Anything welding
Discussion in 'Garage / Workshop' started by EL TACOROJO, Sep 17, 2010.
  1. Dec 29, 2018 at 3:05 PM
    INBONESTRYKER
    INBONESTRYKER Well-Known Member
    WY
    '96 access cab 3.4 5 spd manual 4X4
    @Rakso Use some JBWeld epoxy (not the quick setting stuff) to get that bushing stuck in place. You'll need to remove the shaft in order to clean any oil or grease from the inside of the tube. also clean the outside of the bushing. Put the mixed epoxy on the flange and about halfway up the side of the 'hat'. It wont take very much epoxy to do this.
    Shmellmopwho likes this.
  2. Dec 29, 2018 at 3:51 PM
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    Cool man I'll try that. Thanks for the input.
  3. Dec 30, 2018 at 1:47 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    So many different things effect output .
    Just experiment with your different settings see what changes what works best.
    Myself I use only .023 wire with those little welders does it come with those drive rolls ??
    Does your owners manual give you a source for the consumables ??
  4. Dec 30, 2018 at 10:24 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Funny I find when things like that happen at work it is because everyone things all the youngins should be as smart as the rest of us after doing these things for 40 years.
    Best is putting covers back on after they tighten each fastner as it gets put in.
    koditten[QUOTED] likes this.
  5. Dec 30, 2018 at 7:10 PM
    mjbtaco
    mjbtaco low and slow
    Michael
    Montclair , so cal
    Turbo'd 95.5 extra cab and 2013 Silver DCSB TRD Sport
    PERFORMANCE Custom Turbo Setup FRONT SUSPENSION Drop Spindles by Aaron Carswell 01-04 Swaybar Endlinks Energy Suspension Endlink Bushings Cando Upper Control arms QA1 coilovers with 8" spring Custom 4 pot Brembo BBK Modified lower control arms with mjbfab qa1 mounting plates and Poly bushing sleeves REAR SUSPENSION Chasis Tech drop leafs QA1 adjustable shocks weld in drop notch Gas tank cross member bridge 3" angled blocks 2013 Double Cab Short Bed TRD Sport Eibach Pro Truck Shocks front and rear Lifted to the 3rd setting on the front shocks
    Just got my new grinder. My chop saw will be here tomorrow.
  6. Dec 30, 2018 at 7:13 PM
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    Is that a 4-1/2" grinder? It looks different from my 4". I have a 4-1/2" cordless dewalt I use also. One has a flap disc on it and one is for cutoff wheels.
  7. Dec 30, 2018 at 7:33 PM
    mjbtaco
    Michael
    Montclair , so cal
    4.5"
    Blackout14, stumbles, jjsul and 2 others like this.
  8. Dec 31, 2018 at 12:24 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    The best thing you can do is throw the handle away .
    You can never have to many grinders
    deeezy and Bentrodder like this.
  9. Dec 31, 2018 at 4:37 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I don't have any use for the blade gaurd either.
    Running Board Man and Bentrodder like this.
  10. Dec 31, 2018 at 4:43 AM
    jjsul
    jjsul Well-Known Member
    James
    New Hampshire
    95.5 OME
    I was just gifted this one for Christmas. Beast compared to my porter cable
    stairgod, mjbtaco, velillen and 2 others like this.
  11. Dec 31, 2018 at 4:52 AM
    Pella
    Pella Well-Known Member
    Pella
    209
    SSMDCSBORFTMFW
    AFAA5165-B6CC-447E-906E-5A2D1A20EA7C.jpgI just got one of these recently.
    Running Board Man, koditten and jjsul like this.
  12. Dec 31, 2018 at 5:01 AM
    jjsul
    James
    New Hampshire
    95.5 OME
    I heard these are the beezneez
    Pella[QUOTED] likes this.
  13. Dec 31, 2018 at 5:23 AM
    Pella
    Pella
    209
    SSMDCSBORFTMFW
    They are. It’s a great grinder. A brand that is rarely brought into the conversation but should be.
    kystnTRD and jjsul[QUOTED] like this.
  14. Dec 31, 2018 at 5:26 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Bentrodder likes this.
  15. Dec 31, 2018 at 7:12 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    My First Metabo was a piece of junk never bought another one .
    Must be about 30 years ago.
  16. Dec 31, 2018 at 9:32 AM
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    11 amp?
    Edit: nevermind 7.5A
  17. Dec 31, 2018 at 6:35 PM
    mjbtaco
    Michael
    Montclair , so cal
    Got my chop saw and tested out the grinder. Love them both!
    jjsul and EatSleepTacos like this.
  18. Dec 31, 2018 at 6:39 PM
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    O man you better not mention the chop saw! Now all you will hear is how a cold cut saw or bandsaw is the only way to go :)
    WarrenG, Blackout14, jjsul and 6 others like this.
  19. Dec 31, 2018 at 6:47 PM
    mjbtaco
    Michael
    Montclair , so cal
    Lmao I already know this but this is the best bang for the buck and suites my needs at the moment. I'll eventually get both of those things haha.
  20. Dec 31, 2018 at 6:49 PM
    velillen
    Nick
    Wyoming
    2011 Access Cab 4x4
    I was just giving ya a hard time. I still use mine for all sorts of stuff
