Anything welding
Discussion in 'Garage / Workshop' started by EL TACOROJO, Sep 17, 2010.
  1. Aug 2, 2019 at 3:12 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I use a carbide blade on my circular saw and my compound miter saw. Some say to turn the blades around, but I don't see that it works any better.
  2. Aug 2, 2019 at 4:09 PM
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    Next question, I know this is not an "electrician" thread but whatever.
    I'm going to install a 110V and a 220V outlets outside (next to my garage). Can I run all wires through the same conduit? Or should I use separate conduits for each voltage?.
  3. Aug 2, 2019 at 4:22 PM
    koditten
    Kirk
    Central Michigan
    I know I would have no issue using the same conduit.
    Most likely you will need 1" conduit.
    A 30 amp breaker will be good for 10 gauge wire to feed the 240 volt welder.
    The 20 amp 120 volt wires can be 12 gauge. You can use 14, but might as well be sure.
    I know I'm gonna start an argument, but just because you have a 50 amp plug in the welder, does not mean you need a 50 amp breaker and the 8 gauge wire to go with it.
    My plugs are changed to 30 amps before I ever use the welders.
  4. Aug 2, 2019 at 4:27 PM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    Just googles "EMT Wire Fill Chart" and will show how many conductors you can run through X" conduit by wire gauge.
    Rakso[QUOTED] and Bigdaddy4760 like this.
  5. Aug 2, 2019 at 4:37 PM
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    I got 20A for compressor on 110V, also 30A for 220V for welder.
    koditten[QUOTED] and Drainbung like this.
  6. Aug 2, 2019 at 5:35 PM
    zachshere
    zachshere Well-Known Member
    Hi! I'm sure this has been asked before (i'm to lazy to look through the whole post history) But what equipment do you suggest for someone wanting to get into basic welding? I would like to be able to do basic small repairs and maybe a bit of accessory construction. As always looking at a limited budget.
  7. Aug 2, 2019 at 5:44 PM
    koditten
    Kirk
    Central Michigan
    Vulcan Mig Max 215.
    I can't find a better deal or warranty or return policy ( you won't be returning it).
    A friend of mine just bought this unit this week. I tried it out and I'm very happy with the performance/quality.
    You will be handing this down to your grandkids.
  8. Aug 2, 2019 at 5:50 PM
    zachshere
    Do you need a torch as well? Sorry, typical newbie.
    Bigdaddy4760 likes this.
  9. Aug 2, 2019 at 5:51 PM
    koditten
    Kirk
    Central Michigan
    I'm not following.
    What kind if torch?
  10. Aug 2, 2019 at 5:56 PM
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    This. Search my posts on this thread. You'll see.
  11. Aug 2, 2019 at 5:57 PM
    koditten
    Kirk
    Central Michigan
    Do mean cutting torch?
    I sold my torch kit years ago. Using a portable metal cutting band saw has been my main way of cutting metal.
    If you mean welding torch, well, the welder cones with the needed welding torch, we call them MIG guns for short.
    Bigdaddy4760 and Drainbung like this.
  12. Aug 2, 2019 at 10:09 PM
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    As I understand it, I need a 3/4in ID conduit.
    Drainbung[QUOTED] likes this.
  13. Aug 3, 2019 at 1:40 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Your pretty much just running from a panel in your shop through the wall to the outside .
    You want two different breakers one for the 120VAC the other 240VAC( or the voltage you have)
    The larger the conduit the easier to pull the wires
    I thought you had a Plasma cutter don`t like using it for Aluminum?
    The real reason I bought mine that sits unused for years now.
  14. Aug 3, 2019 at 1:53 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Limited budget and welding never go together !
    It is a ever growing collection of tools .
    Living where you do myself I can`t live without a Oxy-Fuel Torch then using them the last few years since the early seventies .
    Knowing how to braze is also a good reason
    So very hard to heat with a porta band or a plasma cutter.
    It all depends just what you might get into one can never have enough clamps or in my case 4" or 4 1/2" grinders with the assorted disc options.
    Lets not forget the safety gear glasses ear plugs gloves .
    Welding hood those are about the hardest thing if it does not feel right it gets tossed aside to let others watch .
    Myself if I had to make do with one process it would be stick for the majority of what I do any more
    koditten likes this.
  15. Aug 3, 2019 at 8:26 AM
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    Yes. I do have a plasma cutter. Lol I forgot about it. LOL.
  16. Aug 3, 2019 at 8:34 AM
    deog
    deog Well-Known Member
    snicklefritz
    Las Vegas. As far west as you can go.
    work in progress
    gucci interior and chandelier.
    Day off.
    Getting burned out on 65 hour weeks .
    I just want to stay inside in the AC and do absolutely nothing.
    Cheers
    koditten and buyobuyo like this.
  17. Aug 3, 2019 at 8:40 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Did I not say enjoy the down time while you have it !
    It seldom lasts long when you can repair or build things
    deog[QUOTED] likes this.
  18. Aug 3, 2019 at 9:19 AM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    That's me everyday after work and every weekend. The heat/humidity here in AR is killer. :bananadead: :rain: I definitely miss the non-existent humidity from my time living in NM. :tumbleweed:
  19. Aug 3, 2019 at 11:46 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    any tips how to keep a wire feed welder to feed? it seems like its slipping when I hit the trigger. Ive tightened the adjuster inside, I just didnt know if it should be tighter or what?
  20. Aug 3, 2019 at 11:51 AM
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    Do you have the right wheel for the wire size?
