Anything welding
Discussion in 'Garage / Workshop' started by EL TACOROJO, Sep 17, 2010.
  1. Feb 11, 2020 at 6:50 PM
    velillen
    velillen Well-Known Member
    Nick
    Wyoming
    2011 Access Cab 4x4
    Sadly not much fabricating or anything really.
    Instead its been changing out the bearings in the fan motor thingy for my septic system.....and being annoyed at companies while doing it for the amount they want to charge just for parts. Luckily it just needs two bearings and the seal replaced so easy to source them elsewhere
    six5crèéd likes this.
  2. Feb 11, 2020 at 6:52 PM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    That’s crappy they want to do you like that :D
    gpb and koditten like this.
  3. Feb 11, 2020 at 7:04 PM
    velillen
    Nick
    Wyoming
    2011 Access Cab 4x4
    Its just an Aerator thingy thats part of the system. Just blows air pretty much. So its plenty clean outside of grass lol.
    And ~$40 bucks in parts is a hell of a lot better then the 500-600 for a new unit.
    six5crèéd[QUOTED] likes this.
  4. Feb 11, 2020 at 7:45 PM
    mjbtaco
    mjbtaco low and slow
    Michael
    Montclair , so cal
    Turbo'd 95.5 extra cab and 2013 Silver DCSB TRD Sport
    PERFORMANCE Custom Turbo Setup FRONT SUSPENSION Drop Spindles by Aaron Carswell 01-04 Swaybar Endlinks Energy Suspension Endlink Bushings Cando Upper Control arms QA1 coilovers with 8" spring Custom 4 pot Brembo BBK Modified lower control arms with mjbfab qa1 mounting plates and Poly bushing sleeves REAR SUSPENSION Chasis Tech drop leafs QA1 adjustable shocks weld in drop notch Gas tank cross member bridge 3" angled blocks 2013 Double Cab Short Bed TRD Sport Eibach Pro Truck Shocks front and rear Lifted to the 3rd setting on the front shocks
    About to start the fabrication on my turbo setup. Just waiting for a day off.
    six5crèéd and irayfz6 like this.
  5. Feb 11, 2020 at 8:31 PM
    snowboard704
    snowboard704 Well-Known Member
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    A few little projects for people over the last week or so, nothing too crazy. Installed some newer chevy seats into an 86 pickup, had to adjust all the mounts and seat rails so that they sat low enough so that your head doesn’t hit the roof. Also installed a quick disconnect hub and mpi wheel, the weld on splines version A471C201-4607-4067-ABB7-50327F0E1981.jpg D86DFC78-3293-4762-A834-B40C16C850A5.jpg A35E3A6A-D7E0-4BDC-B7D3-33A0C5F0A5A5.jpg C7694A7D-7EB6-41E3-B9B1-2EB5DFC87BFD.jpg 01D2AF1A-5340-467F-B638-209B2CE465B1.jpg
  6. Feb 11, 2020 at 9:48 PM
    malburg114
    malburg114 Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
    Bought a bunch of steel for a side gate... and ordered some fireball squares. 6B6F365E-3C34-4A32-9A74-28CC46098D1F.jpg 2852B71F-3242-4DAB-9BD9-8D3B303EA802.jpg
  7. Feb 12, 2020 at 7:57 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Anyone ever weld a receiver to or through the crash bar for light duty stuff?
  8. Feb 12, 2020 at 8:12 PM
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    It's aluminum. It's weak. It's only bolted to thin metal. You can't pull on it, you'd just rip it off.
  9. Feb 12, 2020 at 8:21 PM
    bagleboy
    Scott
    Norcal, Santa Rosa
    The emphasis was on light duty, like 1k, certainly not truck weight since I don't get off road. I thought it was bolted to the frame ends.
  10. Feb 12, 2020 at 8:25 PM
    teamhypoxia
    Colorado
    '12 DCSB TRD OR
    It's bolted to thin metal at the frame ends. People who have mounted plate bumpers to the same spot without any extra reinforcement have bent those thin plates with light pulls.
  11. Feb 12, 2020 at 8:32 PM
    bagleboy
    Scott
    Norcal, Santa Rosa
    I expect so which is why I'm stipulating light duty non truck weight, not more than front axle weight really. I can lift 100 lbs if I've had my wheaties but not 1000 and it would be nice to have hoist ability at either end.
  12. Feb 13, 2020 at 8:54 AM
    D2.
    D2. Well-Known Member
    Dan
    Nova Scotia, Canada
    2009 Tacoma - access cab 4x4 2TR-FE
    Cruise Control install. Intermittent wipers Hood lights Bed Lights Sliders 3" lift 886's on Billy 5100's Icon AAL 285/75 R16 Falken Wildpeak AT3W's
    I'm with @teamhypoxia, on this. I think it would bend
    with the crash bar being Aluminum, you would need an aluminum receiver.
    not sure I've ever seen one, do you have a link?
  13. Feb 13, 2020 at 9:54 AM
    bagleboy
    Scott
    Norcal, Santa Rosa
    No, i just assumed one would use square stock to make it or if the right size wasn't available make it from two pieces of right angle plus a wrap and I'm sure it would bend if I tried to pull more than 1k or didn't reinforce it some. So far it seems the only use anyone considers is for moving the truck rather than using the truck as the anchor to move something lighter. I've seen aluminum extension ladders coupled with a portable hoist to raise loads and those are much thinner than the crush bar.
  14. Feb 13, 2020 at 10:04 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Why not make a receiver hitch to attach to the 2 tie down Tow hook location not that hard and stronger
  15. Feb 13, 2020 at 12:41 PM
    six5crèéd
    Southern Virginia
    8 lugs no plugs
  16. Feb 13, 2020 at 1:38 PM
    bagleboy
    Scott
    Norcal, Santa Rosa
    I can’t imagine that perforated 1 x 2 is stronger than the crush bar.
  17. Feb 13, 2020 at 4:23 PM
    weldertaco
    weldertaco Mr.13%bodyfat
    texas
    TrailRunner
    4wd to 2wd conversion
    If ya know, ya know
  18. Feb 13, 2020 at 9:18 PM
    Duckfatt
    Duckfatt Member
    Las Vegas NV
    04 DCSB
    6129F0F1-45B7-471C-838E-FF733965A1FB.jpg AD7E5361-7FEC-4573-B78C-CE96364C0649.jpg Hello, just got a welder for Christmas, Hobart 210 MVP. Been practicing every weekend for like an hour at a time. Just figured I could post some welds and get some criticism. Don’t have 220v yet, but this is the highest setting on 115. Overall goal is to SAS on my Tacoma. Thanks.
    la0d0g, deeezy, jjsul and 3 others like this.
  19. Feb 13, 2020 at 9:19 PM
    mjbtaco
    Michael
    Montclair , so cal
    Oh boy this is gonna be fun
    la0d0g, deeezy, buyobuyo and 8 others like this.
  20. Feb 13, 2020 at 9:42 PM
    snowboard704
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    that would look sweet tig welded
