Anything welding
Discussion in 'Garage / Workshop' started by EL TACOROJO, Sep 17, 2010.
  1. Dec 12, 2012 at 6:57 PM
    #1221
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    I bought a Miller 140 Auto-set. I wish I'd gone with at least the 180 and maybe even the 211.
  2. Dec 13, 2012 at 7:52 AM
    #1222
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    But then again the 211 is harder to do really thin stuff. So now you just need a 211 and you will be totally set :D
    I hear you though, I have a Hobart 190 and wish I spent the extra to get one more step up and I would have the multi plug
  3. Dec 14, 2012 at 5:37 AM
    #1223
    My68ur8trd
    My68ur8trd Well-Known Member Vendor
    Justin
    Williamsburg, VA
    2007 TRD OR Dcab 4x4
    URD Catback | TRD CAI | TRD S/C | APR X-1 | DTLT | APR 2.85" Pulley |Fabtech 6" | Icon C/O | Alcan Leafs | 33 Grabber AT2 | 17" XD Addicts
    If you are pricing, be sure to go to a welding supply store.
    I was shopping at the big box store for the 180 and it comes in 220 only. Also, the big box store models have selectable speed and power, but its not a full sweep (you can click to 1 or 2, but you cant set it to 1.5) and the wire drive is plastic. It was around 700 bucks.
    I found this deal..
    http://www.lincolnelectric.com/en-u...atters.aspx?WT.mc_id=slider_home_moneymatters
    I went to the local welding supply store and picked up a Lincoln 180 Dual.
    With the incentive you get a nice Viking autodark helmet, jacket, mic gloves, and a duffle. ( all stuff you will need to pick up anyway) and the machine is convertable between 110 and 220 for about 200 bucks more than you would pay at Home Depot for an inferior model.
    Plus it is the commercial model which has all aluminum drives for the wire feed, stronger casing, and is fully tunable. I have welded 3/16 with it no problem with gas and 1/4 no problem with flux ( I have done some 1/4 parts with gas and it seems to be fine, but I have not cut any welds to inspect the penetration, Lincoln recommend to use flux and/or multi pass for anything over 3/16 with the 180)
    Just a suggestion
    Justin
  4. Dec 14, 2012 at 10:05 AM
    #1224
    SCRunner12
    SCRunner12 Tundra Troll
    Robert
    Santa Cruz, CA
    2006 Tundra DC, TRD, 4wd
    Ok I'm debating going with the Hobart 140, 210 or waiting for the 190 to be back in stock. I'll mostly be using this in my garage to mess around and eventually build some bumpers with. Any suggestions? I have 220V for my dryer, so I figure I might as well go with that. I'm thinking of buying this weekend as I have a 10% off that ends this weekend and that would make the 210 only 495 shipped or I could get the 140 for 370 and that would allow me to spend the extra money on a gas tank and other supplies.
  5. Dec 14, 2012 at 10:30 AM
    #1225
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    I'd get the 210 for that price. Always better to have a little more power than needed, plus maxing out a smaller welder will give a really low duty cycle vs having the larger machine at the same power.
  6. Dec 14, 2012 at 10:36 AM
    #1226
    M C M
    M C M Well-Known Member Vendor
    Matthew
    Sin City, Nevada
    91 Toyota Pick Up, 02 Toyota Tundra
    Lots of expensive shit
    My best advice as a shop owner is if your worried about a 50-100$ difference on a welder now, your really going to stress when you have to buy the other tools to make your welder useful.
    Thermal Arc makes a real nice all in one machine. Its about 1100 but does mig tig and arc and is a 180 amp machine.
    I'm a Miller guy, my Millermatic 250 is going strong at 22 years old and has never had an issue. I spent 1700 on my 250 and a hypertherm plasma when I was 17 and it was the best investment I ever made.
  7. Dec 14, 2012 at 12:10 PM
    #1227
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    Be careful with "all in one" machines. There's nothing wrong with them but that what they offer might not necessarily be what you want so whether you look at the Hypertherm, Everlast or ESAB, be sure they offer what you want-especially as it relates to the TIG portion.
  8. Dec 14, 2012 at 12:28 PM
    #1228
    RelentlessFab
    Eric
    Sparks, NV
    Agree with you here, all fab equipment isnt cheap and adds up quick. Even a simple roll of wire can be $50-100+ and a tank of shielding gas $30+. Grinders, clamps, a welding table, welder/cylinder cart, drill, etc.
    I run ThermalArc welders daily. Great machines. I'll be trying the 211i soon, I just got it for $1135. The 181i can be had for under $900 if you look around online.
    I wouldnt personally purchase an all in one that does plasma too, nor a cheap chinese welder. ThermalArc or miller 3 in 1 would be my only choice and thermal arc wins with lower cost and previous experience with both brands. :cool:
  9. Dec 16, 2012 at 4:50 PM
    #1229
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    Is the roller setup for the size wire you're running? How does the wire feed? Almost seems like either a liner or feeder causing a short.
    I've never seen it or even read about it happening.
    edit: I was just reading about wire liners and the indication seems to be you need to swap them after 6 months of use (like every day use). But if you burn the wire back to the tip, you might also need to swap it sooner. I'm not sure what the real interval is but it sounds like with heavy use, it needs to be done.
  10. Dec 16, 2012 at 5:09 PM
    #1230
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    The color is indicative of heat. Maybe the wire doesn't melt but it does get hot ;)
  11. Dec 16, 2012 at 5:22 PM
    #1231
    littledvl
    littledvl ride BMX!
    Eric
    Saint Leonard MD
    08 taco dc 4x4 / 15 tundra dc 4x4
    Too many to list
    Had it happen every now and then on a old welder we got from an auction at work. Problem was there was a bare spot on the ground not far out the machine and it was grounding the machine, so the wire hit the steel roller and melted causing it to bind and screw shit up. The welder worked fine until you would pull the ground a certain way and make it arc, after we fixed the ground hasnt had the problem since..
    Not sure its the same issue your having but my suggestion is there is a short somewhere in the machine.
  12. Dec 16, 2012 at 11:07 PM
    #1232
    logcabinwc
    logcabinwc Well-Known Member
    Micah
    SF East Bay
    08 4d 4x4 White V6 TRD
    Old Man Emu 885s with Nitrocharged 90000, Bilstein 5100 in the back with AllPro 3 spring progressive AAL, 16 inch Baja Black 6-spoke alloy wheels, Flow Master exhaust, bed lights, Pioneer HD radio, Uniden CB Radio, K&N Air filter, BAMF Sliders w/kickout, Relentless Aluminum IFS Skid, 24 LED light bar, custom/homebuilt expedition style bed rack and basket combo, and Body Armor rear plate bumper.
    Alright I need a little help. I am new at welding, and just got my first little baby stick welder. I need to finish up building my bed rack (which I did in a metal fab class) but was using nicer mig welders while building most of it.
    I now have a little Proline BX1-100B 110V AC welder (off of Amazon here). I'll only be finishing up some welds on 1/8" thick mild steel.
    Should I get 6011 electrodes that are 1/8" diameter?
    And What should I set it at? I am a little confused..
    Any help would be appreciated!
    Oh and here is what I am working on
  13. Dec 16, 2012 at 11:24 PM
    #1233
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    You would need to set the machine between 75-100A with the 1/8" rod. For the 3/32" rod, you would need between 45-55A.
    6011 is a good general purpose rod.
  14. Dec 16, 2012 at 11:29 PM
    #1234
    logcabinwc
    Micah
    SF East Bay
    ok that sounds great! just what I needed to know. Thank you for helping the newb! :rolleyes:
  15. Dec 16, 2012 at 11:35 PM
    #1235
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    Once you get good at running the 6011, give some 7018 a shot. Much prettier welds produced.
  16. Dec 16, 2012 at 11:47 PM
    #1236
    logcabinwc
    Micah
    SF East Bay
    would 7018 work with a 110v?
  17. Dec 17, 2012 at 6:26 AM
    #1237
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    It should, I know I usually run maybe 5-10 amps hotter with the 7018 compared to 6011 but your welder should have no problem depending on the thickness of material.
  18. Dec 17, 2012 at 7:03 AM
    #1238
    Creston
    Creston Crusty
    CrustyBushman
    DaBush, Manitoba, Canada
    2006 tacoma sport
    ARB Front bumper. OME suspension with 2.5" lift. Firestone airbag load assist.
    Use 7018 for everything. it's stronger and can be used in any position.
  19. Dec 17, 2012 at 7:16 AM
    #1239
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    I need someone to weld some aluminum around Raleigh. Anyone know anyone?
  20. Dec 17, 2012 at 5:22 PM
    #1240
    logcabinwc
    Micah
    SF East Bay
    Well i tried getting my little welder going today with both 1/8 and 3/32 6011. The dang thing will not keep a sustained arc! I've tried tapping and scratching and for the life of me I could not get it to maintain an arc.
    Does anyone have any ideas?
