct 20, 2018 at 7:42 PM
    #9545
    koditten
    Kirk
    Central Michigan
    Those should work great!
  6. Oct 20, 2018 at 7:48 PM
    #9546
    RickyTaco77
    Steven
    Gastonia, NC
    I got this in a text with," Can you make 2 of these? "I hope they work for him.
  7. Oct 20, 2018 at 7:55 PM
    #9547
    Shmellmopwho
    Shmellmopwho Well-Known Member Vendor
    Lomita CA
    2013 White DCLB TRD sport
    Bunch of stuff
    Pretty hard without a hard physical guide of some sort. Freehanding it comes out kinda sloppy when I try it. I can’t get nicer tighter notches than what my notcher can produce
  8. Oct 20, 2018 at 8:03 PM
    #9548
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Got my hands on two laser cut 16” diameter circles cut out of 1/4” plate steel (scrap from someone’s job). Now to figure out what I’m gonna do with it.
    Shmellmopwho likes this.
  9. Oct 20, 2018 at 9:29 PM
    #9549
    Shmellmopwho
    Lomita CA
    Bunch of stuff
    Pew pew practice!
  10. Oct 21, 2018 at 2:47 AM
    #9550
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    If your good with electronics and can design and build your own control circuits that will be the challenge what good is having a welder .
    With output at one set point
    Plan on a Cap bank to smooth out the output ?
  11. Oct 21, 2018 at 4:38 AM
    #9551
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I think I’m gonna cut one up and make some u bolt flip plates out of it. I was banging my stock u bolts in rocks yesterday!
    Shmellmopwho[QUOTED] likes this.
  12. Oct 21, 2018 at 5:36 AM
    #9552
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    Weld them together and make it into a welding table. Even better if you put it on a swivel so you can sit and weld and rotate the table :)
    EatSleepTacos[QUOTED] likes this.
  13. Oct 23, 2018 at 4:22 PM
    #9553
    koditten
    Kirk
    Central Michigan
    Bent spindle on the drift boat trailer.S4Yg40hfqUn_R8AkZLV4_gz4bfhhfgn8VCBoOjDO_354bc8719e247913994f2e0df49878ce81dc9d48.jpg Lr7qR2OBQeM6wLWcf9jShzDtn8e3Icf34BHdn_4z_794ebd875a0a5f5cdd651ff6e59488fd1c0b27ac.jpg Avw4qraHZXu65NpnIvdSZKwB28TAmfxpHq_E8slh_c93a99e2a60f81a33f0b70362d02d9e35fd18ec9.jpg
    I couldn't have guessed any closer to where the spindle ended.
    D2. likes this.
  14. Oct 23, 2018 at 4:24 PM
    #9554
    koditten
    Kirk
    Central Michigan
    Cleaned up the pipe and welded on a new spindle.hK4OvBOtUUUZF-yO-9iBgVqiR4my7bJIXmOR50KP_73254ea0dec0edd6ca0384e808ec5ebf9d640f2a.jpg 7RrBJOsDpIunZm1370J44uJyXSbWwIRv6pS64jvP_4988ae23d517f4eb79173afefe25a1b807bd883d.jpg 7vyhutOyJ1DPPbqZ_8Sg4-MBrbpRI4BfdNb3-cYx_bfbee92fb9ae2bf8f499ea529875727281d5833b.jpg
    jjsul, stairgod and RickyTaco77 like this.
  15. Oct 23, 2018 at 6:30 PM
    #9555
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    A little stick practice/refresher. 7018 .
    I my hand was steadier I would almost call it good
    la0d0g, koditten and Drainbung like this.
  16. Oct 23, 2018 at 9:34 PM
    #9556
    la0d0g
    running for the hills
    For crawling not hauling
    And ride that wall a little more :)
    stairgod[QUOTED] likes this.
  17. Oct 24, 2018 at 12:23 AM
    #9557
    Wyoming09
    New Tripoli Pa
    Super Springs
    Pray tell just how did you bend the spindle ??
    Was it like that when you installed the axle??
    To many Hard landings ?
  18. Oct 24, 2018 at 12:47 AM
    #9558
    koditten
    Kirk
    Central Michigan
    Nah. It was a used axle that I recycled. I first thought it was a bent axle. Those are easy to repair. I didn't find this had a bent spindle until I pulled the hub.
    Its hard to see a bent spindle/hub without a tire attached, so I didn't find out until I was towing it, that it was bad.
    Wyoming09 and stairgod like this.
  19. Oct 24, 2018 at 3:03 PM
    #9559
    RickyTaco77
    Steven
    Gastonia, NC
    1540418586390436684625316584248.jpg Burning off the paint!
  20. Oct 24, 2018 at 4:21 PM
    #9560
    jjsul
    jjsul Well-Known Member
    James
    New Hampshire
    95.5 OME
    How did you clear out the propane take before cutting? Fill with water? Dry ice?
    I've been too scared to cut any open! :bananadead:
