Anything welding
Discussion in 'Garage / Workshop' started by EL TACOROJO, Sep 17, 2010.
  1. Sep 24, 2019 at 2:39 PM
    Martyinco
    Martyinco Well-Known Member
    Amazon, and any rig welder supply in the country
    wilcam47 likes this.
  2. Sep 24, 2019 at 3:10 PM
    malburg114
    malburg114 Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
  3. Sep 24, 2019 at 3:25 PM
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    Pipe stands and bessy clamps
    Pretty sure those are the best gifts you can get a welder haha
  4. Sep 24, 2019 at 3:31 PM
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    Beautiful, thanks. :cheers:
  5. Sep 24, 2019 at 4:24 PM
    m603holden
    Marteeen
    New England
    I forget what the size is, but grab extra pipe. You can make all sorts of helpfully holders and braces out of them. Cut 2 U's in some angle iron and weld it to a post and you'll have a grinder and wire wheel holder
    Drainbung and Bigdaddy4760 like this.
  6. Sep 24, 2019 at 5:59 PM
    malburg114
    Las Vegas, NV
    How are you guys getting rid of mill scale? Accidentally got a hole sheet (4x8) of 1/8 hot rolled since I forgot to tel him cold rolled and didn’t realize till I got home and cut it so I’m stuck with it... not really looking to grind it off was hoping there’s a better solution
  7. Sep 24, 2019 at 6:12 PM
    INBONESTRYKER
    INBONESTRYKER Well-Known Member
    WY
    '96 access cab 3.4 5 spd manual 4X4
    Diluted muriatic acid, in a plastic container, rinse with water, spray with WD40. Small batches Do this outside, wear a respirator & plastic safety glasses, rubber or vinyl apron old shoes that you can throw away. Neutralize acid with baking soda (keep adding until there is no reaction). Good Luck and be safe.
    Drainbung and malburg114 like this.
  8. Sep 24, 2019 at 6:22 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I just use a wire cup on my hand grinder.
  9. Sep 24, 2019 at 6:23 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I just clean up the areas I’m gonna weld and that’s it. Just paint over the rest.
  10. Sep 25, 2019 at 12:46 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Depends some is so thick grinding is the only way.
    Clean a little past the heat effected zone.
    Return it and get cold rolled unless you worked it up already .
    malburg114 likes this.
  11. Sep 25, 2019 at 2:14 PM
    koditten
    Kirk
    Central Michigan
    deog, la0d0g, jjsul and 2 others like this.
  12. Sep 25, 2019 at 6:47 PM
    KILLINTIME
    KILLINTIME Like a Villain
    My Fitter and I Have 60+ hours this week on welding/ fitting X-ray sch40 300# weld neck flanges to spool pieces for a propylene oxide system upgrade for a shut down. Every bit is going into the scrap dumpster. Engineer ordered the wrong parts....thousands of dollars down the drain. FFA4D9AD-8445-4311-AA1F-E5038C6EDDA9.jpg
    wilcam47, buyobuyo, bagleboy and 2 others like this.
  13. Sep 25, 2019 at 9:46 PM
    deog
    deog Well-Known Member
    snicklefritz
    Las Vegas. As far west as you can go.
    work in progress
    gucci interior and chandelier.
    Dynasty 200 went down AGAIN today. 2nd time in 2 months.
    Dragged out the tried and true syncrowave 250 DX.
    At this point I am not a fan of these inverter machines. All the electronics makes for a unreliable machine in a production facility as far as I am concerned. Old school transformer machines don't have all the bells and whistles these new inverter machines have, but I am not making parts for NASA so I don't care.
    Old transformer machines don't die
    Just my opinion but I have never had good luck with any new fangled inverter machine, they all have issues sooner then later.KIMG0947.jpg
  14. Sep 25, 2019 at 10:13 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Too bad, that shit's a work of art.
    koditten and KILLINTIME[QUOTED] like this.
  15. Sep 25, 2019 at 11:39 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    What happened to the Die nasty ?? ( I get told about spelling it that way)
    I tend to agree the Transformer/Rectifier machines last forever it seems the down side is the weight .
    I much rather move a Dynasty 700 around then a Syncrowave 300
    Yet most all the new machines are inverter based
  16. Sep 26, 2019 at 8:13 AM
    WarrenG
    WarrenG Well-Known Member
    Agreed. My transformer tig welder has survived 15 years of -30 to +30 deg C seasons in the garage. It can also double as a battering ram if needed.
    deog[QUOTED] and koditten like this.
  17. Sep 27, 2019 at 6:34 AM
    deog
    snicklefritz
    work in progress
    Starting a windmill. 15' tall. Has a motor and everything.
    la0d0g, Shmellmopwho, irayfz6 and 3 others like this.
  18. Sep 27, 2019 at 7:41 AM
    deog
    snicklefritz
    work in progress
    Probably some mother board or computer chip. That is what it has always been in the past. I just don't think this fancy machines and all there electronics can stand up to the grinding dust in a production facility.
    Transformer machines don't go down.
    koditten and HCFab like this.
  19. Sep 27, 2019 at 8:27 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    I hear you !1
    In theory you should not suck metallic dust into anything but the wind tunnel .
    Some people do way to much grinding .
    Aluminum is by far the worst for getting where it does not belong .
  20. Sep 27, 2019 at 10:11 AM
    deog
    snicklefritz
    work in progress
    I have metallic dust in my nose every night.
