Anything welding
Discussion in 'Garage / Workshop' started by EL TACOROJO, Sep 17, 2010.
  1. Aug 11, 2019 at 7:07 AM
    glorifiedwelder
    glorifiedwelder IG= @Liquid_Torch
    jason
    Santa Clarita, ca
    double cab trd sport
    x2 on the bandsaw. I like them because they are quite and are somewhat of a labor multiplier. I can set everything up, start the cut, and walk away to do something else, saw turns itself off when the cut is finished. You can also flip it to the vertical position and use it a vertical bandsaw by putting a table in the saws vice.
  2. Aug 11, 2019 at 7:28 AM
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    Thanks for the replies.
    I would use it maybe a couple of times a month. I like bandsaws, but space is at a premium. A chop saw can get stashed on a shelf or under the welding table. A bandsaw would likely take up a similar amount of floor space as the welding table.
    Budget wise, I don’t mind spending a little more for a better quality tool. I’ve been looking at the dewalt dw872 for roughly $500, or the evolution rage 2 for about half the price of the dewalt. Or the evolution evosaw380 for about $400.
  3. Aug 11, 2019 at 8:09 AM
    weldertaco
    weldertaco Mr.13%bodyfat
    texas
    TrailRunner
    4wd to 2wd conversion
    Be careful. Heard the blades are not cheap on those and you can get 200 cuts from 1 or 1 cut if you don’t know what you’re doing.
    D2. likes this.
  4. Aug 11, 2019 at 8:25 AM
    JLink
    Josh
    Ocean, NJ
  5. Aug 11, 2019 at 8:43 AM
    Sacrifice
    Sacrifice Motorcycle Goon
    KS
    DCSB OR 4X4 LT
    Pelfreybilt Front Bumper,BAMF sliders, Airflow Snorkel,Mini D2S Retrofits, ADS Rear Shocks, Deaver U402 Leafsprings, 35s, AllPro +2LT
    Have you thought about a portaband?
    koditten likes this.
  6. Aug 11, 2019 at 11:30 AM
    weldertaco
    texas
    TrailRunner
    Barely passed but I passed. Gonna be chasing drilling rigs now.
    Oregon Mike, jjsul, la0d0g and 9 others like this.
  7. Aug 11, 2019 at 11:42 AM
    weldertaco
    texas
    TrailRunner
    Thank ya. Now to tell my other boss that I quit lmao
  8. Aug 11, 2019 at 11:58 AM
    JLink
    Josh
    Ocean, NJ
    I don’t have much experience with them, but to me it seems like it wouldnt be a good choice. I’m looking to make square cuts and miters
  9. Aug 11, 2019 at 12:23 PM
    glorifiedwelder
    jason
    Santa Clarita, ca
    Portabands are awesome and definitely the best choice for certain jobs. But I’d bet if I handed one to 10 different guys who hadn’t used them a bunch, only 2-3 could make a straight cut
  10. Aug 11, 2019 at 12:43 PM
    mjbtaco
    mjbtaco low and slow
    Michael
    Montclair , so cal
    Turbo'd 95.5 extra cab and 2013 Silver DCSB TRD Sport
    PERFORMANCE Custom Turbo Setup FRONT SUSPENSION Drop Spindles by Aaron Carswell 01-04 Swaybar Endlinks Energy Suspension Endlink Bushings Cando Upper Control arms QA1 coilovers with 8" spring Custom 4 pot Brembo BBK Modified lower control arms with mjbfab qa1 mounting plates and Poly bushing sleeves REAR SUSPENSION Chasis Tech drop leafs QA1 adjustable shocks weld in drop notch Gas tank cross member bridge 3" angled blocks 2013 Double Cab Short Bed TRD Sport Eibach Pro Truck Shocks front and rear Lifted to the 3rd setting on the front shocks
    I really like my wen bandsaw. It's not top of the line but I've made a ton of cuts already with it and I love it. The blades are cheap too. It's perfect for my purposes.
    jubei, la0d0g, JLink[QUOTED] and 4 others like this.
  11. Aug 11, 2019 at 1:40 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Better then not at all !!
    I knew you could do it .
    How far from home and how long ??
    Time for the camper yet??
    Running Board Man and wilcam47 like this.
  12. Aug 11, 2019 at 1:43 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Don`t burn the bridge no matter how bad the job was .
    Good employers are always glad when you move up in the game even when they hate to lose a good employee
    RedBeard1, Bentrodder and wilcam47 like this.
  13. Aug 11, 2019 at 1:44 PM
    weldertaco
    texas
    TrailRunner
    I got nervous and fucked up in one spot but the dude was cool about it.
  14. Aug 11, 2019 at 1:45 PM
    weldertaco
    texas
    TrailRunner
    Yea I’m actually sad leaving this time. My boss was a good boss but this is just something I gotta do for my growth and future. Really hard to find a good boss these days but by golly I had one.
  15. Aug 11, 2019 at 1:48 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Sadly the ones I have used are mostly in the $2500.00 range.
    Yes Blades are expensive and your really limited in what you can cut.
    I won a chop saw at a welding Expo years ago I gave it away 15 minutes later
    Running Board Man and koditten like this.
  16. Aug 11, 2019 at 1:59 PM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    Your welding table must be tiny, or you're looking at huge bandsaws. A consumer/prosumer vertical bandsaw shouldn't take up much more than about 2'x2' of floor space. A horizontal will take up more, but if you get one with wheels, it can be stored under a shelf or workbench (if it's tall enough). You can also just store it against a wall and pull it out when needed.
    There was a saw like that in one of the shops I worked on a project in at my last job. I forget the brand, but it cut really well. It had plastic jaw covers which I wasn't a fan of, but it made quick work of all the bolts I was chopping down to size.
  17. Aug 11, 2019 at 5:22 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    how much?
  18. Aug 11, 2019 at 8:38 PM
    mjbtaco
    Michael
    Montclair , so cal
  19. Aug 11, 2019 at 9:53 PM
    wilcam47
    Will
    Bourbon state
    a pass is a pass...
    weldertaco[QUOTED] likes this.
  20. Aug 12, 2019 at 4:06 AM
    JLink
    Josh
    Ocean, NJ
    I was referring to horizontal, and my welding table will be 2’x4’
