Anything welding
Discussion in 'Garage / Workshop' started by EL TACOROJO, Sep 17, 2010.
  1. Aug 14, 2012 at 11:52 AM
    #961
    dmb
    dmb Well-Known Member
    Boise, ID
    Totally! I'm loving life right now.
  2. Aug 14, 2012 at 1:29 PM
    #962
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    That's great!
  3. Aug 17, 2012 at 7:34 AM
    #963
    JLee
    JLee The Man! Vendor
    Jerry
    Grass valley CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Nice Oxy bead just wait and see what you can do with a Tig :cool:
  4. Aug 17, 2012 at 8:01 AM
    #964
    My68ur8trd
    My68ur8trd Well-Known Member Vendor
    Justin
    Williamsburg, VA
    2007 TRD OR Dcab 4x4
    URD Catback | TRD CAI | TRD S/C | APR X-1 | DTLT | APR 2.85" Pulley |Fabtech 6" | Icon C/O | Alcan Leafs | 33 Grabber AT2 | 17" XD Addicts
    So I am working with some 3/16 plate and .120 wall tubing (1.5" OD). I swapped the welder to .035 wire and went to town.
    I have a question. The welder ( Lincoln Pro Mig 180 Dual) came with .025 wire that I had been using for other projects with thinner metal. The welds always came out nice a clean ( CO2/Argon mix).
    I picked up a roll of .035 Hobart wire form TS yesterday and played with it some on a few practice pieces. The welds looke OK ( iad to play with the speed), but I am getting a brown dusty residue that I did not get before. I brushes off and you cannot tell if I wire wheel it.
    Is this due to the wire, or possible the gun position? ( I am working on a better technique for tubing) I usually weld with a forearm down, but I guess I need to float to do this.
    Thanks for the input in advance
    Justin
  5. Aug 17, 2012 at 8:12 AM
    #965
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    It almost sounds like the stick out is too much or you're not feeding the wire fast enough.
  6. Aug 17, 2012 at 8:21 AM
    #966
    JLee
    Jerry
    Grass valley CA
    Yeah it happens to me with 1/4" plate when i have the voltage up and the wire speed down I just hit the with a wire wheel after and it's good to go.
  7. Aug 17, 2012 at 8:44 AM
    #967
    Swimmerboy2112
    Swimmerboy2112 Well-Known Member
    Brian
    Walnutport, PA
    02 TRD V6 5 Speed X-Cab
    Borla exhaust, K&N intake, ARB bumper, 16x8 Konig Countersteer Offroad wheels, 20% Tint
    Nice thread, never noticed it before.
    I used to repair welders/plasma cutters for a living.
    Keep up the good welds guys!
  8. Aug 17, 2012 at 9:15 AM
    #968
    TruckyTruck
    TruckyTruck Well-Known Member
    Tundra Crewmax TSS Off-Road 4x4, sr5/leather
    This is what ill be starting in about 10 days... cant wait to make things. My brain is on overload thinking about all the things i can make for my Tacoma!
  9. Aug 17, 2012 at 10:49 AM
    #969
    My68ur8trd
    Justin
    Williamsburg, VA
    Thanks,
    Thats exactly my scenario, Max power and a slower feed. I tried to up the speed a little, but I was getting some build up. I also checked the regulator to make sure the gas flow was high enough, and it all looked ok.
    I can brush it off, I was just curious as to what caused it. It will be painted anyway.
    On another note ( for you guys without a Torchmate ;)), do you have a good source for tabs and other small laser/plasma/waterjet cut parts? I have been looking at A&A manufacturing and they carry some pretty trick things.
    Justin
  10. Aug 17, 2012 at 12:34 PM
    #970
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    I get that brown dusty residue around my welds a lot. I do like running hot and fast though, so thats probably it. Simply brushes off so I wouldn't think twice about it I'd say it just means you're running nice hot solid welds.
    If you need miscellaneous tabs/etc, sketch what you need and pm me. I can cut and ship flat rate for reasonable prices. Up to 3/4" thick steel(recovery points?), and 1/2" aluminum parts.
  11. Aug 17, 2012 at 3:13 PM
    #971
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    That's what I like to see! Finally getting the hang of this stick welding thing. 7018 rod at about 90 amps.
  12. Aug 17, 2012 at 6:20 PM
    #972
    littledvl
    littledvl ride BMX!
    Eric
    Saint Leonard MD
    08 taco dc 4x4 / 15 tundra dc 4x4
    Too many to list
    :cheers: I have done it a few times using 7018/9018 , thats when you know your doing it right!
  13. Aug 17, 2012 at 6:22 PM
    #973
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    Now to make my vertical passes not look like chicken poo :laugh:
  14. Aug 17, 2012 at 6:31 PM
    #974
    littledvl
    littledvl ride BMX!
    Eric
    Saint Leonard MD
    Too many to list
    1/8" 7018 rod and weave is how i do uphill vertical in almost any situtation. Keep a short arc and work slow to build shielfs, stay at your 90 amps and you should be able to make some clean/strong welds in no time. :cool:
  15. Aug 17, 2012 at 6:37 PM
    #975
    Btnewman
    Btnewman Benjamin Newman
    Benjamin
    Grand Junction co
    Uh. It's beat to he//. But it's only 1 owner.
    Custom body work/damage ARB rear locker Bumpers Shocks Other parts Tires and Rims Air tank fully plumbed into truck "Golf ball mod"
    This thread is Definately subbed!
  16. Aug 17, 2012 at 6:58 PM
    #976
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    Yeah that's how I've been doing it, Just not very consistent yet. Just need more practice.
    edit: I wonder if the fact that these rods are probably 4+ years old and have been in open air the entire time is messing with things? Our humidity rarely gets over 20% but still.
  17. Aug 17, 2012 at 7:11 PM
    #977
    littledvl
    littledvl ride BMX!
    Eric
    Saint Leonard MD
    Too many to list
    That would have a affect to it, there still usable but as you are having issues with being consistent, im betting thats not helping. I have used brand new rods and have had the same issues, gets frustrating.
  18. Aug 17, 2012 at 7:27 PM
    #978
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    You could also toss the rod into a rod oven or other heat source to dry them out.
  19. Aug 17, 2012 at 7:29 PM
    #979
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    Well I have probably 6 or 7 lbs of this rod left, and about 10 lbs of 6011 at my disposal to practice with so until I actually weld an actual project with stick the old rod will do.
    I also tried aluminum stick the other day, holy cow the entire rod is gone in about 10 seconds! It makes pretty welds though.
  20. Aug 17, 2012 at 7:29 PM
    #980
    JayS
    JayS Well-Known Member
    Angleton, TX
    05 Prerunner Stock
    Just joined this group and saw this. I like to weld. And do some occasional blacksmithing when it is not to hot outside to fire up the gas forge. Just started into metal work a year or two ago. Can't wait to weld up a bumper for my new (to me) Prerunner. Here is a pic of the last thing I made up. Needed something to shoot at with the pistols when I had some guys from work come over to blow off some steam.....and blow up some homemade tannerite. Just some old leftover angle I had laying around. And yes I was careful with the galvanized coating.
