Anything welding
Discussion in 'Garage / Workshop' started by EL TACOROJO, Sep 17, 2010.
  1. Mar 20, 2020 at 9:45 PM
    Zebinator
    Zebinator Well-Known Member
    Norcal
    06 Tacoma TRD Offroad
    Thes pics are reinforcing how much I suck at mig. I need professional help!
    gpb and deeezy[QUOTED] like this.
  2. Mar 20, 2020 at 9:49 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Mine has a chart in the back of the manual showing gauge and length. Your 12 gauge cable might be alright if you cut it shorter. Nice looking welds.
    deeezy[QUOTED] likes this.
  3. Mar 21, 2020 at 12:05 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Did you use the same plugs or go with new ones??
    It is not only the length and size it is also all the connections you have the blade connections as well as where the wire connects to the blade and the female side as well all can cause voltage drop.
  4. Mar 21, 2020 at 12:39 AM
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    No, I'm using the same big 50A receptacles. Just changed the wire gauge. It's 50 feet long so I think that was the issue. I wanted it that length so I could roll my welder outside of my garage if I had to.
  5. Mar 21, 2020 at 7:45 AM
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    Got this in the mail last night! Time to set it up and start getting back into the swing of things.
    Really stoaked to finally have my own machine. I Took a few welding classes in college and spent most of my senior year on a tig welder putting together the chassis and suspension for the Baja SAE team.
    Already made a fat trip to the steel yard so I’ve got material for a few projects lined up for once I get stuck at home.
    deeezy, malburg114, irayfz6 and 7 others like this.
  6. Mar 21, 2020 at 12:09 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Good luck read your manual !!
    To new for my taste
  7. Mar 21, 2020 at 12:11 PM
    Rakso
    Rakso CeRaTi
    OsKaR
    Cali
    09 PreRunner
    LSK LT in Progress, custom bed cage, DMZ SUA kit with 2.5 kings triple bypass, kings bump stops, baja bumper, rear custom tube bumper, glass all around, Weather Tech Liners, wet okole seat covers, Cluster LED Swap, HU LED Swap, hood LEDs, bed LEDs, etc etc etc
    Was at the metal store today.
    deeezy, six5crèéd and Drainbung like this.
  8. Mar 21, 2020 at 3:07 PM
    snowboard704
    snowboard704 Well-Known Member
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    nice! I have the 211, so same machine minus the dc tig functions. I’m liking it so far minus a setback with the mig gun, which miller replaced for free
    kind of different from the miller 252 I came from but definitely a lot easier to move around the shop!
    Drainbung and six5crèéd like this.
  9. Mar 21, 2020 at 3:34 PM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    That seems like decent prices.
    Drainbung likes this.
  10. Mar 21, 2020 at 5:12 PM
    deeezy
    Dana
    Hawaii
    I use a Miller Elite. Isn't the Infinity a step above the Elite? I use the X-mode all the time when peeking through areas that block the sensors and it works pretty darn good.
  11. Mar 21, 2020 at 5:38 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I use an elite as well.
    I guess you will now have a good for home and 1 for work.
  12. Mar 21, 2020 at 5:49 PM
    snowboard704
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    I killed a digital elite after 5 years. Great hood. I plan to get the infinity for tig only
    currently use a speedglas for mig
  13. Mar 21, 2020 at 5:59 PM
    deeezy
    Dana
    Hawaii
    Bigger window. Keeps track of how long it's been dark. Different headgear maybe?
  14. Mar 21, 2020 at 7:08 PM
    plurpimpin
    PDX
    I was shopping for a 211 but with the current rebate it was only a $100 difference for the Multimatic. Figured screw it good excuse to play with a tig torch. Realistically most of my projects are steel anyway. If I need AC tig down the line I’ll get a dedicated machine.
    snowboard704[QUOTED] likes this.
  15. Mar 21, 2020 at 10:30 PM
    snowboard704
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    yea I’m at the point where I need a new dedicated tig (ac/dc)
    The rebates are great! I picked up the 211 on a pretty good rebate also!
  16. Mar 22, 2020 at 3:19 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    When they first came out all kinds of issues to the point some distributors quit selling them.
    I thought of buying one for the large view and was talked out of it at the time just remember I have worked with all the distributors for 15 years
    Not that things were not fixed one way or another under warranty it was just the hassle.
    Been some time lets hope the bugs have been worked out.
    3 year warranty depending on if you weld the majority of your day that is lots of ARC time.
    take the digital elite home for home work. besides if the work hood dies a new one is right up the street so to speak
    It is provided go for it
  17. Mar 22, 2020 at 8:42 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    About to tack these in
    deeezy, jjsul, koditten and 2 others like this.
  18. Mar 22, 2020 at 9:03 AM
    Zebinator
    Norcal
    My wallet is now so light it might actually float this beast up on to the legs I have yet to weld. At least I hope so... I definitely can’t lift it! 59 more holes to go and then on to legs.
  19. Mar 22, 2020 at 9:14 AM
    fatfurious2
    David
    Ashburn, VA
    Not too bad so far
    excorcist, six5crèéd, jjsul and 5 others like this.
  20. Mar 22, 2020 at 10:20 AM
    deeezy
    Dana
    Hawaii
    How do you like the speedglas compared to the M. Elite?
