Anything welding
Discussion in 'Garage / Workshop' started by EL TACOROJO, Sep 17, 2010.
  1. Apr 13, 2019 at 9:01 PM
    YumaTRD
    YumaTRD The Church Of @ODNAREM San Diego Chapter 1904
    David
    El Cajon, CA
    Solid Axle Yota
    Locked, Flat bed, 22R 5 speed, BFG KO2's
    Being a coastal location can cause oxidation to the liner. I see it in my Customer units.
    deeezy[QUOTED] likes this.
  2. Apr 14, 2019 at 1:04 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I see this quite often .
    Always do the simple things.
    The fact the Guns on the 211 are quite poor may have something to do with liner problems
    By chance do you tend to bend the gun hard at either end??
  3. Apr 14, 2019 at 1:17 AM
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    I actually try to be aware of that and keep the hose pretty straight. The smallest bend my hose/liner bends is about a 2 foot loop when put away and rolled up.
    The liner looked straight when I pulled it out.
  4. Apr 14, 2019 at 3:39 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I can remember cleaning mine a few times, but that's about it.
  5. Apr 15, 2019 at 8:10 PM
    mjbtaco
    mjbtaco low and slow
    Michael
    Montclair , so cal
    Turbo'd 95.5 extra cab and 2013 Silver DCSB TRD Sport
    PERFORMANCE Custom Turbo Setup FRONT SUSPENSION Drop Spindles by Aaron Carswell 01-04 Swaybar Endlinks Energy Suspension Endlink Bushings Cando Upper Control arms QA1 coilovers with 8" spring Custom 4 pot Brembo BBK Modified lower control arms with mjbfab qa1 mounting plates and Poly bushing sleeves REAR SUSPENSION Chasis Tech drop leafs QA1 adjustable shocks weld in drop notch Gas tank cross member bridge 3" angled blocks 2013 Double Cab Short Bed TRD Sport Eibach Pro Truck Shocks front and rear Lifted to the 3rd setting on the front shocks
    Got my Instagram giveaway prize
    jubei, D2., Pella and 3 others like this.
  6. Apr 16, 2019 at 1:36 AM
    weldertaco
    weldertaco Mr.13%bodyfat
    texas
    TrailRunner
    4wd to 2wd conversion
    Sucks the price of steel has gone up so much. Makes killing time building stuff as a hobby kinda expensive
  7. Apr 16, 2019 at 10:22 AM
    deeezy
    Dana
    Hawaii
    I got my bumper finished up. Added these side supports to the center hoop. My notcher can't notch at that angle so I had to cut it with my angle grinder using this free notching pattern online.
    slander, jubei, D2. and 13 others like this.
  8. Apr 16, 2019 at 11:04 AM
    la0d0g
    running for the hills
    For crawling not hauling
    That printout is a great idea!
  9. Apr 16, 2019 at 2:38 PM
    BamaTaco56
    BamaTaco56 Well-Known Member
    Trey
    That’s slick!
    deeezy[QUOTED] and whatstcp like this.
  10. Apr 16, 2019 at 2:39 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    What in the fuck, that's genius!! I'm going to be using that.
  11. Apr 16, 2019 at 2:43 PM
    la0d0g
    Would have helped me a ton when I was just eyeballing my shock hoop support brace cuts :laughing:
  12. Apr 16, 2019 at 2:43 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
  13. Apr 16, 2019 at 2:51 PM
    la0d0g
    deeezy and EatSleepTacos[QUOTED] like this.
  14. Apr 17, 2019 at 7:47 AM
    Jensonbt
    Jensonbt Well-Known Member
    Beckler
    Idaho
    2012 gray tacoma DCLB
    Just enough to look kinda cool.
    I made a mini wrench, thanks for the idea.
  15. Apr 17, 2019 at 12:00 PM
    deeezy
    Dana
    Hawaii
    That's awesome. I think im going to borrow that idea also.
    TheDevilYouLove likes this.
  16. Apr 17, 2019 at 5:23 PM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    Now we’re all going to start chopping our wrenches
    deeezy, jberry813 and EatSleepTacos like this.
  17. Apr 17, 2019 at 5:25 PM
    koditten
    Kirk
    Central Michigan
    Not all.
    TomTwo and Drainbung like this.
  18. Apr 17, 2019 at 5:33 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Or start extending them. I could use a longer 19 for some extra leverage. 3’ wrench anyone?
  19. Apr 17, 2019 at 5:42 PM
    koditten
    Kirk
    Central Michigan
    It still is an awesome bottle opener.
    Even though we have been neutered with these ghey twist off caps.
    whatstcp likes this.
  20. Apr 17, 2019 at 6:22 PM
    Jensonbt
    Beckler
    Idaho
    I got like 3 inches of extra wrench if you need some material.
