Anything welding
Discussion in 'Garage / Workshop' started by EL TACOROJO, Sep 17, 2010.
  1. Feb 7, 2020 at 4:23 PM
    weldertaco
    weldertaco Mr.13%bodyfat
    texas
    TrailRunner
    4wd to 2wd conversion
    And they still want that shit to be 100% perfect. Like bruh I can’t even angle the rod/gun/torch in that spot to do the weld the right way.
    Drainbung and Wyoming09 like this.
  2. Feb 7, 2020 at 4:26 PM
    KILLINTIME
    KILLINTIME Like a Villain
    Yuup
  3. Feb 7, 2020 at 4:28 PM
    KILLINTIME
    I fixed 22 leaks on a dimple jacket on a tank Tuesday, they had ATS come out and PT the repairs. That’s how anal they are. LOL
  4. Feb 7, 2020 at 4:30 PM
    KILLINTIME
    Like when they cut the steam back on and the repairs aren’t Leaking.....we’ll still PT them just to make sure they aren’t leaking. :rofl:
    weldertaco likes this.
  5. Feb 7, 2020 at 6:24 PM
    Speedo
    Speedo Well-Known Member
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    I broke it up into 2 days only because no garage so working outside winter days are short and didn't start until noon. Requires a lot of time for sure. Definitely not for the non DIY guy, cost for labor would kill you.
    deeezy[QUOTED] likes this.
  6. Feb 7, 2020 at 6:54 PM
    weldertaco
    texas
    TrailRunner
    Repairs take twice as long.... can’t believe the shit people leave lol
  7. Feb 7, 2020 at 6:54 PM
    weldertaco
    texas
    TrailRunner
    And that around the corner peel
    Ooooffff
    whatstcp and Wyoming09 like this.
  8. Feb 9, 2020 at 3:07 PM
    Gen1FTMFW
    Gen1FTMFW Well-Known Member
    2000 Tacoma 3.4 TRD "Stock AF" & 2006 GX470 Sport
    Anyone have a recommendation on a decent tube notcher? Seems like some say the HF isn't bad, but I don't mind spending a little more for something of decent quality. It seems like most people say the cheaper models don't notch on center and need to be shimmed, would like to avoid that. What say you?
    Shmellmopwho likes this.
  9. Feb 9, 2020 at 5:17 PM
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    My JD2 Notch Master has been doing fine. It's notched a lot if material so far and still works the way it did brand new. It is adjustable so you need to set it center of your material to be notched. Will notch up to about 50 degrees or so. I use Lenox bi-metal hole saw bits for it and they last a really long time.
    Shmellmopwho and GHOST SHIP like this.
  10. Feb 9, 2020 at 6:25 PM
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    I have the cheapo freight, I had to tweak it a bit to make center notches, nothing mayor just added a couple of spacers to lever it. Other than that in think the trick is using decent hole saws.
    deeezy and koditten like this.
  11. Feb 9, 2020 at 6:26 PM
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
  12. Feb 9, 2020 at 6:27 PM
    Shmellmopwho
    Shmellmopwho Well-Known Member Vendor
    Lomita CA
    2013 White DCLB TRD sport
    Bunch of stuff
    I have the Eastwood Professional tubing notcher and it’s been great for years
    https://www.eastwood.com/professional-tubing-notcher.html
    Drainbung, deeezy and GHOST SHIP like this.
  13. Feb 9, 2020 at 6:28 PM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
  14. Feb 9, 2020 at 6:35 PM
    glorifiedwelder
    glorifiedwelder IG= @Liquid_Torch
    jason
    Santa Clarita, ca
    double cab trd sport
    I use the jd notch master with the swag off-road upgrades. Bought it from a member on here. It looks pretty much identical to the Eastwood. I owned a few harbor freight notchers previously. With shimming they will get the job done.
    deeezy and Shmellmopwho like this.
  15. Feb 11, 2020 at 5:54 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Pretty quiet here lately...
    six5crèéd and Shmellmopwho like this.
  16. Feb 11, 2020 at 6:04 PM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    I welded some sheet metal patches on a tractor hood today.
    la0d0g, gpb, deeezy and 6 others like this.
  17. Feb 11, 2020 at 6:08 PM
    jjsul
    jjsul Well-Known Member
    James
    New Hampshire
    95.5 OME
    I’m about to have a baby (wife was due this past Saturday!), so most truck and metal projects are on hold for a while.
    :cookiemonster:
    Dreaming of new, beefier skies and re-working my rear shock relocation.
  18. Feb 11, 2020 at 6:09 PM
    koditten
    Kirk
    Central Michigan
    Congrats!
  19. Feb 11, 2020 at 6:14 PM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
    Congratulations! Your kid will be welding in no time!
    D2., Drainbung, jjsul[QUOTED] and 2 others like this.
  20. Feb 11, 2020 at 6:22 PM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Tried the .030 flux core wire on my sheet metal for my firewall tub, working pretty good. Far less blow through and easier to get some good tacks on there.
